Can too much oil pressure cause problems with hydraulic lifters?? - Chevelle Tech
Auto Insurance
Old May 23rd, 07, 11:23 PM
jester605 jester605 is offline
Lightbulb Can too much oil pressure cause problems with hydraulic lifters??
Can too much oil pressure cause problems with hydraulic lifters?? Could this be causing some of my valvetrain noise??
Old May 24th, 07, 12:17 AM
LevonH LevonH is offline
Moderator
Levon
Default Re: Can too much oil pressure cause problems with hydraulic lifters??
How much oil pressure? Up to 70 is usually not a problem.
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed.
Current Engine VortecPro 460 (513 HP) Original is resting
1966 427 Corvette SOLD
1973 Camaro IHRA Hot Rod (LS-6 Auto)11.00 @121 (Chased a 10.99 or better) SOLD
Priddis, Ab. Canada
My Showroom
Old May 24th, 07, 7:23 AM
its at 70 at idle relatively cold ~up to 160 degrees
Old May 24th, 07, 9:52 AM
engineguy engineguy is offline
Bill R
High oil pressure has no affect on hydraulic lifter operation. The clearance between the lifter body and the plunger is measured in millionths of an inch. As I recall (and it's been awhile) the spec is 180 millionths and I think this equates to about 18 ten thousandths of an inch??
Anyway, the hydraulic lifter cavity is filled while the lifter is on the base circle of the cam lobe, with enough oil to move the pushrod to zero lash and then this amount of oil is contained within the cavity, due to the tight clearance between the lifter body and the plunger. You could probably have several hundred pounds of oil pressure before it would affect hydraulic lifter operation and even then it is doubtful that a problem would arise.
Bill
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (20+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
Old May 24th, 07, 4:22 PM
Boldly procrastrinating
TerribleTom II
yeah, the oil would have to act on the plunger like a hydraulic ram. the area of the plunger is a tiny fraction of a square inch. Also, you're working against the pressure of the valve spring multiplied by the rocker arm ratio.
looks like the area of the end of the plunger might be about .1 sq. in. so if you had a 100 lb valve spring x 1.5 ratio = 150lbs/sq in pressure on the pushrod. you'd be looking at 1500 lbs oil pressure to move the plunger in the lifter body. Doubt if it's going to be a big issue anytime soon.
WARNING: round numbers, estimates, possibly un-warranted assumptions, professional on a closed course, don't try this at home, IMHO, YMMV, all that jazz. but it's at least in the ball park.
Tom
  #6
Old May 24th, 07, 4:42 PM
furball8994 furball8994 is offline
Scott
Good save Tom.
Jester. Lifter noise with Hydro. lifters is usually from lack of oil in the lifter caused by low oil pressure or dirt clogging the lifter. Check your lash. It should be 0 + 1/4 turn. (someone correct me if i'm wrong on the 1/4, Its been a while since I messed with Hydro. lifters.)
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
  #7
Old May 24th, 07, 4:59 PM
TerribleTom II
I run them at 1 full turn of preload unless it's a engine used mostly for racing of some sort, then I use 1/8 to 1/4.
Tom
  #8
Old Feb 10th, 12, 11:12 AM
WurlitzBurg WurlitzBurg is offline
Tom
It seems to me there must be a spring inside the hydraulic lifter in order for it to extend fully when the valves are closed. I know that the oil pressure would do that normally but the lifter must be extended for oil to enter, correct? Or can the oil enter any time during the cycle?
Without a spring it would be difficult to set zero lash. As soon as you shut off the engine, the valve springs are going to cause oil bleed off. To set zero lash with no spring we would have to adjust the valves right after shutting the engine down. I never hear anyone saying that.
Tom
'69 SS396 4-Speed Hardtop Red/Red
http://photobucket.com/WurltzBurg
  #9
Old Feb 10th, 12, 12:09 PM
ss3964spd ss3964spd is offline
Team Member
Dan
Send a message via Yahoo to ss3964spd
Jester, some camshaft lobe profiles can also cause valve train noise.
What camshaft are you using?
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
  #10
Old Feb 10th, 12, 4:42 PM
oldcutlass oldcutlass is offline
Eric
Some roller rockers are just plain noisey also.
Your just jealous because you can't hear the voices!
1967 Olds Cutlass 468 BBC/T400
1963 Plymouth Fury 440/Torqueflite
2006 Ford Mustang GT (momma's car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
  #11
Old Feb 11th, 12, 8:10 AM
TerribleTom II
Wurlitzburg,
Yes, there's a small coil spring under the plunger. You can push it down with a finger if there's no oil in the lifter or of if it's dis-assembled. It's inconsequential in terms of the pressures generated by the spring at the rocker ratio.
Tom
  #12
Old Feb 11th, 12, 2:41 PM
Schurkey Schurkey is offline
Gold Founding Member
First guess: Excessively thick oil.
There is.
Oil "can" enter any time the oil band in the lifter is aligned with the oil supply drilling in the lifter bore. Of course, if there's more pressure in the lifter than in the oil gallery, oil isn't going to enter the lifter. That's what the check valve does--prevent high-pressure oil in the lifter from squirting back OUT.
Did you SEARCH BEFORE POSTING a new thread?
Did you post in the CORRECT FORUM?
  #13
Old Feb 11th, 12, 9:12 PM
Tom
Thanks, guys. Good info.
Tom
Chevelle Tech > General Tech Area > Performance      Current Topic: Can too much oil pressure cause problems with hydraulic lifters??
Location
*REQUIRED*
Insurance
First Name
Human Verification
