Best fit headers - Chevelle Tech
Auto Insurance
Old Dec 12th, 07, 2:16 PM
crankitup crankitup is offline
Trey
Default Best fit headers
Have any of you used either of these two headers on a '69 chevelle with a BBC that has power stering? The 1st one is Hooker's full length with 2" primary, summit part # HOK-2455-1HKR. Or Patriots full length header with 2" primary, part # PTE-H8026-1. How is the fit? Do they have to be dimpled to fit? Can you get to the header bolts and spark plugs ok? How is the Ceramic coating holding up? I'm currently using a set of hedman's 1 3/4" ceramic coated headers. I pulled the engine last week and took a good look at the inside diamitor of the header tubs and the exhaust ports on the heads. The inside diamitor of the headers is 1 5/8" and the id of the exhaust port is 1 3/4". So the header pipe is overlaping the exhaust port about 1/8" (You were right Bob). That is why I think I should go to a 2" header. The Hooker and the Patriot headers are $370.00. The 2" hedman's are $502.00. If any of you have used these headers, I would like to hear your imput on them. Thanks, Trey
Black 69 Chevelle SS
cruiser, 468 bbc
Silver '72 chevelle
street/strip, 496 BBC
3:73 gears
Best 60' - 1.36
Best 1/4 et - 9.91
Best mph 132
All Motor
http://www.cardomain.com/ride/2518078
http://www.chevelles.com/showroom/sh...0/ppuser/19137
"And by the way, turn your hat around straight and pull up your pants. You look like an idiot".
Old Dec 12th, 07, 2:37 PM
Brettd85 Brettd85 is offline
Brett
Default Re: Best fit headers
My hooker super comps with 2" primaries fit great, unfortunately my car is lowered so the bottom are smacked up good. They did clear everything else great and you can still get to all the plugs. I will defiantly be going a different route this summer. My car is about your height, I would not go with the hooker super comps.
1968 Camino Custom
468, TKO600, 3.73:1
Pic of Car: http://i52.photobucket.com/albums/g3...5/DSCN0827.jpg
Pic of 468:http://i52.photobucket.com/albums/g3...5/IMG_0233.jpg
1966 Triple Black Chevelle
327, TKO600, EFI, 4.11:1
Pic of Car: http://i52.photobucket.com/albums/g3...5/DSCN1706.jpg
Whiskey Whiskey is offline
Bill
Send a message via MSN to Whiskey
I have the 2 inch hookers in my 68. The brake proportioning valve will need to be moved. Most move it to the top of the frame rail. If your heads have raised exhaust ports they will hit the rear mounting points for the lower control arms. I solved this buy modifying a set of BB motor mounts to move the engine forward 3/8 inch.
Bill
68 Chevelle
427 w/Merlin heads
10.2 to 1 comp
Hooker headers
Art Carr 200R4 w/3500 stall
3:90 Posi
72 SS 454
Hooker Headers
400 turbo
3:31 gears
Old Dec 12th, 07, 2:42 PM
wildman926 wildman926 is offline
Team Member
Walter
Bill
I also have the same Hookers with ceramic coating and they fit perfect, but as you said, I put the brake proportioning valve on the frame rail.
I am about to put on some AFR heads in a new motor. How much are your exhaust ports raised?
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
Old Dec 16th, 07, 6:14 PM
G.Hiller G.Hiller is offline
Glenn
I have a 1969 Chevelle,after the new BBC 454 went in,I bought 8,yes 8 pair of headers.The only pair that was a direct fit,with absolutely no problems were Hedman..They have a beautiful finish,Nice thick flanges..I have had them off and on several times with Percy's "dead soft" gaskets...use them forever,never a leak...and if you ever have to change the starter or take out the tranny it's a snap...Just my opinion,but they look great under the hood,going on 3 years now...
Big Block Power....,Imports for breakfast,Mustangs for lunch.
  #6
Old Dec 18th, 07, 4:34 PM
Bill
Wildman, I am not sure how high they were but they are Merlins if that helps.
Bill
68 Chevelle
427 w/Merlin heads
10.2 to 1 comp
Hooker headers
3:90 Posi
72 SS 454
Hooker Headers
400 turbo
3:31 gears
Chevelle Tech > General Tech Area > Performance      Current Topic: Best fit headers
Human Verification
