My Holley is spewing gas. - Chevelle Tech
Auto Insurance
Old Sep 5th, 07, 8:15 PM
1971 Chevelle 1971 Chevelle is offline
Unhappy My Holley is spewing gas.
Today I hooked the pcv up in the car. I went to start it, it ran for about 2 seconds and I gave it gas and it died. Now when I turn it over gas is GUSHING out a small tube that sticks up right behind the secondaries. Its a 1 year old holley 600, single inlet, vac. secondary. I just put it on my 327 and have drove it only a couple times. Would my rear float cause this? I have never set either float since I put on the new motor, but this just seems extreme. I hope someone has an answer.
Luke
1979 Trans-Am 400/4 speed
2000 Z/28
There is a way that seems right to a man, but its end is the way to death.
Old Sep 5th, 07, 8:23 PM
oldtimr oldtimr is offline
Team Member
Tim Smith
Default Re: My Holley is spewing gas.
There's probly a piece of trash stuck in the needle and seat.
Just loosen the screw and eyeball how far down it is to the top of the needle before you unscrew it. Take it out and blow it, make sure it flops freely. Then put it back fairly close to exactly where it was. Generally they are halfway down the nut. Put the screw in tight, turn your pump on and set it.
Tim Smith
Old Sep 5th, 07, 11:21 PM
Schurkey Schurkey is offline
Gold Founding Member
First Guess: Needle 'n' seat not working properly. (just as described above)
Second Guess: O-ring on the needle 'n' seat assembly leaks. Had this happen a couple of times; no-one seems to remember that even if the needle completely seals on the seat--if the O-ring is bad the gas just bypasses the seat!
Holley does not sell o-rings separately; you either buy a needle and seat assembly; or you buy a gasket "kit". Either choice involves spending "about" 100 times the cost of an individual o-ring.
I bought a batch of Viton o-rings; I'm prepared for a lifetime's worth of O-ring issues.
Old Sep 6th, 07, 9:32 AM
Georgia69 Georgia69 is offline
Mike
One other possibility...float has a hole in it, filled up with fuel, and sank. Happened to me a few weeks ago.
Old Sep 6th, 07, 12:31 PM
sledgehammer67 sledgehammer67 is offline
Daniel
Schurkey where did you buy all these viton o-rings at?
  #6
Old Sep 6th, 07, 1:04 PM
See this thread:
http://www.chevelles.com/forums/show...t=Viton+O-ring
  #7
Old Sep 6th, 07, 1:24 PM
Daniel
Thanks Schurkey i appreciate it.
  #8
Old Sep 6th, 07, 1:30 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
I had the same problem caused by the float actually falling off. There is a pin driven into a boss inside the bowl upon which the float pivots. This pin can fall out taking the float with it causing the needle valve to be left wide open. If cleaning the needle valve doesn't work, pull the bowl off and fix whatever problem you find (bad float, float fell off, etc.).
Also, your engine has now swallowed a lot of raw fuel. I'd suggest changing the oil before starting it up again. It also wouldn't hurt to squirt a little oil into each cylinder before starting it to make up for the oil that was likely washed off the cylinder walls by all that raw fuel.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
  #9
Old Sep 6th, 07, 2:52 PM
Mike
Good point Rich. Additionally, it's probably a good idea to pull the spark plugs and spin the motor over a few times before re-installing. My engine actually locked up...a cylinder or cylinders filled up with raw fuel (which is non-compressable) preventing the motor from turning over with the starter. Fortunately, I realized what was happening and ceased trying to start the engine before it was damaged.
  #10
Old Sep 6th, 07, 6:32 PM
I took the two things out of the bowls with the screw in them and cleaned them. Still is doing the same thing. I'm about ready to smash it and go quadrajet. I've had this holley a year and im not impressed. The Q-jet on my Trans am has never been touched in 28 years and works much better. I dont know what to do.
Luke
2000 Z/28
  #11
Old Sep 6th, 07, 7:14 PM
Super Mod
Rich
TAKE THE BOWL OFF AND SEE WHAT'S GOING ON INSIDE. It's very, very likely something simple but you'll have to take the bowl off to find out.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #12
Old Sep 6th, 07, 7:34 PM
Well got it working. Now my tranny is leaking and I can't keep oil from coming out around where the valve cover bolt holes are. I need to take a deep breath. I just about had enough.
Luke
2000 Z/28
  #13
Old Sep 6th, 07, 8:09 PM
Boldly procrastrinating
TerribleTom II
Don't keep us in suspense, what did you do to fix the carb problem?
Tom
  #14
Old Sep 6th, 07, 8:58 PM
I ended up cleaning out the needle and seat. Thanks for your help guys Sorry for being impatient.
Luke
2000 Z/28
Chevelle Tech > General Tech Area > Performance      Current Topic: My Holley is spewing gas.
Human Verification
