Need cooling help on Pro Street Big Block - Chevelle Tech
Auto Insurance
Heating & Cooling Heating, cooling and air conditioning
Old Mar 20th, 07, 4:05 PM
Chas67 Chas67 is offline
Default Need cooling help on Pro Street Big Block
Any help would be appreciated! I have a 496 big block with a 8-71 supercharger, 5 lbs of boost, big Be Cool Radiator, 300 series Meizere electric water pump (rated at 55 GPH), Dual electric fans, and a 160 degree thermostat. When I went out cruising, I was fairly happy with my temp not going above 205 degrees for the first 50 miles. I stopped to get a bit to eat and resumed my trip about 30-40 minutes later. Upon my return trip, the temp hovered around 225 degrees and finally got to 230. WTF! I stopped for gas and there was a bit of boil over (not much). The coolant is fresh and the system clean and purged of air. I let it cool a bit and made it home, at about 225 degrees.
Are there any thoughts out there as to a solution for this over ehating problem. Am I too paranoid about 230 degrees? Would an extra circuit for the water pump when stopped help? An alternative to the water pump that I have? Any thoughts.
496 C.I. 4-bolt main
TH400 with Coan Converter
Dyers 8-71 Supercharger
Backhalved and Tubbed
4050 lbs with driver
9.66 sec in 1/4 mile
1.33 sixty foot
139 mph
Old Mar 20th, 07, 9:00 PM
ironhead ironhead is offline
Default Re: Need cooling help on Pro Street Big Block
Is the torque converter in a constant state of slip on the street?The trans temp along with the higher engine rpm and reduced flow thru the rad core all add up to heat.It is a fine balance between street and strip.With that much motor..a tighter converter may be the solution.Food for thought only.
Old Mar 20th, 07, 10:05 PM
I do not think that the torque converter is slipping at all in this aplication (3000 stall Coan set up for the blower), but I did not think about trans temp. No problems with it over the whole cruise.
Thanks for the thoughts.
1.33 sixty foot
139 mph
Old Mar 22nd, 07, 7:38 AM
ALUMITECH REPRODUCTIONS ALUMITECH REPRODUCTIONS is offline
you may want to chang your timing ....the boost dosent seem to high ... as for the 160 t/stat its useless after 160 just stays open .. in effect this tells you your cooling system is not enough to modulate the t/stat .. put in a 180
this may help with the issue of time coolant cycles trough the rad ...to get cooled down before heading back to the block ...what cfm are your fans ? .
and lastly .. with electric w/p its a good idea to cycle the w/p and fans when you stop the engine to cool things down and avoid heat soak .
Don
Old Mar 22nd, 07, 10:31 AM
Thanks for the thoughts Don. I have two 1200 CFM fans without a shroud that takes up most of the face of the radiator. I just ordered a dual set up that has a buit in shroud and flows 2800 cfm. I will be installing that this weekend. I will also try a 180 degree thermostat at the same time and see how this Sunday pans out.
How difficult would it be to cycle the water pump and fans after engine shut down? Is there a Kit or something available commercially?
1.33 sixty foot
139 mph
  #6
Old Mar 22nd, 07, 10:47 AM
onovakind67 onovakind67 is offline
What is the pressure rating of your cooling system? Burping at 230 would indicate a low rating on the radiator cap. What kind of coolant are you using?
  #7
Old Mar 22nd, 07, 12:56 PM
I am running a 21 PSI Moroso cap on the Be Cool Radiator. I am using the Prestone Green coolant and one bottle of Purple Ice in the system.
1.33 sixty foot
139 mph
  #8
Old Mar 22nd, 07, 5:38 PM
Sounds like you bought a Spal twin 11 inch fan set up ... the thermal switch
is set to kick the fans on at 195 degress and off at 175 .. this is a open closed ground switch thus.. run another wire from the top of the sensor to a toggle switch under the dash to ground the relays this way ....any time you want to run the fans you can .. along with tripping the electric water pump and run in combo while the motor is off ... a strip track trick to cool things down between runs .
Another tip .. mix your coolant 70 % distilled water 30% anti freeze
while im at it ...presure cap ratings ...each lbs of cap pressure increases puke point 6 degrees 10 bls = 60 added degrees = puke point 271 degrees ... high cap presures do nothing to keep motors cool
a efficient rad ... good flow ...and high cfm will cool alot of HP's
  #9
Old Mar 23rd, 07, 4:06 PM
I bout the adjustable temp switch for the Be Cool Set up as well. I trust that I will be able to report success after this weekend!
1.33 sixty foot
139 mph
  #10
Old Mar 23rd, 07, 4:58 PM
You can't keep it cool if you can't keep the coolant in the system. If you increase the boiling point, you increase the ability of the system to absorb heat at higher temperatures. Once the coolant boils, it won't absorb more heat.
I was under the impression that the boiling point was raised about 3/lb, so a 10# cap would raise the boiling point to about 242. If the pressure cap is on the high pressure side of the radiator, it could be even less.
  #11
Old Mar 30th, 07, 11:54 AM
Chevy fan attic Chevy fan attic is offline
Mike
You would be correct
  #12
Old Apr 1st, 07, 11:51 AM
bln bln is offline
Dave
chas, don is giving some good advise. I have a 402 BB dyers setup ,be cool rad ,stock waterpump , when i added the dual spal fans = end of overheatng whoas . if i turn my fans on and leave them on i can run at 160 all day long. let us know what happens lets see some pictures of your car. Dave
My Chevelle convertible My65
67
  #13
Old Apr 1st, 07, 8:50 PM
Xtreme70SS396 Xtreme70SS396 is offline
Mark
I see a second issue here -
If you're running that hot while cruising, that means you're running that hot with airflow through the radiator. So the new fans will help while stopped or slow, you still have a problem when cruising at speed.
I'd take a look instead/in addition at your electric waterpump, it may not be up to the task. Are you getting full voltage at the pump while the fans are also on?
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
  #14
Old Apr 2nd, 07, 9:32 AM
Update to all.
While the Spal fans fit the radiator, they will not clear the belt of the blower! I would have to move the radiator back at least 2.5 inches. I have already recessed it to clear the long blower drive and do not have any more room options. I did install the 180 degree thermostat in place of the 160. But all is not lost.
I will be building a custom aluminum shroud for the two fans that I have (Permacool flat hi-perf 12 inchers). Also, I will install a Spal adjustable temp switch so that the fans will come on at a set point and run until the temp reaches another established point. I will also wire the water pump to continue to run with the fans. I will also add a manual override option to keep them on longer if needed. My hope is that the lost radiator area formerlly not shrouded, along with cycling the cooling system, will give me lower temps.
You can see some pics at
http://members11.clubphoto.com/charl.../guest-1.phtml
I will be updating them later.
1.33 sixty foot
139 mph
  #15
Old Apr 2nd, 07, 11:04 AM
forcd ind forcd ind is offline
i have in the past run diff size restrictors in place of the thermostat, sometimes you have to hit that fine line of keeping water in the rad. long enough to cool as opposed to keeping it too long in the block.
usually with a 3" belt, it kills room for a fan, which i think is some of the overheating problem versus the blower causing it
then i have seen the fans wired wrong, blowing in rev dir
good luck with it, one of the hardest things to fix is overheating problems
when your credit cards are maxed, have the limits raised
Chevelle Tech > Mechanical > Heating & Cooling      Current Topic: Need cooling help on Pro Street Big Block
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
big block cooling fan macdon Heating & Cooling 7 Jan 29th, 07 10:30 AM
big block engine swap bloodhound248 Engine 3 Aug 23rd, 06 12:13 PM
Building A 396 Big Block Engine TYLERJAC Engine 9 Aug 1st, 06 7:28 PM
Big Block vs. Small Block frame mounts dfoisy78 Engine 3 Jul 5th, 06 11:56 PM
UDHarold: Lunati/UltraDyne Cam Catalog?? Cable Performance 6 Apr 6th, 04 5:48 PM
