My 2nd One Piece Oil Pan Gasket is Leaking Again!??? Help! - Chevelle Tech
Auto Insurance
Old Jun 2nd, 04, 12:09 AM
ChevroletR ChevroletR is offline
Ryan
Post
Hello again, if you don't remember me I was asking about putting a Milodon 7 quart oil pan on my 350 in my Monte months back and I finally did and I used FelPro's 1 piece oil pan gasket PN OS34509T I think and it leaked like crazy a week later but not from the front or back or corners, from the sides!? I figured I had tightend the bolts too tight because it only says 18ft lbs on the corners and 8ft. lbs. on the rails and I know for sure I did more than 8 on the rails. I called Fel-Pro and they said I could have definately mushroomed the gasket by over tightening So I went ahead, took the pan back off and got ANOTHER $35 Fel Pro 1 piece gasket and straightend out the oil pan rails that were barely even dimpled in (only some holes were from where I had overtightended it) and put the pan back on and only snugged the rail bolts (about 8 ft lbs) after I had tightened the corners to 18ft lbs. And right after I drove it it leaked like crazy still, still from the sides. I fired it up and got underneath and started tightening the bolts on the SIDE where I saw oil leak and the leaks slowly went away and I was only down to 3 bolts that oil was coming out around (near the back of the pan).
So I took a gasket maker called "The Right Stuff" and pulled those three bolts out and put some on them and the leak is very slow but still leaking. What should I do?
Someone said the pan is warped now that I overtightened it but thats hard to believe because I straightened it and even if it wasn't perfect, that darn gasket is thick and should make up for it.
Is it just the one piece gasket or am I doing something wrong? I thought about going back to the stock gasket. Before taking it back off again I thought about getting those rails that go along the rails of the pan and the bolts hold them to the rails of the pan to make sure the pan is flush, I think Moroso makes them. Should I try this??
I definately need help, thanks a lot.
Ryan Washington
www.RyansCustoms.com
Ryan@RyansCustoms.com
Old Jun 2nd, 04, 3:23 AM
Scott_68_SS Scott_68_SS is offline
Scott
Post
I had some unstoppable leaks too with my Felpro 1pc.
Went to a SCE 1pc gasket. Summit sells them.
It has metal inserts. You'll break the bolts before you'll tweak the pan. Assuming it's straight
Well went away for a while. Went to a chasis dyno and picked one up while on the rollers. wtf
Don't think it's the pan this time. Had probs with front cover too. So just how big do the dowl holes need to be?
68 SS El Camino 454 -sold
69 RS Camaro 383 Brodix -sold
Scott L
Old Jun 2nd, 04, 3:24 AM
Scott
Post
Edit: now I hit stop before I hit post again.
Old Jun 2nd, 04, 8:07 AM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Post
We tried the Fel-pro one peice gasket once did like the way they fit and went back to the Corteco p/n 16635 they use to be called Detroit gaskets. We build a lot of engines and that seems to be the best pan gasket for us to use.
Old Jun 2nd, 04, 8:14 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Post
I went back to the conv. pan gasket, still have the Felpro 1 pc. [ sitting on the shelf ]. The 1 pc. did not fit well aroung the timing cover and just from sitting on the stand I got a drip from the hole at the bottum of the timing cover when we prelubed the motor - the 1 pc. barely covered this hole. Conv. gasket is installed, dry as a bone.
  #6
Old Jun 2nd, 04, 8:19 AM
Georgia69 Georgia69 is offline
Mike
Post
I have used the FelPro #1405 one-piece gasket on two different 350's, both with stock oil pans. Neither has ever leaked.
  #7
Old Jun 2nd, 04, 9:30 AM
ss3964spd ss3964spd is offline
Team Member
Dan
Send a message via Yahoo to ss3964spd
Post
My engine builder used the FelPro one piece on my BB and it has never leaked anywhere. I've done two cam swaps and it hasn't even leaked around the timing cover. Definitely works for me.
Dan
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
  #8
Old Jun 2nd, 04, 9:36 AM
mr 4 speed mr 4 speed is offline
Post
One piece Felpro on my BBC here..No problems.I installed it with the motor in the car too.
  #9
Old Jun 2nd, 04, 10:45 AM
Team Member
Joe
Post
Chris,
I remember you asking about this. What timing cover do you have on the motor? I had a heck of a time trying to get the Milidon replacement pan to pull up to the timing cover on mine.
  #10
Old Jun 2nd, 04, 1:04 PM
Wolfplace Wolfplace is offline
Mike
Post
Ryan,
I posted this in the engine section but here it is again.
You ain't doing anything wrong.
I have quit using the FelPro on aftermarket pans.
If you look at the bolt holes in the gasket they are too big (5/16") & on a lot of aftermarket pans the little anti crush rings will hang into the inside of the pan & oil runs right through them.
You can usually seal it by pulling the bolts that are leaking & putting either your "Right Stuff" or Silicone in the hole after brake cleaning it good & blowing it out & then putting the bolt back in.
Let it sit for a few hours before starting.
Or, I have a different 1pc gasket I use that has the right size holes (1/4") & is also less money
But even with this one I have had to seal a couple bolts with aftermarket pans on
occasion
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
  #11
Old Jun 2nd, 04, 2:09 PM
Post
Joe,I have the just a cheap chrome cover that's actually beeen good to me.
  #12
Old Jun 2nd, 04, 2:12 PM
MonteMan454 MonteMan454 is offline
Kris
Post
If possible can lay the pan on the mounting surface. If it rocks then there is something getting in the way of it fitting correctly. I used a stud set instead of a bolt set and found it to work better.
I know the frustration of leaks. Just about everything I have installed on my 70 Monte has leaked. You think you have it figured out and then you look under the car in the morning only to see drips on the newspaper!
  #13
Old Jun 3rd, 04, 6:07 AM
ac72rat ac72rat is offline
Post
NO more Milidon pans for this guy!!!!!!
  #14
Old Jun 4th, 04, 4:23 PM
young gun '71 young gun '71 is offline
Send a message via AIM to young gun '71
Post
I just add more pooky on both surfaces on everything I try to seal [img]tongue.gif[/img] about the thickness of my little finger and then let it sit bolted together and come back a few hours later tighten it about an 1/8 and trim off the excess glue a few days later. BTW I use about a half a tube of RTV on valve covers.
Chevelle Tech > General Tech Area > Performance      Current Topic: My 2nd One Piece Oil Pan Gasket is Leaking Again!??? Help!
Location
*REQUIRED*
Insurance
First Name
Human Verification
