Hard starts with Edelbrock Carb - Chevelle Tech
Auto Insurance
Old Aug 13th, 07, 11:16 AM
Jimmyhotrod Jimmyhotrod is offline
Jimmy
Default Hard starts with Edelbrock Carb
When my small block chevy motors are cold they both need very few cranks to get started, but when they get hot it takes two or even three tries. Any ideas??? Both motors run fantastic with great response.
Both motors have the exact problem and both have Edelbrock 600 carbs with electric choke.
Things I already thought of:
1. Fuel line is as far away from heat as I can get it.
2. If I start it as if it's flooded and hold the pedal to the floor and let off as soon as it fires, it'll start quicker.
Thank you for any suggestions!
Jimmy Hotrod
Drive it like you Stole it!!!
http://www.geocities.com/jimmys1971hotrod/
Old Aug 13th, 07, 11:40 AM
Jesse66Original Jesse66Original is offline
Gold Member
Default Re: Hard starts with Edelbrock Carb
I also have run a few Edelbrocks on both SB and BB's, I found out early on my GM 350 Crate that it would not start good when it was hot. I believe you may find that what happens when you shut it off hot and leave it for a while the fuel percolates (spelled wrong) out of your carb, Edelbrock mades a insulator spacer they call it for this reason, it is .0320 thick if my memory serves me correctly. Worked good for me. Let me know if you are intersted and I will dig up the PN# for you.
Jesse
My Showroom
T/C Gold 243
ACES 02344
Old Aug 13th, 07, 2:31 PM
Jimmy
Thanks Jesse. Please find the Part # for me. It's worth a try.
Jimmy Hotrod
Old Aug 13th, 07, 2:37 PM
bochnak bochnak is offline
Matt
Is this true imediately after shutting down when engine is hot/warm? Or after say 15 minutes?
Matt
70' 350/Th350 - C6 wheels
Old Aug 13th, 07, 3:00 PM
bbm bbm is offline
Team Member
Dan
I use a Holley PT# 108-70 heat shield kit.
  #6
Old Aug 13th, 07, 4:10 PM
mod since about forever, old now :)
TerribleTom II
betcha this problem goes away when the weather cools off. We get a bunch of posts similar to this every summer.
Cheap gas will often boil easier than good gas, what gas are you using?
Tom
  #7
Old Aug 13th, 07, 4:19 PM
steve70malibu steve70malibu is offline
Steve G.
There are two lessons I learned about the edelbrock carbs.
1 - use a premium fuel filter, the smallest particles cause problems!
2 - use a heat insulator/spacer, fuel boils in the bowls easily!
Steve
Steve
1970 Malibu 383 CI A/T 3.42 posi
1972 Buick GSX 455
  #8
Old Aug 13th, 07, 4:38 PM
Stikman33 Stikman33 is offline
Daniel
Used to have a similar problem on my edelbrock 1406. Reason being because the fuel actually sits inside the main body of the carb, immediately in contact with the intake almost. So some sort of heat spacer is a good investment. I used a phenolic spacer on mine that worked great.
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
  #9
Old Aug 13th, 07, 5:59 PM
Jimmy
Thanks for the ideas. I'm thinking an insulator/spacer is worth trying out. I know it's not the quality of gas, because I burn premium or better in both engines. And, the problem with starting is after the carb sits on top of the hot motor for about 15-30 minutes.
Thanks again,
Jimmy Hotrod
  #10
Old Aug 13th, 07, 10:43 PM
Gold Member
Jimmy,
The PN# is 9266 made by Edelbrock. I should have ask you what type
intake you are running. This PN# has a divider in the center which allows for use on divided-plenum Performer style manifolds, there is another PN# for the open center Insulator. These PN#'s can be found in a Jegs Book also. Hope this helps. Also it is 0.300" thick. I believe it will do the trick for you.
Jesse
My Showroom
T/C Gold 243
ACES 02344
  #11
Old Aug 13th, 07, 10:55 PM
zeke67 zeke67 is offline
I concur with what has been said. The smaller fuel volume, the aluminum casting and the close proximity to the intake of the Edelbrock cause more rapid heat soak and fuel percolation. Mine does the same thing, haven't gotten around to the heat spacer gasket yet.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
  #12
Old Sep 5th, 07, 3:31 AM
Cable Cable is offline
LSx Swap Guru
I just installed a 1406 tonight on my K5 (350) and I have to hold the pedal to the floor to get it started. It doesn't matter if it is cold or warmed up. After it is running the engine idles smooth as glass. If I turn it off, even for a second, I have to hold the pedal to the floor a crank on the starter for a few seconds before it will start.
When it was running at idle I had to set the mixture screws to 1.5 turns from the seat to get max vacuum of 16". Off idle throttle response is great, runs like a champ when running.
I had a Q-Jet on it and it ran fine except I need an electric choke because my wife can't keep it running for anything when cold. I'll buy another Q-Jet in the future, but in the meantime I need to fix this thing ASAP.
Could the electric choke or linkage cause any problems like these? Ideas?
Thanks guys.
-Cable
-'74 K5 2wd Blazer 'Ghost': 6.0 LQ4/4L80e Swap, BW S474 T6 Turbo, Custom Turbo Cam, 690/600 rwhp/tq
-'08 Trailblazer SS, Factory 400HP LS2, Daily-Driver
-'70 Chevelle Wagon (LSx Swap Project Car)
-'75 Datsun Z 'LSZ': 6.0 LQ4/4L60e Swap, 11 Sec Daily-Driver (SOLD)
-'75 Monza: Factory 350/350 Car, 5.3/Turbo Swap In-Progress
  #13
Old Sep 5th, 07, 11:49 AM
69chevelleX2 69chevelleX2 is offline
Walter N
In my opinion, i would say..Check your timing, my uncles Suburban with a 383 stroker and a edelbrock carb, had that problem too, took it to about 3 different places to get it timed right, and nothing, till i went over there and fixed the timing for him, also check your valves, make sure they are not open or closed too much.
  #14
Old Sep 5th, 07, 1:21 PM
LSx Swap Guru
Normally I would completely agree with you as a good place to start. However, I went from the Q-Jet that fired up without any problems to the Edelbrock and starting having issues in a matter of 15 mins, no other changes. The timing wasn't touched. It is set at 10* initial btw.
Thanks anyway.
-Cable
  #15
Old Sep 5th, 07, 5:48 PM
canuck canuck is offline
Mike
I had this same problem on my 79 C20 pickup. It was hard to start when it was warm and it would stumble when sitting at a intersection for more than 20 seconds. I put the thick isolator gasket from a local parts store and most of my issues have gone away. The truck does not stumble and stall anymore and the hard starting when warm have gone away. Unfortunately, until I figured this out I was monkeying with the metering rods to try and solve it now I have to take it apart again. Thank god for notes.
Chevelle Tech > Mechanical > Engine      Current Topic: Hard starts with Edelbrock Carb
Human Verification
