Body Shop Paint & Body Forum
Old Apr 14th, 07, 11:11 PM
rubadub rubadub is offline
Rob
Default tight floor pans
I've got the bride resizing the pictures, just a fewpictures, and there not that good, but will suffice.
I'll give a good explanation on what I did, but this is for us amateurs, a regular body shop would go out of business doing it this way.
I'm thinking within a half hour, if I put some pressure on her to hurry up.
Trying to get it on before you early birds go to bed that way you guys can jump right on it in the morning
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old Apr 15th, 07, 12:01 AM
Rob
Default Re: tight floor pans
http://www.1969supersport.com/floorpn.html
Rob.
Old Apr 15th, 07, 1:20 AM
Andy69 Andy69 is offline
Ricardo Cabeza
wow RObert very nice. I was pretty proud of my work but you old timers just keep showin me up
Whoever claims the right to redistribute the wealth produced by others is claiming the right to treat human beings as chattel - Ayn Rand
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Old Apr 15th, 07, 10:35 AM
LateNight72 LateNight72 is offline
Typhoon
Send a message via AIM to LateNight72
Looks Great!
One thing I did learn, use the self-drilling screws. They will cut about 1/3 off of the time it takes to screw them all down.
Todd Sickles
1972 Chevrolet Chevelle SS
Avail 4/13/2010 -- GM '68-'72 A-Body Aluminum Solid Body Mounts
LINK
Old Apr 15th, 07, 10:56 AM
Rob
Thats a good idea Todd, especially in any area that you don't need to really draw them down. But the size drill bit and screw I used, the screw is a little bit over sized, and most of the time you have to push down pretty good with the air ratchet just to get it started.
Sometimes the screw is indenting the pan itself, but because its set in on the edge of the support, from underneath its tight and flat right next to the support.
When I did my trunk pan, I probably stripped out about 20 or so, but I used a bigger drill, then went to a bigger screw on those.
On these I stripped the threads off about a half a dozen, but because of the small hole, I didn,t need to go oversize, just a new screw.
I haven't compared the two screws, but I think a regular sheet metal screw has a deeper thread, Maybe.
Anyway, good idea you have there Todd. I never thought about it.
Rob
Rob
  #6
Old Apr 15th, 07, 11:04 AM
Rob
Andy, the difference between us old guys, and you younger guys. You have children at home to raise, usually a wife that works also, plus a job yourself. We have nothing but time, and it probably takes me ten times as long as it does you to do something.
And, anybody that looks to see how tight a floor pan is, has probably got a screw loose himself, like me.
Rob
  #7
Old Apr 15th, 07, 11:15 AM
ss396boy ss396boy is offline
Jason
What happened to pouring the epoxy in the holes and flipping the car in 360's? Guess that plan didn't work. I think you made the right choice.
69 SS396 Camino (540 FAST EFI BBC) When will it be finished...???? MoneyPIT!
http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
  #8
Old Apr 15th, 07, 11:46 AM
Rob
I'm still going to do that.
Rob
  #9
Old Apr 15th, 07, 1:01 PM
sevt_chevelle sevt_chevelle is offline
Eric
When I did my floors I used 8-32 bolts. That way the screws dont strip out and plus you can put a washer on both sides and really get em tight without denting the metal.
But then I modified some long reach vise grips, instead of being a 18in throat they are now around 38in throat. No more holes for me
Currently working on How to videos and replacement sheetmetal panels
1970 chevelle getting Sliced and Diced Anything But STOCK
1970 chevelle SS455 not a typo its a BUICK BABY
1949 and 1972 chevy trucks
Pictures of my work
http://s969.photobucket.com/home/sev...elle/allalbums
http://community.webshots.com/user/sevt_chevelle
  #10
Old Apr 15th, 07, 1:30 PM
NOTHINBUT69s NOTHINBUT69s is offline
Jim
Look great Rob, Can I ask why you went with half supports? just curious. I've been watch your project 69 for awhile now, Its looking awsome.
1969 hard top
1966 hard top
1969 SS hard top
1969 SS Convertible
"The day you think you know everything there is to know is the day you start learning"
  #11
Old Apr 15th, 07, 1:42 PM
Rob
Eric, sounds good, the bolts and extended clamps . As long as there tight to the supports, thats the name of the game.
Rob
  #12
Old Apr 15th, 07, 2:02 PM
Rob
Jim, as a rule the only part of the support that usually needs replacing is the outside, and when I did it all the rest of the support and pans were intact, I don't know if it makes a difference in keeping everything straight, not sure.
But its a toss up I guess, all new or half supports. I will spot weld everything pretty good, except the back seat support, then I will pull that full support out and redo it also.
I did the supports on my rotisserie, but first I welded four cross braces to the inside of the rockers out of square tubing, I had some pictures, see if I can find them. It really held everything together tight.
They were about 8 or 10 inches above the floor pans, with an angle brace spot welded in four places on each end to the inside of the rockers. I kept them low enough so I could roll the body over.
The body fits the chassis really nice, so I'm into the overkill mode to retain that shape.
I would like to do a half a dozen of these 69's, and I will get some help when I do it, but right now its a lot of experimental work for me, and a lot of jigs.
Then when I do the next ones, I can have somebody work with me, and it should go good.
Right now, I'm just really picky, old age and cantankerous, nobody could work with me until I get the whole program down.
I also replaced about four inches of the toe boards, and kept the factory lip, Might not be able to see it in this picture.
Anyway, My remaining braces are in really nice shape, good and solid.
I'm trying to make the underside perfect, but it just takes me so long to do it.
Once I get it all figured out, then I can really knock these babys out yeah right.
Rob
  #13
Old Apr 15th, 07, 3:59 PM
Rob
Heres the cross braces I mentioned
FLOOR PAN
[ 1 ] [ 2 ] [ 3 ]
HOME
These are supports for doing the floor pans. They are about 60" long. I welded them in between the rockers, then I could change the supports on the rotisserie. About 4 spot welds on each end and that will tighten up the whole bottom of the body. I kept them fairly low so I could rotate the body a full 360 degrees. I had pictures of them installed on the body but the bride likes this camera so she asked if she could delete them and I gave her permission to.
These are made out of 1/16 thick 1-1/4 square tubing. You can see where I ground the spot welds off when I got done.
[ 1 ] [ 2 ] [ 3 ]
HOME
  #14
Old Apr 15th, 07, 6:28 PM
Gravy_D Gravy_D is offline
Dave
Thats really nice work Rob. I wish you would have had all this info when I started my project. It would have saved me alot of time/head scratching and kicking myself in the pants for not doing something a different way.
My 1968 Convertible
383 cu.in
M-20 Muncie
  #15
Old Apr 15th, 07, 7:21 PM
Rob
Thanks Gravy, a guy wonders if anybody ever uses any of it, I've posted stuff and never got a reply, it makes you wonder.
Rob
You may not post new threads
You may not post replies
Similar Threads
New U-Joints - How Tight Should They Feel leejoy Transmission & Driveline 6 Jan 26th, 07 4:12 PM
Moser c clip brearings very tight victtor Transmission & Driveline 3 Nov 24th, 06 10:08 AM
Loose Mains and Tight Rods Brotherjoe Engine 8 May 8th, 06 12:11 AM
Wheel bearings...how tight should they be? 69boo307 Brakes, Suspension & Steering 6 Sep 16th, 03 1:12 PM
my door doesnt close properly...how do i adjust? icedog Body Shop 4 Jul 1st, 02 9:42 AM
