How good is Sheet Metal Adhesive - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Dec 3rd, 07, 6:42 PM
drklynoon drklynoon is offline
nathan
Default How good is Sheet Metal Adhesive
I just bought two tubes of the heavy sheetmetal adhesive from 3M Duramix 4179 Large Metal Panel Adhesive. I was wondering if any of you have used this stuff and how has it held up and how was it to work with? I'm seriously considering putting my rear quarter skins on with this stuff. I have had serious problems with warpage on large panels before and I have tried most of the tricks but if this stuff works it will seriously reduce my prep time and the amount of plastic in the car.
Nathan 67 402
Old Dec 3rd, 07, 8:59 PM
chevy_man67 chevy_man67 is offline
john
Default Re: How good is Sheet Metal Adhesive
hey whats up i have used the metal fusors lord fusor brand it works pretty good make sure the area your doing is real clean use klecos or screws to hold the panel tight
i usualy flange the panel and leave a small space at the top of the flange dont use it to blend in your work it will read through use a razor blade to trim up what ever sueezes out if youve never used it try a little on a test panel let me know how it worked
Old Dec 3rd, 07, 9:06 PM
Art Art is offline
Art
I used the 3M Automix 8115 panel adhesive on a door skin, both quarters, and the roof skin. They've been on 2 years now with out any problems. I used it on the long straigh bonds and welded the high stress corners though. Be sure to follow the directions to the letter.
Old Dec 3rd, 07, 9:21 PM
69ssmike 69ssmike is offline
Mike
I've seen a demo on this product, they glued 2 panels together and pulled them apart, the metal tore before the glue failed.
Old Dec 3rd, 07, 9:31 PM
micky69396 micky69396 is offline
Micky
Good stuff, we use it. As Mike said, metal will tear before the glue breaks.
Micky Hale
68 Biscayne 427/425 M-22
ACES #134
Warlock Racing AA/GS
www.mickyhale.com
https://www.facebook.com/pages/North...111066?sk=wall
  #6
Old Dec 3rd, 07, 10:02 PM
Rmchevelle Rmchevelle is offline
Rod
Exclamation Re: How good is Sheet Metal Adhesive
Member "MartinSr" did an experiment here: http://www.chevelles.com/forums/showthread.php?t=177043
  #7
Old Dec 3rd, 07, 10:26 PM
nathan
Awesome guys these are the kinds of answers I was hopeing for. I am an airplane mechanic and have been using all kinds of sealants for years but I just heard about this stuff. I think I'm sold on it Thanks for the imput.
Nathan 67 402
  #8
Old Dec 3rd, 07, 11:51 PM
nathan
I have a second question about this adhesive when doing a rear quarter panel I see no other choice than to use tech screws to hold it in place. What do you guys do with the screw holes left after you pull the screws? I don't know if you can weld them up because of the adhesive and that would kinda be counter productive anyway. denting the holes and filling them would work but it would cause a bunch of unnecessary work. Can you use the adhesive to fill the holes without the hole showing up in your paint a year later?
Nathan 67 402
  #9
Old Dec 4th, 07, 12:01 AM
70 SS LS-5 70 SS LS-5 is offline
Banned
Mike
Nathan,
I used both the 3M 8115 glue and regular spot welds on my quarter panel and the glue is amazing. I glued the rocker area, wheelwell, the outside of the door jamb and the trunk drip rail; basically everywhere you can't get a spot welder into. The rest I spot welded. The only problem is clamping the rocker area, so I put 3 self tapping screws through the quarter on the inside, down into the rocker, to not only keep it aligned but to clamp it down. After the glue dried I removed the screws, squirted sealer into the holes and reinstalled them.
Have no fear using the glue, it's great stuff.
Mike
  #10
Old Dec 4th, 07, 1:25 AM
sevt_chevelle sevt_chevelle is offline
Eric
Just so you know that bonding a panel down a visible seem can lead to faint ghost lines to appear due to the different expand/contract rates.
Although panel bond is a great tool but with very tool requires knowledge and caution to its limits.
Filling the hole left behind from the screw with adhesive is a great way to see that hole later down the road. The best route Ive seen is to forget the adhesive and just use stranded body filler instead like marglass to cover the holes.
Also IMO the duramix is one of the best on the market, great product. You might want to to adventure over to the Lord Fusor website as they has some great info on panel bonding and also some great info on prepping the panels and how to lessen the effects of ghost lines.
Panel bond is not a replacement for welding in all situations...Eric
Currently working on How to videos and replacement sheetmetal panels
1970 chevelle getting Sliced and Diced Anything But STOCK
1970 chevelle SS455 not a typo its a BUICK BABY
1949 and 1972 chevy trucks
Pictures of my work
http://s969.photobucket.com/home/sev...elle/allalbums
http://community.webshots.com/user/sevt_chevelle
  #11
Old Dec 4th, 07, 12:53 PM
keg69ss keg69ss is offline
kirk
i've used the lord fusor brand ,great stuff. i'd still throw couple welds here and there . for peace of mind.
  #12
Old Dec 4th, 07, 6:44 PM
nathan
Hmmm so you'd use Marglass I didn't know they even still made that stuff. Would you knock the area down first before using the tiger hair? I'll take a look at that site. I'm planing on running my quarter skin down my body line so I don't want some contracting rates cracking my body work but other than that I'm prtty secure in my decision to use this product.
Nathan 67 402
  #13
Old Dec 4th, 07, 6:57 PM
Eric
No I would not knock the area down prior to filler.
I would also not have my cut line right on the body line. The different expand rates is the nature of the beast which is why no glue manufacture suggests having a visible seem like that.
Pictures of my work
  #14
Old Dec 4th, 07, 10:23 PM
nathan
I read through that site thanks for telling me about it. I'm wondering why you would not use a body line to hide a replaced panel. In the past this the way I was taught but I'm willing to learn. I'm trying to catch up on the way things are done now and this is one step for me. Lord fusor site said to use a fiber filler to keep ghost lines from showing does this actually work? I was planning on flanging were the panel would over lap. What do you think? Should I change my plans I haven't started working on this yet I still have plaenty do do before I get here but I have already purchased the quarter skins.
Nathan 67 402
  #15
Old Dec 4th, 07, 10:45 PM
Eric
I wouldnt use the bodyline as a cutline because you just removed your bodyline and now have to rebuild it, why not leave it alone and be ahead in the game?
I dont remeber the reason why fusor gives for the fiber filler(marglass, everglass) and why it says it cuts down the ghost lines. But for filling the holes and using adhesive, that adhesive will contract and expanded differently and that hole will show up like a sore thumb, been there done that. A 1/8 screw hole for marglass to fill is nothing and doesnt show that hole.
Personally I dont like to flange anything because flanging changes the shape of a panel. A flange will straighten out a curved panel.
I would bond the quarter just like fusor shows on the website. Bond a 2" strip to the existing quarter panel first and allow that to set up and cure. Then come back and bond the new quarter panel to that strip.
In my experiences just bonding the new to the old WILL show a line when going down that amount of metal distance wise. Bonding a short section of metal like a pickup cab corner is a different story.
Bonding like fusor shows using the bonding strip Ive noticed better results, you can still see a very small faint line but not the stand out LINE that shows when using just a regular lap joint...Eric
P.S another thing that fusor stressly very highly is tapering the edges of the metal. The reps say this is one of biggest things you can do to help cut down the ghost lines, so taper your edges at like 30 degrees.
Pictures of my work
Chevelle Tech > General Tech Area > Body Shop      Current Topic: How good is Sheet Metal Adhesive
Location
*REQUIRED*
Insurance
First Name
Human Verification
