How do I remove differential cross shaft bolt? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Feb 3rd, 07, 11:04 PM
Slowpoke70 Slowpoke70 is online now
Enrique
Send a message via AIM to Slowpoke70 Send a message via Yahoo to Slowpoke70
Default How do I remove differential cross shaft bolt?
I've done this before, but seem to have forgotten how?
I have the rear cover off and the bolt loose but I can't get it out. I slide it as far as I can and it hits the bearing cap. I don't remember removing the bearing cap to install the locker, and I had to remove the cross shaft to install the locker. What am I doing wrong? I've already tried turning the wheels but it seems like no matter where the bolt ends up, I can't get it past the bearing cap?
1970 Malibu
355/TH350/3.36
Isky z25/Sportsman2/300-36/Summit Headers
Old Feb 3rd, 07, 11:46 PM
big gear head big gear head is offline
Freddie
Default Re: How do I remove differential cross shaft bolt?
You don't need to completely remove the bolt. You just need to get it out of the way far enouogh to remove the shaft. Do you have enough room to do that?
Old Feb 4th, 07, 1:53 AM
Enrique
I pulled the bolt out as far as I could and then pushed the wheel towards the outside of the car and the shaft moved about 3/4" out but then it seemed like it snagged on something and I couldn't push it out with my finger. Maybe I have to pry on the part of the locker that is next to the shaft? Hmm, now that I think of it, maybe that would work.
1970 Malibu
355/TH350/3.36
Old Feb 4th, 07, 4:35 AM
Cameano Cameano is offline
Gold Founding Member
Darren
Doesn't sound good, Enrique. I've broken those cross shaft retainer bolts before. One, I was lucky enough to fish out the broken piece, and get the shaft out. The other, no such luck, so I left it alone in there. Then one day, I'm driving down the freeway, and get this BAM BAM BAM under the car, whole car shaking violently. It was the cross shaft finally working itself free, and whacking the pinion gear as the diff spun around. Scratch one 10 bolt rear.
Darren
64 El Camino 468, 9", ST-10, 4wdb, eternal project
69 Firebird 461" stroker, th400, 3.36's, 4wdb, Midnight Green - Sold
Beach Cam
TC #78 Gold, ACES #3130
Old Feb 4th, 07, 12:41 PM
Enrique
I don't think mine is broken. I think I'm just not doing this right. I'll report back in a little bit.
I have to get these axles out, I haven't driven the car in so long...
1970 Malibu
355/TH350/3.36
  #6
Old Feb 4th, 07, 4:15 PM
Enrique
okay, I got the shaft out. It had some pretty deep "scratches" on one end that I think were snagging. I think I have a spare cross shaft around here, but does anyone make a replacement (8.2 10bolt)? The instructions from Richmond for the locker mentioned replacement pins but the ones I've found online say "only for Richmond mini-spools".
1970 Malibu
355/TH350/3.36
  #7
Old Feb 4th, 07, 4:26 PM
Freddie
Is this a Lock Right? There are a few cross shafts available for this rear end. You need to know the diameter and length.
  #8
Old Feb 4th, 07, 6:18 PM
Enrique
I couldn't find my calipers but it looks like 4.75" long and 11/16" in diameter, maybe 3/4"? This is with a regular ruler.
1970 Malibu
355/TH350/3.36
  #9
Old Feb 4th, 07, 7:39 PM
Enganeer Enganeer is offline
John
Quick way to tell the diameter is use the open end of a wrench.
If it is a fractional size say a 3/4", then a 3/4 wrench will fit between the flats of the wrench with very little room, a 11/16 will not fit and a 13/16 will be too loose.
John
64 Malibu SS 406
406 DYNO Results
1970 EL Camino soon to be LS1 / T56
06' GTO LS2, M6, CGM
Instructions...All I need is the exploded view.
  #10
Old Feb 4th, 07, 8:07 PM
Enrique
i'll check that out. Oh, and yes it is a Powertrax Lock Right.
1970 Malibu
355/TH350/3.36
  #11
Old Feb 4th, 07, 11:43 PM
charbilly2001 charbilly2001 is offline
Bill
If the shaft wasn't loose in its bores I would recommend taking some emery cloth and clean up those scratches and reuse the shaft you have. They aren't particularly delicate. Should be good for one more round.
  #12
Old Feb 4th, 07, 11:47 PM
Enrique
I don't know, I guess scratches isn't the right word. They're more than deep enough to catch a nail on and emery cloth won't polish them out. That and the powertrax instructions state in bold letters to replace it if ANY scratches or imperfections are present?
Also it looks like it is a 3/4" diameter. The shaft also has to flat sections that the fit perfection into the 11/16" wrench.
1970 Malibu
355/TH350/3.36
  #13
Old Feb 4th, 07, 11:54 PM
Bill
I stand corrected
  #14
Old Feb 5th, 07, 7:51 PM
Enrique
TTT
Anyone know where I can get a replacement shaft?
1970 Malibu
355/TH350/3.36
  #15
Old Feb 5th, 07, 8:12 PM
Freddie
Send me an email. I can get one for you. There are several available.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: How do I remove differential cross shaft bolt?
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Difficulty level for Novice & tools Needed-Front End rebuild? Steven's 72 Brakes, Suspension & Steering 17 Jan 30th, 07 12:00 PM
'67 Front Control Arm (A Arm) Cross Shaft? Rodeo73 Brakes, Suspension & Steering 9 Nov 26th, 06 7:41 PM
Open carrier 12 bolt cross pin bolt P/N needed ratengine Transmission & Driveline 1 Aug 15th, 06 7:09 PM
12 bolt Differential Shims-Where to Start? ben70 Transmission & Driveline 5 Aug 20th, 04 8:26 AM
12 bolt cross shaft set screw broke, need advice 136679ss Transmission & Driveline 9 Jun 3rd, 04 5:58 PM
