eaton 8.2 10 bolt posi c clip? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Oct 14th, 07, 9:26 PM
thricemalibu thricemalibu is offline
Default eaton 8.2 10 bolt posi c clip?
I am currently bidding this item on ebay i was wondering, hoe the whole c clip axle retainers work? will it work on my rear end? can i make it work if it's not the right part? in other words could i buy the right axles or what ever i might need?
Old Oct 15th, 07, 8:04 PM
cobaltchev67 cobaltchev67 is offline
Mike
Default Re: eaton 8.2 10 bolt posi c clip?
Yes, it will work, if you have an 8.2 10 bolt that is....I have the exact same setup....in fact I just took it apart Saturday to get my drum backing plate off for the disc brake setup. After taking the differential cover off...you take out the shear pin bolt(small, facing towards the right side of car), remove the shear pin, push one axle in and use a magnet to remove a C-clip, remove the axle, then do the same to the opposite axle....easy as it can get. Revers order to put it back in. Make sure you don't lose the lock washer for the shear pin bolt as it's very important that bolt does not come out.
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
http://s348.photobucket.com/albums/q...67%20Chevelle/
Old Oct 15th, 07, 8:37 PM
big gear head big gear head is online now
Freddie
What part are you bidding on? The posi? If you have a Chevy 8.2 it wll have c clips holding the axles in. If you are bidding on a Chevy 8.2 posi for c clip axles then it will work. Be sure to get bearings and shims with it. You will need the shims to set the backlash and bearing preload.
Old Oct 16th, 07, 12:02 AM
sweet deal guys. ok I got out bidded wich is ok because I think im just going to order a new one from summit
My question to you guys is how would I know if my car as the c clips holding in the axles? How do I find that out with out taking off the diff cover off?
If i were to get a 8.2/ 8.5 gm posi whats the differance betwen the both?
Old Oct 16th, 07, 8:09 PM
Freddie
If you have the Chevy 8.2 10 bolt then you have c clip axles. If you have the BOP 8.2 10 bolt then you don't have c clip axles. If you have the 8.5 then it could be either one. Do you know which rear end you have? Before you buy something from Summit send me an email for a price. I sell the Eaton cheaper than Summit.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: eaton 8.2 10 bolt posi c clip?
Human Verification
