Starter spins does not seem to engage - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Jan 26th, 07, 8:30 PM
Lou59 Lou59 is offline
Default Starter spins does not seem to engage
Hey guys, need some help here. Everything is new in the resto on a 69 Chevelle SS. Wanted to get it started this weekend. Anyway...using a mini starter on a 454. Initially was not getting anything to the starter and figured out I needed to jumper the NSS. Did that and now the starter is energizing but it sounds as though it's not engaging the flywheel, just spins? Any ideas?help please. Thanks
Lou
Old Jan 27th, 07, 11:34 PM
anychevy anychevy is offline
Team Member
Dave
Send a message via Skype™ to anychevy
Default Re: Starter spins does not seem to engage
I don't have any experience with mini starters but I'm sure the principals are the same, the solenoid is engaging but not throwing out ? or wrong gear for the flywheel ? teath missing from flexiplate ? pull it off and bench test it. maybe some others will chime in ?
Dave
Old Jan 29th, 07, 3:27 PM
Thanks for the response Dave.
Figured it out...there are two possible mounting positions with a Mini...why? Don't know why but I suppose the first installation (which made more sense to me...and where the notch on the mini starter mounting block appears to be made to wrap the edge of the block/oil pan)...was incorrecto. It was spinning but not engaging the flywheel. Well, moved it to the second position which seems to be a slight lateral move away from the block and it fixed the problem...Not sure how that works because it seems to me I would be increasing the gap between the starter gear and the flywheel by moving in that direction...But then again...starts and runs now.
Thanks again
Lou
Old Jan 29th, 07, 11:17 PM
Team Member
Dave
Is it possible that it's made to bolt up to Pontiacs, Buicks and Olds as well ?
Dave
Old Feb 2nd, 07, 11:08 PM
rcrchsr16 rcrchsr16 is offline
Dave
Probably the 2 mounting positions are there for different ring gears. I know there's at least 2 different gears with different numbers of teeth.
  #6
Old Feb 3rd, 07, 5:13 AM
Keith Tedford Keith Tedford is offline
Keith
We use a Chevy mini starter on our 396 Chevelle. It whips the engine over as if all the spark plugs were removed. A lot of power for such a little unit. I have a suspicion that these little starters will over heat very quickly if your car doesn't want to start. Not much size to dissipate heat. If you get yours working, you will be pleased I am sure.
  #7
Old Feb 6th, 07, 12:25 AM
Team Member
Dave
I prefer the OEM type myself, heavy I know, but when they're rebuilt right they will last for ever !
dave
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: Starter spins does not seem to engage
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Starter doesn't always engage :( Spar Troubleshooting 12 Aug 27th, 06 1:45 AM
Starter won't engage at times Chevy 70 SS vert Engine 5 Jul 9th, 06 6:37 PM
Starter Spins WILD72 Engine 5 Apr 9th, 05 9:48 PM
Won't Start when hot 67SS_MASS 2003 15 Jul 24th, 03 11:20 AM
weird "short", or "open", or ?.......... mikeclam Electrical & Wiring 19 Feb 13th, 03 10:17 AM
