Rochester fuel filter - which way does it go? - Chevelle Tech
Auto Insurance
Old Jul 18th, 07, 2:05 AM
66Malibu 66Malibu is offline
Jed
Default Rochester fuel filter - which way does it go?
I've just rebuilt my 2 bbl Rochester carb and need to know which direction the in-carb filter goes. One end has a hole in the center, and the other end has a larger hole with a cone in the center, created by the hole from the other end. Anyway, is there a certain way it should be installed, or does it really matter?
Old Jul 18th, 07, 2:15 AM
Boldly procrastrinating
TerribleTom II
Default Re: Rochester fuel filter - which way does it go?
one end will be open, that end faces the fuel line. don't miss the spring that goes in first, that's what pushes the rubber or cork seal on the end of the filter up against the seat inside the fuel inlet nut.
it does matter
Tom
Old Jul 18th, 07, 8:43 AM
M.Maner M.Maner is offline
Tom he's installing a brass filter. The cone faces the incoming fuel.
Mike
Old Jul 18th, 07, 9:39 AM
TerribleTom II
I haven't seen one of those things in so long I forgot they existed.
still a spring, but there's a separate gasket that goes between the filter and inlet nut.
Tom
Old Jul 18th, 07, 1:24 PM
Jed
Thank you! I wasn't sure it even mattered, but I'll install it as you say it should be done.
  #6
Old Jul 18th, 07, 5:16 PM
66 If you look at the filter from the cone end you can see how much more surface area there is for the fuel to pass thru and that extra area also allows trash,dirt etc. to collect in that area and still be able to flow enough fuel to keep the engine happy.
Mike
  #7
Old Jul 19th, 07, 9:02 AM
Jed
Makes sense now. Thanks, Maner.
Chevelle Tech > Mechanical > Engine      Current Topic: Rochester fuel filter - which way does it go?
Location
*REQUIRED*
Insurance
First Name
Human Verification
