Powerglide Modulator Vacuum Line - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Dec 7th, 07, 8:43 PM
boboh1 boboh1 is offline
Robert
Question Powerglide Modulator Vacuum Line
Where is the modulator vacuum line usually connected on the intake manifold? The guy I got my 1964 Chevelle from had it connected to the carburetor but I am sure this is not the proper location. He did not have a choke and hooked it to where the choke pulloff vacuum line normally is hooked up to. Will this work or should I move it somewhere else? Thanks.,
Old Dec 7th, 07, 8:47 PM
2cool 2cool is offline
Ace Ventura
Default Re: Powerglide Modulator Vacuum Line
It should be on a vacuum tree on the intake.
Old Dec 7th, 07, 8:54 PM
Robert
There is no T on this intake as maybe the guy closed it up with a bolt or something. I'll have to check closely. There is a large line coming out of the carburetor base that is used for the brake booster. Where would I get a fitting for the intake vacuum?
Old Dec 7th, 07, 9:44 PM
kivaka kivaka is offline
David
Send a message via AIM to kivaka Send a message via Yahoo to kivaka Send a message via Skype™ to kivaka
i have a powerglide book at home i can look it up and post here after i find it, i also have a 64 with a powerglide but i dont have any vacuum lines on mine, i use have the lines that run to the cooler
64,4dr,350,.30, 650 edelbrock, torker ll.
PG, 10bolt 3.55posi, Flow Tech headers 1 3/4.
2 1/2in Flex-pipes, 2 1/2in H-pipe,
46in 2 1/2in srait pipes,
2 1/2in Magnaflows dumped behind rear tires
Team Member#4268
ACES#8244
http://www.kivaka.com/chevelle.html
http://www.dirtypistol.com
Old Dec 10th, 07, 12:21 PM
Robert
Which method do you feel is best? Hooking it up to the carburetor or directly to the intake manifold? Thanks.
  #6
Old Dec 10th, 07, 7:38 PM
Ace Ventura
It depends, if you have a big port at the base of the back of the carb that will be ok, you can't use one of the small ports around the enrichment screws.
Edit:
Or you shouldn't but if you only have one and it goes to the valve cover then use those.
That line tells the tranny when to upshift you can tell if it's not right.
  #7
Old Dec 10th, 07, 7:52 PM
Robert
The guy I bought it from had it hooked to one of the small carburetor ports. He blocked off the intake port with a bolt for some reason. I was just wondering if the vacuum is the same at what ever location it is hooked to. I was going to hook it the correct way to the intake but then I'll have an extra port on the carburetor since I converted it to electric choke and no longer need the choke pull-off vacuum.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Powerglide Modulator Vacuum Line
Human Verification
