interesting procomp heads dyno test - Chevelle Tech
Auto Insurance
Old Nov 27th, 07, 1:20 AM
baddbob71 baddbob71 is offline
Default interesting procomp heads dyno test
http://www.boatstoreonline.com/procomp.html
Old Nov 27th, 07, 2:17 AM
Chief fat nutz Chief fat nutz is offline
Mike
Default Re: interesting procomp heads dyno test
Very interesting,makes me not want to look into those heads for a future budget build up.
1972 Chevelle Malibu
http://www.youtube.com/watch?v=RpeC6DhYkj0
Old Nov 27th, 07, 3:39 AM
mod since about forever, old now :)
TerribleTom II
good story, couple problems.
Cast iron exhaust manifolds are killing HP on all heads
"600 BG carbs flows 900" I doubt it. The jet sizes they give wouldn't work with a 900 anyway. Aroma of fish here.
A lot of people were already calling the Procomp heads cheap China junk already, no surprises here. Looks to me like boatstoreonline isn't much better.
Tom
Old Nov 27th, 07, 8:29 AM
Busted Knuckles Busted Knuckles is offline
I checked 'em out, big and small block.
Big block heads I looked over are thin, lightweight castings with inferior valve seats (thin) and poor core shift on the castings. Smallblocks would have taken hours just to clear the casting slag in the ports, hands-down the worst castings I've ever seen.
Junk, just like the boatstore said.
Gary Adrian
FCS Harmony Racing
'Cause if they catch you in the back seat trying to pick her locks,
They're gonna send you back to mother in a cardboard box...
You better run!
Old Nov 27th, 07, 9:17 AM
wildman926 wildman926 is offline
Team Member
Walter
I am so glad that I did not stay my usual, hard headed self and tried to make the BBC pair that I had work. I sold them and picked up a set of AFR 305's with 114cc CNC chambers from Wolfplace, among many other things. Thanks Mike!!
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
  #6
Old Nov 27th, 07, 10:17 AM
CNC BLOCKS N/E CNC BLOCKS N/E is online now
Now thats quite a cam We stepped the cam up to 503/510 224/230 @.005 as I hope thats a type O.
The BSFC numbers don't look right either.
  #7
Old Nov 27th, 07, 10:44 AM
jbird jbird is offline
wannabe
For a small block boat engine that doesn't sound too out of place to me? Especially shooting for 400hp with 383 cubes.
Jay Campbell
Campbell Competition Motorsports
  #8
Old Nov 27th, 07, 10:49 AM
224/230 at 5 thousands seems out of place to me as I wonder what it is at .050
  #9
Old Nov 27th, 07, 11:51 AM
TerribleTom II
probably just a typo.
Tom
  #10
Old Nov 27th, 07, 10:48 PM
DragRacer DragRacer is offline
Jason
Anybody notice the numbers between the Vortec head and the IK180.
For the money, I believe I'd spend and hour or two on the Flowbench with the Vortecs and put a fresh valve job on them and let 'em rip.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3555 lbs
1.40 - 60', 6.18 @ 116.7 MPH - 1/8th
  #11
Old Nov 28th, 07, 1:27 AM
hutchenc hutchenc is offline
Chad
That's exactly what I was thinking. Especially since they said the pushrods were incorrect on the Vortecs and they were using stamped steel rockers instead of rollers.
In Brodix's defense...I'm sure if they were turning more than 6000 RPM the differences between the Vortecs and IK180's would be quite a bit bigger though. Still, kinda makes you wonder.
  #12
Old Nov 28th, 07, 3:16 AM
Camaro_fever68 Camaro_fever68 is offline
Ray
And to think I almost bought a set of Procomp before I settled on the IK200's
I'm sure the .005 number was supposed to .050
Vortecs are some good flowing heads. The Brodix heads picking up 18hp over them at the same rpm is pretty good in my book. Those IK's are a cheap replacement head (IK = Iron Killer) that seems to run pretty good. And I agree, if they were turning more RPM, the IK's would walk away from them.
Building a street engine to similiar specs, one would have to consider total cost whether it would be cheaper to go with vortecs and do all the necessary mods to get a decent spring on them or a head such as the IK series. The vortec does require a specific manifold so that can't be over looked.
Ray
  #13
Old Nov 28th, 07, 1:10 PM
wannabe
I actually didn't even notice the typo. Pretty obvious it should read .050".
Jay Campbell
  #14
Old Nov 28th, 07, 4:11 PM
8sec71 8sec71 is offline
Dustin
A friend of mine has a 392" sbf in a Ranger that had World iron heads on it. They "stepped up" to the Pro Comp heads and lost 1/2 second...
They put the World heads back on and got their lost ET back and then eventually went w/ some AFR's and picked up over 1/2 sec over the World heads. Lesson learned...
Dustin Morgan
'71 Chevelle SS 454: Stock suspension, 3675lbs, 632ci BBC, N/A
1.266
5.673
121.59
8.921
150.43
VIDEOS
8.92 pass
Wheel stand
  #15
Old Nov 28th, 07, 6:03 PM
N20 GO N20 GO is offline
A good friend of mine bought a set of the pro-comp heads and bolted them on his blown 383.
The 383 had a 4340 assembly,SRP blower pistons,custom ground mech. roller blower cam,the CNC Pro-comp heads with a 215 cc port volume,2.0/1.6 valves,
pair of flowed 750 dp's on top of a 8-71 from the Blower Shop.
This engine was a max. effort for 92 pump gas.
Pull after pull with the Pro comp heads the best he could do was 588 hp.
He sold the heads and I told him to try a set of the 220 AFR heads.
He bolts them on and goes back to the dyno.
His first pull was 633 hp with no tunning.
He then say's the timing was only at 27* total and his A/F ratio was way fat.
Of course of think he is full of BS.
He then calls me back after he drops 3 jet sizes out of the front and 4 jet sizes out of the back of both carbs and then takes his timing to 33* total he also advanced the cam 4 degree's.
With all the tunning he claims it now went 662 hp.
I have never seen the dyno sheets maybe he really was telling the truth??
Chevelle Tech > General Tech Area > Performance      Current Topic: interesting procomp heads dyno test
Human Verification
