Length and height at a 45 degree angle - Chevelle Tech
Auto Insurance
Bench Racing Stories, cruising and more.
Old Dec 5th, 07, 6:42 PM
rubadub rubadub is online now
Rob
Default Length and height at a 45 degree angle
I'm working on an airline drawing, need some quick help, please.
If you take a 24' x 24' garage, and run an airline up the wall at 45 degrees and then down again at 45 degrees.
How long would it extend out before it hit the floor and ceiling.
Now we'll assume the garage is longer and has 8 and 9 and 10 and 11 and 12 and 13 and 14 foot high ceilings.
Plus how long is the total length of the pipe in each case.
thanks in advance.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old Dec 5th, 07, 6:56 PM
chevelledude71 chevelledude71 is offline
Wally
Send a message via Yahoo to chevelledude71
Default Re: Length and height at a 45 degree angle
Originally Posted by Andy69 View Post
OK, using the formula c= SQRT[a^2+b^2] where C = your pipe length, a = h, b = 12
for h = 9 feet, C = 15 ft
for h = 10, C = 15.6
for h = 11, C = 16.3
for h = 12, C = 17
for h = 13, C = 17.7
for h = 14, C = 18.4
all numbers rounded to the nearest 0.1
I was getting ready to say the same thing.
Old Dec 5th, 07, 6:58 PM
depley depley is offline
DeWayne
8 foot wall 19.31 feet
9 foot wall 21.73 feet
10 foot wall 24.41 feet
11 foot wall 26.56 feet
12 foot wall 28.97 feet
13 foot wall 31.38 feet
14 foot wall 33.80 feet
Acworth, GA
Peach State Chevelles
Aces Member # 08262
72 Sport Sedan
72 GMC Sprint
1966_L78 1966_L78 is offline
Tony
thanks in advance.
Rob
At 45 degree angle, the height of the ceiling with be the same as the horizontal run... since going up and back down, the horizontal run will be roughly twice the wall height...
extend out:
~16 feet long for 8 foot ceilings
~18 feet long for 9 foot ceilings
~20 feet long for 10 foot ceilings
~24 feet long for 12foot ceilings
etc
Actually be a little shorter, to account for the diameter of the pipe, etc...
Length of pipe (again, using the 45 degree angle requested) So I used
Length = 2 X (sqrt(wh^2 + wh^2)),
wh= wall height:
~22.6 ft for 8 foot ceilings.
~28.3 ft for 10 foot ceilings.
~34 ft for 12 foot ceilings.
etc
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Old Dec 5th, 07, 7:10 PM
Tony
I'll bet now you are soooooo glad you asked, eh Rob?
Just remember, Measure once, cut twice...
Then swear a bit and go back to the store for more materials...
TC #1366
'66 SS L78
  #6
Old Dec 5th, 07, 7:20 PM
Rob
You guys are to smart for me this is going to take me a while to figure this out. EEEYAAAAAAAAAAAAAAAAAAHHH!
Rob
  #7
Old Dec 5th, 07, 7:35 PM
Rob
Is there anyway to get a sketch of this, then I could copy it and add it to the drawing, then put it on my web site?
Also, do they make 3/4'' pipe in different angles so I could get a little more length, I wouldn't have as much down slope but I want to try and get close to 50' at possible for cooling.
I know I can't get 50' but the pipe has the return run.
Also if a guy went around an inside or outside corner, he could get the length?
  #8
Old Dec 5th, 07, 8:23 PM
Ark68SS Ark68SS is offline
Team Member
Steamy
BillL
Well you know there's such a lot of good ways to be bad.
If you keep on livin', you're gonna get old.
Remember: Don't make old folks mad.
We don't like being old in the first place, so it doesn't take much to piss us off.
My Showroom
http://www.chevelles.com/showroom/sh...0/ppuser/15214
  #9
Old Dec 5th, 07, 9:14 PM
Rob
Originally Posted by Ark68SS View Post
BillL
roflmao
Rob
  #10
Old Dec 5th, 07, 9:31 PM
webfoot webfoot is offline
Jeremy
So let me make sure I understand this, you have an 8' x 12' wall, and the air line is going from the corner up at a 45 degree angle to the ceiling?
I'm out of trig for a long time now but this seems like basic pythagorean theorem to me. You have to right triangles to figure out. Andy69 posted the formula, it is a squared plus b squared = c squared, where c is your "hypotenuse", or in your case, your air line.
|/\| is this about right? Well you have 2 right triangles to figure out the length of the hypotenuse to. Each has a base of 12 feet and a height of 8 feet. 8 squared plus 12 squared is 208. The square root of 208 is 14.422, so with an 8 foot ceiling you would need 28.844 feet of pipe.
With 9 feet ceilings you need 30 feet total. I see I agree with andy's calculations.
Jeremy
70 Chevelle
383, AFR heads, voodoo hyd roller.
Best time 8.09 @ 88.49 MPH (1/8 mi.)
68 GTO 'vert factory 4-sp, rally gauges, hidden headlights
  #11
Old Dec 5th, 07, 9:54 PM
Rob
Heres the finished product, I'll have to figure out some way to add the lenghts you kind gentlemen gave me, but I'll post it like this for now on the body forums, thanks again men.
http://www.1969supersport.com/draw1.html
Rob
  #12
Old Dec 6th, 07, 1:34 AM
BtrBilt BtrBilt is offline
Mark
To keep the angle at 45 degrees, the length and height have to be equal.
A sq + B sq = C sq
A= Ht
B= Lt
C= Pipe
8' Ceiling is 8 sqared + 8 sqared = 11' - 3 3/4"
9' = 12' -8 3/4"
10' = 14' -1 11/16"
11' = 15' -6 11/16"
12' = 16' -11 5/8"
13' = 17' -8 5/16"
14' = 19' -9 9/16"
With those ceiling hts the pipe would be tight to the floor and the ceiling at 45 deg. Those would be maximun lenths if you kept the angle 45 deg. Each pipe length would be one side of the 45 deg angle.
So total wall space for each ceiling ht. would be twice the wall ht.
For 8' ceiling, wall space would be 16'
For 9' it would be 18' and so on.
Hope that makes sence.
Mark
  #13
Old Dec 6th, 07, 1:37 AM
Mark
A sq + B sq = C sq
A= Ht
B= Lt
C= Pipe
9' = 12' -8 3/4"
10' = 14' -1 11/16"
11' = 15' -6 11/16"
12' = 16' -11 5/8"
13' = 17' -8 5/16"
14' = 19' -9 9/16"
Mark
  #14
Old Dec 6th, 07, 7:59 AM
barnyard68 barnyard68 is offline
Allen
awwwww heck, just use 90's and make it easy on yourself..
Catch a sunrise now and again, its good for the soul
Allen
  #15
Old Dec 6th, 07, 9:52 AM
onovakind67 onovakind67 is online now
The only way it will go 45° up to the center and 45° down is if the wall is 24' high. All shorter cases will require a horizontal length of pipe in the center if the angle is 45°.
If you want the pipe to angle towards the upper center of the wall then down, it won't be a 45° angle.
You may not post new threads
You may not post replies
