How do I fix this high spot? - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Feb 4th, 07, 11:14 PM
Dcairns560 Dcairns560 is offline
Dan
Default How do I fix this high spot?
On the drivers door of my 70 there is a divet near the top edge of the door just under the body line that looks like it was caused by a rock. Just underneath that there is a high area. Im not sure if the rock damage caused the high spot as well as the low spot or not. Anyways, I was able to fill the low area with filler but I dont know how to get the high spot to go down. If I wack the high spot with the palm of my hand it pops in but comes right back out. I took the wooden handle of a hammer right on the high spot and pushed in, then I whacked the hammer handle with another hammer, this has made the high spot a little better, but it is still there. Should I continue with this method until it is low enough and then use some filler, or is there a better way? As you may have guessed, I am an absolulte novice when it comes to body work, so any help would be appreciated! Thanks in advance!
70 Chevelle 350+ .030 9.7:1 comp
200cc alluminum heads, 64cc chamber
Comp xr300hr cam, 300/306 duration, .562/.580 lift
Weiand Xcelerator intake, 750holley
4:10 rear gears
3515 lbs w/ driver
12.32 @110 all motor, 11.31 @121 175hp nitrous
Have you driven OVER a Ford lately?
Old Feb 4th, 07, 11:25 PM
MARTINSR MARTINSR is offline
Default Re: How do I fix this high spot?
If this high spot is a "brow" CAUSED by the dent that is IN, you need to remove the filler you filled in the dent and push out on it from behind while you TAP the brow down with a flat faced body hammer.
That would be the start. If it has no "body" and it is poping in and out, well now that is a whole nother issue. But we'll cross that bridge when we come to it. First, push out on the low spot and tap the high spot down. You may find that they "level" out to each other and all is good for a little polyester putty or filler.
Brian
Brian Martin
1965 Buick Gran Sport Convertible
1959 Rambler American. Yeah, I said RAMBLER, you want to make something of it punk?
"Fan of most anything that moves human beings"
Old Feb 5th, 07, 1:04 AM
Dan
Thats kinda what I was thinking... that the dent IN caused the high spot. So how do I pop out the dent? I have access to a beginners body hammer and dolly set... how do I use it?
4:10 rear gears
3515 lbs w/ driver
Old Feb 5th, 07, 10:07 AM
Visit this article and read thru it, you will be miles ahead. The article was writen for large flat panels which you are not working with, but the technique is the same on any dent with a brow next to it. http://www.camaros.net/forums/showthread.php?t=12229
As far as the "beginers body hammer set" sometimes those are real junk. The hammer faces are too small and have sharp edges that put OTHER dents when using them. You may need to use a metal rod with the end rounded off or even a chisel to get to the back of your dent and apply some pressure. Then WHILE that pressure is being applied you tap that brow down with your body hammer. But really, any hammer will do as long as it's face is nice and smooth without sharp edges.
Brian
Brian Martin
Old Feb 5th, 07, 3:54 PM
Brotherjoe Brotherjoe is offline
Joe
Call a local PDR guy. He has the tools to fix it right.
  #6
Old Feb 5th, 07, 7:07 PM
BIGBLOCK70Z BIGBLOCK70Z is offline
JOHNNIE
if the dent is small enough you might take a little propane torch and a cold wet rag. hold tip in middle get hot and then wet rag it. if not use a shrinking hammer and dolly the high spot down while holding steady on the dent from the back side. good luck
i need motivation
  #7
Old Feb 5th, 07, 10:04 PM
Dan
Thanks for the input guys. I will give these suugestions a try this week or weekend.
4:10 rear gears
3515 lbs w/ driver
  #8
Old Feb 18th, 07, 1:23 AM
Dan
I finally got a chance to work on this high spot tonight but didnt have much success. I putting pressure on the back side of the dent with a chisel (its in a hard spot to reach) and tapped around the high area. The dent and the high spot seem to have gotten a little bit better but not much. For the amount of time I spent doing this I didnt see much progress. When I am tapping on the high spot, should I concentrate on one single spot or move the hammer around some? Anything else I can try to make this work better? I am a little leary of trying to use any heat to fix this for fear I might REALLY screw things up!
Any more suggestions are appreciated!
4:10 rear gears
3515 lbs w/ driver
  #9
Old Feb 18th, 07, 9:09 AM
nitetrane98 nitetrane98 is offline
I'm still having a hard time visualizing this dent but the thing comes to mind from your last post and the "tapping" you're doing makes me think you might be being a little timid with it. Your dolly should be spanning the outside high spot on the inside of the door. Sometimes you have to hit it hard enough to get the results you want. Not too hard, you don't want to stretch the metal any more than it already is. You are at a definite disadvantage with your limited selection of dollies. Unless you have the glass out I think it would require an extra set of hands. Maybe even with the glass out. If you are having "oil can" problems with it, ie popping in and out, you are really going to have to figure a way to back it up to use a shrinking hammer. If you can't back it up the torch method described earlier will be your only other choice for shrinking back the area. A picture would be nice.
  #10
Old Feb 18th, 07, 10:45 AM
sevt_chevelle sevt_chevelle is online now
Eric
You will want to move the hammer around the while hitting the high spot. You need to work out both the low spot and the high spot together. As probably mentioned before the low spot is causing the high spot. Your dolly needs to be held very tight with outward pressure against the low spot while you hit the high spot with your hammer.
You need to relieve the stress on that metal from the high/low spots before you do anything. Heat shrinking the high spot at this point will yield poor results, as the stress is still in the panel holding the low spot in.
IMO the shrinking hammers and dollies that are out there are junk, they destroy the metal. They fatigue the metal, weaken it making for repairs that later down might occur impossible. Picture meat tenderizers and what that piece of beef looks like after. The modules that make up that steel will just be pounded to death, stay away from the gimmick tools.
When you get to the point that you do need to shrink that metal, which you do, the BEST method is with a shrinking disc. Its the most controlable and fastest method and does NO damage to sheetmetal.
But for fixing that one dent, its not really needed, you can get by using other methods that work on the disc's basic princple.
If you have a DA sander that can be switched into grinder mode you can use that to shrink the metal. If you dont have one that can go into different modes by moving the weight on bottom of the sander then this method WILL NOT WORK.
Take a dull piece of 120-220 sandpaper and run it over the metal. How this works is simple, it hits the high spots in the metal, heat builds up JUST in those high spots caused by fricition. Run your sander over the metal for around 5 secs, then cool the metal with a wet rag, if you DO NOT see steam you didnt heat the metal enough. Continue using the sander until you see steam when you cool.
You will probably find you need to do a few runs of heating and cooling, just the DA sander and the wet rag.
These two links show some metal work using nothing but simple hand tools and the shrinking disc, the end result is a repair with no filler what so ever, you could simply prime it and paint it. Hopefully you might get some ideas on what to do...Eric
http://www.imagestation.com/album/pi...?id=2099542273
http://www.imagestation.com/album/pi...?id=2103083895 This one explains what is going on and shows the tools used.
Currently working on How to videos and replacement sheetmetal panels
1970 chevelle getting Sliced and Diced Anything But STOCK
1970 chevelle SS455 not a typo its a BUICK BABY
1949 and 1972 chevy trucks
Pictures of my work
http://s969.photobucket.com/home/sev...elle/allalbums
http://community.webshots.com/user/sevt_chevelle
  #11
Old Feb 18th, 07, 11:54 AM
Dan
I do have the glass removed for better access to the back side of the dent, but it is still hard to get in there with any of the dollies that I have. I was using a screwdriver or chisel to put pressure on the back side of the dent. I get the feeling that with the screwdriver/chisel method I am only putting pressure on a very small area of the dent, would I have better luck if I used a tool that could put pressure on a larger area of the dent at a time? What else can I to do this? Also I have been "tapping" rather lightly, should I be more aggressive with the hammer?
4:10 rear gears
3515 lbs w/ driver
  #12
Old Feb 18th, 07, 11:51 PM
baddbob71 baddbob71 is offline
If you can't get enough outward pressure on the low area maybe have a helper put some muscle on it while you work the high areas on the outside. You can also use a slapping spoon instead of a hammer which would be less likely to cause any additional damage if you're uncomfortable with how hard to strike. A slapping spoon can be made from a piece of leafspring fairly easy- do a search for a photo to better describe what you'll need. The spoon strikes the metal and pushes in a a larger area than the hammer and also sends a better shock to get the low area moving outward. If the panel pops in and out (oil canned) after the majority of the dent is removed it will then need to be shrunk. Use a disc or the DA method Eric recomends-works much better than a torch or stud gun IMO.
Getting the metal close to being right will yield the best results, otherwise it's cave and pave time.
  #13
Old Feb 19th, 07, 8:48 AM
SS_Dave SS_Dave is offline
Dave
You guys recomending the DA method of shrinking..
Arent you worried about grinding too much metal off?
Wont the high spot be getting thin?
Just curious.
Cave and Pave... hee hee.
I am guilty of that, but the pothole wasnt too deep, so to speak.
Dave
#1104
1969 Chevelle 460, 3.73 posi
Auto Gear Super Case with M22 gears
12.11 @108 mph
Top speed 114.23
  #14
Old Feb 19th, 07, 4:00 PM
Dan
I did manage to make the low spot somewhat better. It definitely is not as deep, but somehow I seem to have made it wider/longer, if that makes sense. I still dont think that the high spot has gone done at all. It sure seems like I have spent WAY too much time on this for such little progress!
4:10 rear gears
3515 lbs w/ driver
  #15
Old Feb 19th, 07, 5:52 PM
Eric
Thats why I suggest a DULL piece of sandpaper, and with 180 to 220 that would take some time. The trick is having it dull, but the shrinking disc is far superior...Eric
Pictures of my work
Chevelle Tech > General Tech Area > Body Shop      Current Topic: How do I fix this high spot?
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Smoking and always rich SteveRoehll Troubleshooting 12 Apr 9th, 08 8:30 AM
Help! High spot in keeper groove 2 damage valve guide? 47chevy Performance 17 Dec 6th, 06 1:19 AM
High mileage oil? Adam Loose Bench Racing 17 Oct 9th, 06 2:30 PM
Will those with High 9's to high 10's post their incrementals?? Please Shawn Gilbert Performance 11 Aug 6th, 06 9:05 AM
?? Stock Starter vs. High Torqe Starter jimhudgins4 Engine 6 May 28th, 06 9:57 PM
