Interiors Upholstery and soft trim
Old Sep 16th, 07, 4:23 PM
70 Gold Nugget 70 Gold Nugget is offline
Jeff
Default Bench to Bucket Conversion Diagram
Here is a diagram and an animated series of 7 pics of a bench to bucket conversion...all provided by member Bryan59EC...
Perhaps Bryan can give us some detail as to exactly what he done...Excellent...Thanks Bryan!!!
Old Sep 21st, 07, 12:04 AM
bluechevelless bluechevelless is offline
Danny
Send a message via AIM to bluechevelless Send a message via Yahoo to bluechevelless
Default Re: Bench to Bucket Conversion Diagram
cool i couldve used that a long time ago
1970 Chevelle SS 396 Mist Green
^^Built this car with my dad when I was 15^^
1971 Chevelle Malibu 350 4 door Sandlewood (all original)
1973 Chevelle Malibu 350 Mint Green
1973 Chevelle SS 454 Blue
www.cardomain.com/id/3115ultima
www.g3gm.com
Old Sep 21st, 07, 12:07 AM
Wheelhop Wheelhop is offline
Team Member
Jim
Why don't I see the diagrams? All i get is two small squares with X's through them.
Old Sep 21st, 07, 12:09 AM
Team Member
Jim
Don't bother answering, I went back to it and it came up.
Damn computers!!
Old Sep 26th, 07, 10:02 PM
Bryan59EC Bryan59EC is online now
Bryan
Okay--sorry this took so long
These pics are in a 66 Elky
I am using 68 Buick GS seats
4-piece bucket seat mounting bracket kit
repro 68-72 seat tracks
68 Buick seat belts with retractors
I do not see where this would be any different for any 66-72 car
might even be applied to 64/5 with the later seats (not sure tho)
I had to scrape some sealer from under the rocker sill moulding to find an edge that could be used for a reference.
This might not be needed as both holes in the back are existing, but did come in handy for making sure the seat would be square.
The forward mounting studs are are inboard 1" from the original position, AND about 1/2" forward
It is kind of important to use the 'inside rear' hole in the floor to the outside hole in the tracks, as the seat will rub on the seat belt retractor if not moved inboard. (I have 1/2" clearance between seat & retractor.)
The existing holes are spaced at 1", so moving the seat would cause interferance.
The little solid black squares are the bracket stud locations to the seat track.
On the long inboard tracks, there is a L-shaped depression (note the blue tape "L" in the pic) that semi-mates with a stamping in the floor. This will give you a rough idea where it goes, prior to welding.
If someone might have a question---plz ask
I just ran a few sheetmetal screws here for fitting. Will be replacing the floors very soon----just got the full length floors last week and they are now being epoxyprimed. I get to pick them up when I get home from this trip.
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) looks like a car again--painted 12-12-08----YAY
  #6
Old Oct 18th, 07, 5:24 PM
FlameOut FlameOut is offline
Bill
Send a message via AIM to FlameOut
I am finally getting around to putting my bucket seat brackets in. I previously had bought http://www.ss396.com/mm5/graphics/00000009/ICC-001.jpg but ended up getting http://www.ss396.com/mm5/graphics/00000009/IBX-89K.jpg
What I wasn't sure of, are the use of the two existing bolt holes (rear/outer side). Will those still be used for the seat for mounting? It seems that is the only spot the brackets don't cover
Also, is there a way to stop the slideshow viewing of the photos in the original post? I need to study them a little better
My Mulsanne Blue 67
Some Webshot photos
CarDomain Photos
396 (402) .030" over
Edelbrock
Performer RPM Air Gap
Lunati 60203 / KB 0.180
domed pistons
Holley Street Avenger 770
Muncie M-20
12 bolt posi 3.31
  #7
Old Oct 18th, 07, 5:29 PM
Bryan
Since I have my car up on jacks, with new floor pans screwed in, I can get you a couple of better pics.
Will have to e-mail to you though.
With these brackets, the outside mounting hole on the floor will NOT be used.
(going out to get some better pic)
Bryan's toyz
  #8
Old Oct 18th, 07, 5:52 PM
Bill
My car is also up on jack stands right now. I don't quite have that drivers side pan fitted perfectly yet, but have some screws in it, and I'm trying to "persuade" the rest to fit, with my hammer. Hoping to weld it in tonight.
my email is flameout@gmail.com
My Mulsanne Blue 67
Some Webshot photos
CarDomain Photos
Edelbrock
domed pistons
Muncie M-20
12 bolt posi 3.31
  #9
Old Oct 22nd, 07, 4:20 PM
Bill
I'm finally getting around to putting in these brackets, and of course having nothing but problems. First off, my existing bolt hole is 6 3/4", but no big deal. I just added 1/2" to everything. Maybe it's my seats that are messed up? I believe they are from a 67 GTO
Biggest problem seems to be the seat is sitting lopsided. When looking if from the rear of the car, you can see a good lean inward of the back of the seat.
Lopsided seat:
Another thing I'm not clear on. Of those two existing factory holes, is the inner most one used, along with a stud or bolt, for attaching the seat? Driver seat, while sitting in the seat, it would be the two holes in the left rear of the seat)
Existing factory bolt holes:
Underside of driver seat:
My Mulsanne Blue 67
Some Webshot photos
CarDomain Photos
Edelbrock
domed pistons
Muncie M-20
12 bolt posi 3.31
  #10
Old Oct 22nd, 07, 6:07 PM
Bill
I just realized that the rounded end of the top track in above photo was welded on to the original track. Anywhere I can buy new (or used) tracks? Looked on GroundUp site but nothing for 66-67 (Plus a pair is $99!)
My Mulsanne Blue 67
Some Webshot photos
CarDomain Photos
Edelbrock
domed pistons
Muncie M-20
12 bolt posi 3.31
  #11
Old Oct 24th, 07, 4:11 AM
Bill
Would someone be able to post a pic or two of the seats of their 67 taken from outside through the rear window? (Like the one I have above)
It sure can't be right the way mine sit, leaning in toward the center of the car. Are there supposed to be spacers or something to help 'level' the seats?
(Should this be posted in it's own thread, rather than the 'sticky'?)
My Mulsanne Blue 67
Some Webshot photos
CarDomain Photos
Edelbrock
domed pistons
Muncie M-20
12 bolt posi 3.31
  #12
Old Nov 7th, 07, 12:48 PM
coles68 coles68 is offline
Bart
Wow! Along with Danny, I could have used this just two weeks ago. I ended up going a different route that cost me probably more and isn't probably as good. Dang!
Thanks Jeff! Good stuff.
  #13
Old Nov 7th, 07, 9:53 PM
Bryan
If someone needs them---I do have better pics.
Shortly after those original pics were taken, I replaced the floor in the elky, and also took new pics.
Better contrast----less rust----
You can pm me and I will get back to ya
Bryan
Bryan's toyz
  #14
Old Nov 11th, 07, 7:42 AM
Pavonda Pavonda is offline
Pete
Thanks Bryan,
This is some great stuff.
Can you send them to me pavonda@bellsouth.net
Peter Avonda
Weston Fl
772-486-1680
1968 SS396 convertible http://i218.photobucket.com/albums/c...ertible012.jpg
1968 SS396 2dr Hardtop http://i218.photobucket.com/albums/c...Chevelle44.jpg
1968 SS396 2dr Hardtop http://i218.photobucket.com/albums/c...Chevelle30.jpg
  #15
Old Nov 11th, 07, 7:17 PM
Jeff
Pavonda...right click on the images above ^ and click on 'save as'...click save...then they'll be saved to your computer...
You may not post new threads
You may not post replies
