How do I get 550-600 HP from my 454 - Chevelle Tech
Auto Insurance
Old Dec 9th, 07, 11:06 PM
tntt1955 tntt1955 is offline
greg
Default How do I get 550-600 HP from my 454
I have 2 sets of heads. some 781s with stage one porting work done on them. .219/.188. also have some .118 rectangular port heads. (.219/.188)
454 Motor.
561/561 lift cam.
11.1 Dome Pistons
850 Carb
RPM Performer Intake
371 Gears/ 10 bolt
400 Trans
'74 Nova- 3400 lbs.
Would like to get it in the mid to low 10s. any help would be great!
Old Dec 10th, 07, 12:13 AM
Junkyard Dawg Junkyard Dawg is offline
Dave
Default Re: How do I get 550-600 HP from my 454
Might be out of the question but if you'd stroke that 454 to a 496 I'm sure 550 hp would come easy.
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Old Dec 10th, 07, 12:16 AM
Rmchevelle Rmchevelle is offline
Rod
Post Re: How do I get 550-600 HP from my 454
http://www.chevelles.com/forums/showthread.php?t=198499
Old Dec 10th, 07, 12:56 PM
firestone13914 firestone13914 is offline
Adam
The link above is a good one. As far as my experience, below is a combo a friend of mine had built and dynoed.
461
cleaned up 2.19 1.88 valve 049's (flowed 290 max)
port matched victor Jr
242 248 @.050 .600 lift hyd roller
9.5:1 compression
950 carb
dynoed at 560 hp at 6100 RPM and 560 ft lbs.
I would go with the oval heads without any doubt. I beleive that they will make more average hp and probably more peak power also. The motor looks like it should do well but may not be quite 550 with the size of your cam. I think you would need something a little bigger. I guess your duration at .050 is somewhere is the high 230's to low 240's based on the lift. To get the hp you are after, I would look at something in the low to mid 250's @.050 duration and .600-.650 lift and a 3500-4000 stall being that you have 11:1 compression. One other thing to think about, 11:1 seems a little high for iron heads. Can you give the rest of the specs on your cam?
Another thing, even with the larger cam which might put you around 575 hp, I dont think that will be enough to get you the ET you are after by its self. The ET calculator below should give you an idea of what you need to get a mid to low 10.
Assuming 3400 lbs with the driver, in order to get a mid 10, you would need around 575 at the wheels. If you assume a 20% loss to the wheels, you would be looking at needing ~720 hp at the motor. As for a 10 flat, you would need around 675 at the wheels which would be around 850 at the motor. All this assumes that the car hooks and the chassis performs well. It takes a lot to get a mid to low 10.
I would guess that your motor would probably be in the ~530 range with the oval heads and the cam you currently have. This would be around 425 at the wheels assuming a 20% loss which comes out to a ~11.7 in the 1/4. If you went with the larger cam, 575 at the motor would be ~460 at the wheels and ~11.4 in the 1/4.
You could always run a 150 shot on the motor. That may get you closer to what you are after.
ET calculator
http://www.race-cars.net/calculators/et_calculator.html
Adam
Old Dec 11th, 07, 4:56 PM
greg
I pull my heads they are 3856206 and I have flat top piston also one of my push rod was broken about one and half in. missing was not in the valley of the motor . if I put 990 heads on flat top pistons 30 over what would my comp/rato be cam 561/561 also what would hp be.
  #6
Old Dec 11th, 07, 6:05 PM
Adam
I can only assume that the chamber is 118cc. Using the calculator below with a .045 quench, you would be at around 8.0:1. This would really not be a good combo. The low compression with the large runners is not a really good match. I would estimate power to be around 450 at the motor.
http://www.angelfire.com/fl/procrastination/motor.html
Adam
  #7
Old Dec 12th, 07, 9:29 AM
ss3964spd ss3964spd is offline
Team Member
Dan
Send a message via Yahoo to ss3964spd
Greg,
the -206 heads are '65 to very early '66 heads and the chambers should be around 96 CC's - give or take. From what I've read here they are decent heads and work pretty well on a flat top 454.
Dan
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
  #8
Old Dec 12th, 07, 9:46 AM
mr 4 speed mr 4 speed is offline
Compression will be low,but it will still perform.
Have a friend with a 68 GTO powered by a 468 BBC with 990's and flat tops
He used a Chet Herbert solid roller and was running mid to high 11's w/slicks (he ran low 12's on street tires)
It was a budget motor.Most expensive parts where the 990's (bought used for $600) and the solid roller/lifters/springs (bought used for $200)
  #9
Old Dec 12th, 07, 4:53 PM
greg
thanks, i know its going to be hard.
  #10
Old Dec 12th, 07, 5:00 PM
greg
new strategy, Im going to put that flat top motor back together and use it in my 70 Monte Carlo as a street driver only, nothing hot. However i do have a 454 LS5 that came out of a 70 impala or monte carlo, the numbers are
heads: 3964290 (GMT5) (11-5-9)/ 3964290 (H89) (GM8T)
intake: 3855287
front of motor: TO929CGV (10D116942)
Im not trying to make a numbers matching car. The motor is standard bore, I could build this motor and use the 990 heads on it, but i would hate to use a good motor for what i am doing.
  #11
Old Dec 13th, 07, 2:15 AM
Sandy Sandy is offline
Adam,
I would love to have the horsepower and torque your friends combo provides.
The main difference between your friends combo and mine is the cam and a half point of compression. My engine is a real dog. While the ET is not too bad, it is pretty bad for a 2950 pound car (with driver).
More evidence that a bigger cam is not necessarily the answer to more power.
1966 Beaumont SD
hydraulic roller 468 12.22 at 109
1970 Nova
solid roller 461 11.49 at 119
  #12
Old Dec 13th, 07, 12:40 PM
Adam
Sandy, I assume you are talking about the Beaumont. What are you running for a rear gear, converter and exhaust? Dont feel too bad, I am having trouble with my combo also. I have a 9.5:1 496 with fully ported 2.19 1.88 valve 049 heads and a 248 254 @.050 .600 lift solid flat tappet cam in a 1972 ventura that probably weighs around 3500-3600 lbs that is most likely no faster than your beaumont. (It ran a 7.98 in the 1/8th mile which is probably around a 12.5 in the 1/4) I am just trying to get the bugs worked out now.
Adam
  #13
Old Dec 13th, 07, 12:56 PM
Yelcamino Yelcamino is offline
Herb
Do what I did
Dyno proven: 619hp @ 6200 rpm, 570 lb/ft @ 4800 rpm
468 cid, 4 bolt main
AFR 305 heads (as cast)
Edelbrock Victor Jr. intake
QFT 850 cfm carb
Comp hyd. roller cam (.612 lift, 244* @ .050)
Schubeck Roller X lifters (65 grams each)
Jesel shaft rockers
Jesel pushrods
SRP forged pistons w/ ceramic coated tops and DFL coated skirts (10.2:1 CR)
Total Seal rings
Scat Pro Comp 4340 light weight crank
Scat 6.385" H beam rods
ARP main, head, and oil pan studs
MSD e-curve distributor (timing set at 39* total)
6A ignition box
Blaster 3 coil
MSD 8.5mm Super Conductor wires
Denso plugs
Stahl custom stepped headers (2 to 2.25 primary pipes, 3.5 collectors)
3.5" exhaust w/ Dr. Gas X crossover and Spin Tech mufflers
Herb
ridetech Shock Specialist
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
  #14
Old Dec 14th, 07, 10:04 PM
Adam,
No I was referring to the engine in my lightweight race Chevy II.
I am pretty happy with the Beaumont. Three inch exhaust system, but just short pipes from the headers back to mufflers and then down dumps. Resonates like crazy in the car, need to do the extension over the back axles and dump them out at the rear corners like the stock ones. 4.1 gears and 2400 converter. 10.0 compression with hydraulic flat tappet and stock rockers. Like your car it weighs in around 3560 with me in it and a half tank gas. Using the TCI race calculator I calculate 360 horsepower to generate 12.4 at 109 in a 3550 pound car.
The engine I was referring to in my post above was the 454 in my Chevy II. The TCI calculator shows 440 hp. So 80 hp more and 600 pounds less I guess this is what you get (10.8 @ 124). But 440 hp is not even 1 hp per cube!
Herb, you got the 620 hp I could use! The main difference is my GM iron 049 heads vs your AFR 305's. My cam is just a bit bigger too which is probably not a good thing.
Herb, with 620 hp and 3600 pounds you should run 10.4 at 130 if you can hook it and make your shifts.
1966 Beaumont SD
1970 Nova
  #15
Old Dec 14th, 07, 10:27 PM
69-CHVL 69-CHVL is offline
Vinny Vince
Originally Posted by 66ChevElcamino View Post
Do what I did
QFT 850 cfm carb
Jesel shaft rockers
Jesel pushrods
Total Seal rings
6A ignition box
Blaster 3 coil
Denso plugs
Herb, how's the driveability w/that cam? Any vaccum @ idle #'s? Idle rpms?
*69 CHEVELLE SS EFI 502/T56 Mag/3.90
*06 C6 LS2/T56
*96 Stang LQ9 6.0 turbo - everybody should have one!
Chevelle Tech > Mechanical > Engine      Current Topic: How do I get 550-600 HP from my 454
Location
*REQUIRED*
Insurance
First Name
Human Verification
