FRAME RESTORATION POR-15 vs ?? - Chevelle Tech
Auto Insurance
Restoration Corner Where originality comes first.
Old Jan 19th, 07, 10:16 PM
Paul's '66 in PA Paul's '66 in PA is offline
Exclamation FRAME RESTORATION POR-15 vs ??
I hope this is the correct area for a post. Working on a frame which has set outside for several years. Lots of surface rust but structurally sound.
I have been reading about a product called POR-15, to STOP rust and prevent additional rust. It is applied with a paint brush and the consistency of thick water. Product description sounds just what I want..too good to believe?!?.
Can any of your Chevelle tech-heads give me an "approval" to use this product or should I be looking at another product.
I will use the 3 step process with the Marine wash, metal prep and then POR-15.
Paul in PA
Old Jan 19th, 07, 10:36 PM
alss alss is offline
Albert
Default Re: FRAME RESTORATION POR-15 vs ??
I personally do not care for the POR products. I would rather sandblast and then use good automotive grade paints and materials to refinish it correctly. POR seem to be just a band aid IMHO.
ALbert
1969 9566AA COPO Chevelle
COPO 2
COPO motor
1969 Malibu 489 ZL-1 T 56
http://i518.photobucket.com/albums/u...DSC_0201-1.jpg
1969 Beaumont 454 ZL-1 6 spd..under construction
http://i518.photobucket.com/albums/u...DSC_0520-1.jpg
1969 300 2 door post 427 ZL-1 4 spd
http://i518.photobucket.com/albums/u...DSC_0055-1.jpg
1969 Z 28 X77 D 80 olympic gold
MCC#511 ACES #1805
Old Jan 19th, 07, 10:42 PM
CT Mark CT Mark is offline
Team Member
Mark
I've used it in the past on frame pieces. Applied it with a brush. It's way too glossy out of the can if you want a correct look. Also, if you use it, wear gloves!
Mark
66 Chevelle SS
http://www.chevelles.com/showroom/da...velle_DL_2.jpg
AACA Senior Grand National
MCACN Gold Concours
Old Jan 19th, 07, 10:58 PM
micky69396 micky69396 is offline
Micky
Actually the POR 15 Chassis paint is nice. I do not use the POR 15 thats the rust stop stuff or whatever though. Just the top coat product and its really durable and looks good
Micky Hale
68 Biscayne 427/425 M-22
ACES #134
Warlock Racing AA/GS
www.mickyhale.com
https://www.facebook.com/pages/North...111066?sk=wall
Old Jan 20th, 07, 10:33 AM
Hi-po SS 454 Hi-po SS 454 is offline
Richy Rich
Send a message via AIM to Hi-po SS 454
I use it, Good stuff!!!!!!!!!!
Rich
71 SS clone, MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
https://www.youtube.com/watch?v=VzkB7RTVDUc
  #6
Old Jan 20th, 07, 3:11 PM
Lou Merrell Lou Merrell is offline
I have to concure with Al.
I blasted using glass bead (didn't like the texture of sand), cleaned using acetone (and an altered gun cleaning kit), one coat of metal etching primer, and two coats of chassis black.
"It is when people forget God that tyrants forge their chains." -Patrick Henry
  #7
Old Jan 20th, 07, 3:12 PM
fastss396man fastss396man is offline
Brian
I used the POR 15 with great results. However I did not apply it over any rust. I sandblasted the entire frame clean then applied the regular base POR15 and then top coated the base with the POR Chassis Black. I also did all of the control arms, anti sway bars springs, core support and front steel inner fenders and entire bottom of the body. It's been about 10 years now since these pieces were done and all still look great. I did thin and spray not brush. If you decide to spray the vapors are very harmful, also you will need to cover all of your skin and protect your eyes. 2 coats of base and 2 coats of chassis black.
My Showroom
69' SS396 Chevelle L78 396/375hp M-21 Close Ratio Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl and lots of chrome!
ACES# 3466
  #8
Old Jan 20th, 07, 3:16 PM
Gotta' love that Cortez Silver.
  #9
Old Jan 20th, 07, 3:23 PM
Paul, this might be of interest to you:
http://www.eastwoodco.com/jump.jsp?i...Y&iMainCat=688
  #10
Old Jan 20th, 07, 11:43 PM
Mr69 Mr69 is offline
I've heard that once you brush POR15 on, you will never get it off. Apparently it doesn't blast off well at all. So you may want to consider this if you're looking for a correct restoration, now, or in the future.
Knowing this, personally, I'd never use it.
Blast, prime and paint. Muuuuuch better IMHO
Paul, if you've got the frame stripped down, why not just blast it and do it right?
  #11
Old Jan 21st, 07, 12:41 AM
furball8994 furball8994 is offline
Scott
Thanks for that link Lou. I was planning on using the POR. I didn't know much about the Eastwood product. Great to see a side by side, real world comparison. Looks like I'll be giving Eastwood a call in the near future.
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
  #12
Old Jan 21st, 07, 1:04 AM
FameSS-396 FameSS-396 is offline
Fred
Is it possible to apply POR-15 or Eastwoods Rust Encapsulator under the floor boards (for protection) and then top coat it with GM Restoration Black paint as a correct looking final coat?
Fred
1968 Chevelle SS Conv
1964 Corvette Conv
2003 Silverado Crew Cab 1500 HD 6.0L
2001 Tahoe LT
2002 Tacoma Ext Cab
TC # 2866 ACES #7649
"It's better to burn out Than to fade away"
  #13
Old Jan 21st, 07, 1:11 AM
Chessman90 Chessman90 is offline
I had mine sandblasted and powdercoated along with all the other suspension components for $365. They look outstanding. I think you can find pics in my sig
1965 Chevelle SS 327, M-21, 12 bolt
  #14
Old Jan 21st, 07, 1:47 AM
erikbuzz erikbuzz is offline
Send a message via AIM to erikbuzz
I used POR. Just make sure you clean everything before application. I started with a bare metal frame. I definitely wouldn't put it over rust even if they say you can. The only thing I would change is that I would have used their semi-gloss and not high gloss.
1970 Chevelle
355/TH350
COMP HE-268
Flowmaster 50 Series
HEI
Holley 650 spreadbore
Soon to be fuel-injected with Megasquirt and EDIS
  #15
Old Jan 21st, 07, 3:50 AM
Keith Tedford Keith Tedford is online now
Keith
I had a shop sand blast a rad support. I then painted on Por 15 and it looked like it had sand in it when dried. A light sanding showed that it was actually the roughed up metal from the sand blasting that was causing the bad finish. I think that the blaster was using some pretty wicked pressure. After a complete sanding and top coat the support looked fine. I've glass beaded stuff in my cabinet and they come out with a dull shine. Etching primer and top coat turn out excellent. If the product has Isocyanates in it, be careful. These compounds will ruin your lungs if you are not careful. A neighbour had his lungs messed up with the isocyanates about 10 years ago and has been on a disability pension since then. Beware. Micky and Al's advice is good enough for me. They know what works.
Chevelle Tech > Specialty > Restoration Corner      Current Topic: FRAME RESTORATION POR-15 vs ??
Human Verification
Similar Threads
Frame was previously straightened. What needs to be done? stealth71 Body Shop 21 Nov 17th, 06 9:50 PM
FRAME GALVANIZING-East Coast zrwhat Body Shop 18 Dec 14th, 05 7:33 PM
Frame Swap Out Question? chevyguy Restoration Corner 3 Dec 2nd, 04 11:06 PM
Weight difference: boxed frame vs. open frame Rich-L79 2004 8 Mar 10th, 04 11:17 AM
Help !! Motor and Frame Mounts ?'s for BB DS76462 Top Tech 9 Sep 14th, 99 4:58 AM
