TH400 fittings for braided AN cooler lines?? - Chevelle Tech
Auto Insurance
Old May 17th, 07, 11:47 PM
Pro67Chevy Pro67Chevy is offline
Jim
Send a message via AIM to Pro67Chevy
Default TH400 fittings for braided AN cooler lines??
I have a TH400 that I want to get AN fittings for, so I can use braided line. I did a search but I am still a little fuzzy.
I bought fittings from ATI that were advertised as the ones I need, well, they don't fit my trans. They look like NPT on one end and 6 AN on the other. They don't thread into my TH400.
Guys here post that they are buying "inverted flare to AN" fittings but I don't know what size inverted flare is on the TH400 or where to buy them.
Does anyone know what the fitting size is on the TH400 or where I can get these conversion fittings?
Jim
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
"It's all in the smoke!"
Video 1 Video 2
No time slips yet, 2013!!!
Old May 18th, 07, 1:08 AM
Ron454 Ron454 is offline
Default Re: TH400 fittings for braided AN cooler lines??
I just installed the Jeg's EZ kit. I believe it came with either 3/8 or 1/4" pipe to AN fittings.
Ron
69 Nova
LS Alum 5.3 single turbo, 9.45 @ 145 so far
2000 Corvette C5 Auto LS1 10.99@124
Old May 18th, 07, 7:09 AM
fowl69 fowl69 is offline
gotta be careful with that you will split the case. Lance Wilson <wild1955@hotmail.com>
email this guy and ask him what size he just did a tb 400 with an lines
Old May 18th, 07, 10:43 AM
Jepprox Jepprox is offline
They should be 1/4" NPT to 6AN flare fittings. Just installed these into my TH400.
69 Pro Street Chevelle "No man with a good car needs to be justified."
http://www.chevelles.com/showroom/sh...0/ppuser/19836
Old May 18th, 07, 1:38 PM
Jason Snyder Jason Snyder is offline
DITTO, me too!
  #6
Old May 18th, 07, 2:58 PM
Well, you use teflon paste and don't tighten them in like crazy.
Ron
69 Nova
  #7
Old May 20th, 07, 8:51 PM
Jim
I have the 1/4 inch to -6AN fittings that ATI sold me but they don't fit. I get maybe a half thread turn. Is the trans side a "fine" thread? The fitting I have looks to be a "course" thread. Here are the pics.
I stuck the fitting in to show the size. it isn't threaded in.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
  #8
Old May 20th, 07, 9:09 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
looks like the brass fitting should screw directly into the transmission to me.
  #9
Old May 20th, 07, 9:17 PM
smittyocat smittyocat is offline
Joe
Send a message via Yahoo to smittyocat
I agree with Bob I believe that you remove the trans fitting and install the adapter directly into the trans case, the white part appears to be a seal. I would try carefully removing the line adapter from the tranny and see if it threads into the case, I think you will find this to be the correct way to install it.
Joe
1969 SS396 4spd 12 bolt Lemans Blue
1966 ElCamino custom 396 4 spd
My Homepage
  #10
Jim
i thought about that but I didn't know if the fittings in the trans just screwd out or not.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
  #11
Old May 20th, 07, 10:43 PM
mc71454 mc71454 is offline
Tom
Send a message via AIM to mc71454
You have to remove the tubing fittings from the trans, then the 1/4 NPT will screw right in.
Tom B
'71 540 Street/Strip Monte Carlo 10.310, @ 129.86, Pump Gas, Full Exhaust
'70 Chevelle, 462, 3.42's, 12.35, 1.66 60', 107.0 4020 lbs. Full exhaust Pump Gas
'87 Regal Limited Turbo T, Chip & Dual exhaust - 13.08, 1.78 60'
'75 Chevelle S3, 454, Auto (Son's Car)
'07 Tundra TRD 5.7 V8 4WD, 3" Lift
2015 Tundra TRD Pro - (On order)
  #12
Old May 21st, 07, 8:51 AM
Jim
Thanks guys. I'll check tonight. Sounds logical. I just didn't think they screwed out until now.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
  #13
Old May 21st, 07, 9:00 AM
forcd ind forcd ind is offline
the threads in the case are not npt, but a straight thread, called 1/4 something else-the easy way out is to keep the brass adapters, and use flare to #6 adapters, as used on carbs and power steering-do a search, this has been repeated many times, i have even supplied part #'s
when your credit cards are maxed, have the limits raised
Chevelle Tech > General Tech Area > Performance      Current Topic: TH400 fittings for braided AN cooler lines??
Human Verification
