wiring electric fans with relay and toggle - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Mar 31st, 07, 10:56 PM
ric460 ric460 is offline
Default wiring electric fans with relay and toggle
hey guys need some help wiring electric fans in my 69 velle. i have a bosch relay, a simple toggle switch and the dual electric fans to hook up. can anyone tell me or show a diagram of how this is hooked up. Also is 1 relay enough or do i need 2? I need this as simple as possible like 30 goes to ..... 87 goes to ....85 goes to...86 goes to... thanks for all the help in advance.
Old Mar 31st, 07, 11:12 PM
undee70ss undee70ss is offline
Greg
Send a message via AIM to undee70ss
Default Re: wiring electric fans with relay and toggle
You need to use 2 relays, one for each fan. There are many ways to wire fans, you can have them come on automatically, manually or a combo of both.
Greg U
MY 70SS
Old Mar 31st, 07, 11:31 PM
thanks for the quick reply greg u seem to be the electrical guru here . i just have one more qustion then. How do i wire both relays to one toggle switch. i say they are dual fans(but they are in one plastic shroud). they have only 1 power and 1 ground wire to run both fans. So does the 2 relays still apply?
Old Apr 1st, 07, 12:13 AM
onick onick is offline
Eric
Send a message via AIM to onick
Here's how i wired my taurus dual speed fans NOTE: There is a 12V switched to the SPDT that isn't shown on the diagram.
Eric Onick
1968 Chevelle Malibu
Big Block-475ci built by Mark Jones
Tremec TKO-600 5-speed
12 bolt Eaton Posi
TC Member# 2320
Old Apr 1st, 07, 4:35 AM
Greg
Easy. Relays can be switched (turned on or off) by putting the toggle switch either on the power side (86, shown in the pic) or the ground side (85). Simply branch power after the toggle to the relays (86) or bring all the grounds from the relays to one side of toggle, the other to a good ground. Since this is the switched side of the relays, power draw is very low, like 1/8 of a amp per relay.
How much power to the fans pull? If you don't know this what make and model are the fans.
Greg U
MY 70SS
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: wiring electric fans with relay and toggle
Human Verification
Similar Threads
Help w/ relay/ toggle hookup feedphillipnow Electrical & Wiring 16 Jan 4th, 07 9:00 PM
Electric Fan Switch/ Relay feedphillipnow Electrical & Wiring 9 Oct 24th, 06 6:19 PM
Wiring electric fans with relay rednecks70 Heating & Cooling 6 Sep 26th, 06 12:09 AM
wiring toggle switch? mxracer Electrical & Wiring 4 Sep 9th, 06 10:00 PM
Blower relay wiring + other questions. 71wanna-be-ss Electrical & Wiring 1 Jun 2nd, 03 10:41 AM
