3999241 heads good or bad? - Chevelle Tech
Auto Insurance
Old Jun 13th, 07, 9:22 PM
jermbob77 jermbob77 is offline
jeremy
Default 3999241 heads good or bad?
i am looking at building my first bbc.the block is a 69 396 and the heads are 72 casting #3999241 just whant to know with the right port work are these heads a option.also any guess what the max hp and tq i can expect to get out of a 396 and drive on the street every day.faster is better.thanx jeremy
Old Jun 14th, 07, 6:51 AM
dreis454 dreis454 is offline
Dan
Default Re: 3999241 heads good or bad?
per the NHRA flow #s, they are pretty good, right there with the best of them.
I have the same heads on my LS5
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Jun 14th, 07, 11:59 AM
jeremy
thanx for the reply every one keeps telling me i cant get any power out of a 396 and its not worth changing out my 383 6" rods 195 afr heads mowtown block.
Old Jun 14th, 07, 1:50 PM
67mousehunter 67mousehunter is offline
mike
1972 402 240hp,300hp,330 hp,LS3
454 open 365 hp LS5 113.0 cc
Old Jun 14th, 07, 1:58 PM
Dan
actually the 1972 LS3 used the '2292' head.......very similar to the 241
I think the 241 was 454 only.
from what I've seen
TC#3095
  #6
Old Jun 14th, 07, 2:48 PM
jeremy
So It Sounds Like Thay Are Worth Running.i Will Start Porting Them After Work.
  #7
Old Jun 14th, 07, 11:37 PM
Rmchevelle Rmchevelle is offline
Rod
Exclamation Re: 3999241 heads good or bad?
Why are you porting them? There's already plenty of air in them for a 396. Use the search feature in this forum to see other 396 combos. Besides, if you don't have a flowbench to check your port work you could be making them worse.
  #8
Old Jun 15th, 07, 10:10 AM
smokinjoess smokinjoess is offline
Joe
from what I've seen
I have a set of the 292 heads on my 402c.i. .030 over and I've tried to find flow #'s on them so these heads are ok I take it for a 408 c.i. bbc? I have a 454 c.i. .060 over 468 c.i. that I'm putting together are the 292 heads worth swapping over to the 468?
Thanks!
  #9
Old Jun 15th, 07, 11:15 AM
Dan
I don't see why not
they are almost identical to the 241's that came on 454s
check the NHRA website for the flow#s
TC#3095
  #10
Old Jun 15th, 07, 4:12 PM
Tony66 Tony66 is offline
Thumbs up Re: 3999241 heads good or bad?
I had the 2292's on a 402 and I now have the 241's on my 454.Both heads are identical IMO.Both had mild port work done to them and I had 219-1.88 valves put inthe 241 heads.These heads perform exellent for me.If you alreadt have them I'd use them.JMHO.Tony
Chevelle Tech > General Tech Area > Performance      Current Topic: 3999241 heads good or bad?
Human Verification
