max lift on stock BBC heads - Chevelle Tech
Auto Insurance
Old Jan 7th, 07, 2:53 AM
SoCalRat SoCalRat is offline
Garry
Default max lift on stock BBC heads
What is the maximum lift that can be safely obtained using the 063 heads?
Seems .600 is what I recall but the flow numbers posted in Car Crafts head data section lists flow to .750
Garry
67 Chevelle
454 10:1 compression
CCC roller 233-239, 288-296 .623 lift
063 ported heads
Muncie 4-Speed
Old Jan 7th, 07, 8:26 AM
Junkyard Dawg Junkyard Dawg is offline
Dave
Default Re: max lift on stock BBC heads
I've asked this question before and have been told to just have the heads checked....
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Old Jan 7th, 07, 8:30 AM
mr 4 speed mr 4 speed is offline
I have used the GM L88 cam and long slot rockers with stock closed chamber heads before.
Lift was .540/.560
Old Jan 7th, 07, 3:39 PM
92Camaro 92Camaro is offline
If the heads are apart then this will be easy to measure. With the seal on the guide, valve's installed both intake/exhaust, keeper's and a retainer. Measure the bottom of the retainer (near the lock part of the retainer) to the top of the valve seal using a dial caliper. Get you're number then subtract .060 form that number and that will be the total lift.
Ron Miller 92Camaro
Old Jan 7th, 07, 5:01 PM
SWHEATON SWHEATON is offline
Team Member
Smile Re: max lift on stock BBC heads
Dont forget that max lift also has a very important componant to that mix which is piston to valve clearance.
063 heads may in fact be able to handle .600 lift but maybe not if the heads & block are decked,if using high comp/high domed pistons,and a long duartion large overlap high perf cam so keep that in mind too.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
  #6
Old Jan 7th, 07, 5:38 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
I think Ed is over .700 lift with his 215's. I guess it all depends on how much work is done to them.
  #7
Old Jan 7th, 07, 9:05 PM
Pro67Chevy Pro67Chevy is offline
Jim
Send a message via AIM to Pro67Chevy
This is only the 4th engine I've put together so I'm no expert but, if you ask me, valve lift goes far beyond just what head you are using. That is just the beginning.
What pistons are you using? What kind of reliefs? What size valves? How much cam duration? What springs are you using? What's the installed height? What kind of head gasket?
I'm also using the 215s and if I'm not mistaken the 063s are the same closed chamber design. I have 2.19" valves and i'm using a .647" lift SR and I have plenty of room with TRW # 2399 small dome pistons and decent reliefs.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
"It's all in the smoke!"
Video 1 Video 2
No time slips yet, 2013!!!
  #8
Old Jan 8th, 07, 12:56 AM
Garry
Thanks for all the replies, Looking at the Voodoo 60212 roller. Pocket ported stock heads with stock valves for now.
Looking at the same piston. Currently using the .022 steel shm but can change to meet the need. Want 9.5 -10.0 on the compression
Garry
67 Chevelle
063 ported heads
Muncie 4-Speed
  #9
Old Jan 8th, 07, 11:11 AM
Mike Feudo Mike Feudo is offline
I have never raced with an oval port head but the big port closed chamber heads really don't gain alot much over .650 lift because of the shrouding of the chamber wall. Is there is reason you want to use the most lift you can? It will cause you many maintenance problems that can be a real pain.
  #10
Old Jan 8th, 07, 5:40 PM
Garry
Mike, The roller cam I was considering has lift of .619 so I needed to see of the heads would work or if I should go to a smaller lift cam
Garry
67 Chevelle
063 ported heads
Muncie 4-Speed
  #11
Old Jan 8th, 07, 6:24 PM
cstraub cstraub is offline
Bottom of the retainer to the top of the guide including the seal. This measurement is your max cam lift possible. The measurement will also very on every engine because of guides, retainers, seals used.
Measure this area and you will know for sure.
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
http://online.flipbuilder.com/dgew/gken/
Why is it we never have time or money to do it the right way in the beginning but we always have time and money to do it over again?
  #12
Old Jan 8th, 07, 10:04 PM
Jim
Garry,
Maybe you could post a subject:Voodoo 60212.
With reguard to springs, keep in mind...
1) Regardless of the lift your current springs yield, piston-to-valve clearance will ultimately decide what lift/duration you can get away with.
2) Your new cam will be matched up with a new set of springs that you should be using. This will ensure you have the proper lift requirements and spring pressure.
Jim
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
Chevelle Tech > General Tech Area > Performance      Current Topic: max lift on stock BBC heads
Human Verification
Similar Threads
are 215 Bbc heads worth switching to? BACK FROM THE DEAD Engine 9 Jul 13th, 06 8:54 AM
Stock heads and cam lift 75c10 Performance 7 Jul 16th, 05 11:39 PM
Q&D cost analysis of converting to Vortec heads Pat Kelley 1999 -- 6 Apr 17th, 99 7:55 PM
