| Chevelle Tech Current Topic: cowl induction | ||
| Body Shop Paint & Body Forum |
on my 72 chevelle with cowl induction hood the "flap" on it is always in up position and looks like it has a connection for a vacuum line on it but i dont know what it originally would go to.......any ideas?
#2
There should be a vacuum pod (probably silver) attached under the hood and connected to the outer flapper door. The pod will have a nipple on it. Connect a rubber vacuum hose to the pod nipple and connect the other end to your manifold vacuum line using a "t". The flapper should be open when the engine is off, closed when the engine is running normally, and then it should open once again when you are driving and then mash the pedal.
James '71 Chevelle convertible 454 w/TH400 NEEDS: Positraction (coming soon!) |
In addition to the pod, there's also a small check valve. Flap is down when the engine is running, until manifold vacuum drops enough for it to open - ie, under full throttle.
Mark 1970 SS396 Lewis Racing Engines (aka Wolfplace) "mild" 489: 634 HP @ 6,000 rpm 627 Lb-ft @ 4,000 rpm ProSystems HP1000 Gear Vendors Overdrive Moser 12 Bolt Alumitech Radiator Dyno '70 Chevelle '70 Chevelle 2 |
Thanks for the cowl input. I just bought my 71 and I wasn't sure why it always jumped up when I shut the engine off. I feel much better about it. How far open should it open at full throttle/when engine is off. Mine seems to be opened at diffrent degrees each time I shut it off. It is a neat feature I might add though.
Points nearly straight up when off.
Watch this video for an idea of how it works: http://videos.streetfire.net/recentv...8f01445abc.htm
#6
is there somewhere i could get like a kit cuz mine doesnt have a line or anything but it does still have the pod
#7
Great video! My neighbor has one of those Lotus' -- ugly little cars in my opinion. Dave |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Please Help .. Cowl Induction | Birddog1970 | Electrical & Wiring | 1 | May 1st, 05 4:24 PM |
| Please Help! Cowl Induction Setup? | Birddog1970 | Restoration Corner | 8 | May 1st, 05 4:22 PM |
| cowl induction intake and carb swaps | re-animate | Engine | 0 | Nov 29th, 03 12:39 PM |
| Cowl Induction Questions | Mr454 | Troubleshooting | 14 | Aug 5th, 02 10:27 PM |
| 70 cowl induction hood | jrb56 | Body Shop | 8 | Mar 15th, 02 1:41 PM |
