Rectangle vs Oval BBC heads - Chevelle Tech
Auto Insurance
Old Jun 23rd, 07, 8:25 PM
godnrob godnrob is offline
Bob
Default Rectangle vs Oval BBC heads
I built my 468 with Edelbrock RPM performer (oval ports) for a street strip application.would i have been better off with rectangle port heads
Old Jun 23rd, 07, 8:29 PM
-SS454- -SS454- is online now
Chris
Default Re: Rectangle vs Oval BBC heads
doubtful. Oval ports are great on ~454 ci engines. I really like the Brodix Race Rites, small oval port with great velocity make big power and big torque.
Old Jun 23rd, 07, 8:42 PM
30-A rider 30-A rider is offline
The best heads up rectangle vs. oval port test I have ever read about is on a sight called Maliburacing.com Its awesome, and you wont doubt for a second that oval ports are the correct choice for most anything 500cid and under that doesnt see rpm's over 6K regularly.
Old Jun 23rd, 07, 9:43 PM
69 Ratt Vette 69 Ratt Vette is offline
John
Post your combination...........
Thanks Nitrous Supply 714 373 1986
I don't have a Chevelle, but I wish I did!!
69 Corvette Stingray
454, 6 speed, 11.87 @ 124 mph (full street trim) all motor, only trip to the track
63 Corvette A-gas / Top Sportsman
Pettis Performance 565 with two stages of Nitrous Supply nitrous systems.
Bests:
1.082
4.61 / 155
7.170 at 192.6
Old Jun 23rd, 07, 9:45 PM
pdq67 pdq67 is offline
Guest
Paul
Guy's,
Please post up the link to the old "Dirty Sneakers" head rect/oval comparo for this!!
pdq67
  #6
Old Jun 25th, 07, 8:19 AM
LAUGHING RAT LAUGHING RAT is offline
I Have The Same Heads On My 460 And They Take Me As Fast As I Want To Go.
67' CHEVELLE 3700 LBS.(W/DRIVER)
460 B.B.
6.27@111.62 ON NITROUS 1/8 MILE
9.82@137.39 ON NITROUS 1/4 MILE, 6.86@100.25 MOTOR ONLY 1/8 MILE
10.81@123.69 MOTOR ONLY 1/4 MILE
1.47 - 60' .004 R/T
  #7
Old Jun 25th, 07, 8:32 AM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
http://www.maliburacing.com/patrick_budd_article.htm
  #8
Old Jun 25th, 07, 10:04 AM
firestone13914 firestone13914 is offline
Adam
This is an interesting comparason between the oval and rectangular heads. This is a really mild combo, but I think you would need to get a lot more radical (as far as cam lift) before the rectangular heads would really start to shine.
http://www.compcams.com/Community/Ar...ID=-1989283802
Adam
  #9
Old Jun 25th, 07, 10:24 AM
427L88 427L88 is offline
Gold Member
Gene
Re Bob's link: Carl (McQuillen Racing Engines) is a client of ours. It IS a compound in rural upstate NY!
FOr street cars using rects, I usually recommend going smallish on the cam to aid the intake velocities and driveability. With ovals, you can get bigger on that cam.
Bob (Godnrob) , naw, no mistake. Ya dun the right thing.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
  #10
Old Jun 25th, 07, 4:58 PM
jester1 jester1 is offline
Cant wait till 10secbu chimes in . I personally went with oval, it was hard to do the opposite that everyone else does but well worth it. Listen to the guys here they know what there talking about.
  #11
Old Jun 25th, 07, 5:07 PM
blubu blubu is offline
Larry Joe
UHHHHH NO
Not on the street it has been proven more than once that sq port show very little improvements over OP Especially on a 454 which is a grunt motor and works on torque vs hi winding. Gear it right and you dont need all the rpm as well the breakage factor which can come with hi rpm motors
blubu
  #12
Old Jun 25th, 07, 6:50 PM
Augustboy2009 Augustboy2009 is offline
I wish I had oval ports on my engine. Oh well, I guess the square ports will have to do for a while.
  #13
Old Jun 25th, 07, 8:40 PM
MM Racing MM Racing is offline
I guess it all depends on what you want to do with your ride. I have tried several different heads (including 781) and the 074 rectangle ports worked the best for me. I'm not out to be the fastest.... but I am trying to be the most consistent.
-Phil Watkins
'71 El Camino
Midnight Machine Racing
http://dragtruk.com/ENTRIES/L137ADMQNQ44.html
  #14
Old Jun 25th, 07, 9:41 PM
FOOTBRAKER FOOTBRAKER is offline
I see the old rectanuglar vs. oval port debate is still alive and well!
I state this AGAIN for those that haven't read it here or elsewhere...
it is a FACT that my 11:1 467 oval port engine combo out performs EVERY n/a 454-502 combo regardless of bore/stroke/compression/heads/cam yada, yada, yada in a similar weight Chevelle(3880 lbs.) in Division 1 brackets as well it's makes more power/runs quicker than most 540's and GM's 12:1 720HP 572 again in a Chevelle of similar weight to which most comparables are hundreds of pounds lighther.
Further this car/combo is DEADLY consistent, typically varying thousanths in 60 foot from run to run and 2-3 hundreths over the course of a full day/night of racing!
OH and it sees over 6000 "regularly" as in EVERY pass, making the 1-2 shift at 6600 and 2-3 at 6800!!
FYI, my new 522 engine that will see north of 7000 RPM regularly will also have oval port heads!
So to answer your question....
NO
  #15
Old Jun 25th, 07, 10:03 PM
joespanova joespanova is offline
Talking Re: Rectangle vs Oval BBC heads
Ed , why do ya' always have to come along and kill a thread.
71 Nova ....355, Nash 5spd.
6.01 @114 9.51 @ 140 1.30 60ft.@3000
The Nova
http://i611.photobucket.com/albums/t.../Reynolds1.jpg
The 65 Imp
http://i611.photobucket.com/albums/t...a/100_0318.jpg
Chevelle Tech > General Tech Area > Performance      Current Topic: Rectangle vs Oval BBC heads
Human Verification
