reverse clamp/spreading tool? - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Nov 14th, 06, 1:07 AM
Andy69 Andy69 is offline
The Fat Stig
Default reverse clamp/spreading tool?
Is there a tool that does the reverse of a clamp - spread apart? Like a sort of Vice Grips in reverse? I can see that coming in very handy during this whole floor pan/brace expedition.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
Old Nov 14th, 06, 2:17 AM
rubadub rubadub is offline
Rob
Default Re: reverse clamp/spreading tool?
A porta power spreader is one thing.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old Nov 14th, 06, 2:18 AM
Rob
retaining ring pliers.
Rob
I mean snap ring pliers.
Old Nov 14th, 06, 2:24 AM
Rob
You could take two pieces if two inch flat stock about a quarter inch thick, about three foot long, put a bolt and nut in the center of the two, then take a piece of rope or wire and tighten them up by the old twist knot method.
Rob
Old Nov 14th, 06, 2:35 AM
Rob
How about a two by eight about ten feet long, block of wood and have your wife stand on the other end for leverage.
Mine will always say how long is this going to take, and I will stop and look at her, and say, like you have something really important that you have to do. Then when I finally get her out there to help, she will start suggesting, why don't you do it this way.
Shes only called when its an emergency, then a guy doesn't have to listen to that ta ta ta ta.
Rob
  #6
Old Nov 14th, 06, 7:01 AM
theclencher theclencher is offline
Banned
I can't imagine what you're doing Andy. Would a scissors jack from a small car work?
  #7
Old Nov 14th, 06, 8:40 AM
The Fat Stig
Well putting these floor pans and braces on I'm trying to get pieces of sheet metal together in various places. One place that comes to mind is the braces where they meet the inner rocker. I can use a cat's paw or small crow bar to hold it using the frame for leverage but have you ever tried holding 5 things and a welding shield while trying to weld something? I "reverse clamp" thingy would work really well there. Something small like a vice grips that you can lock into position and take your hands off. Is there such a thing? Good suggestion about the wife but she complains too much to be useful for that sort of thing
SuperAndy's Garage
  #8
Old Nov 14th, 06, 10:25 AM
hmott hmott is offline
Harlan
Sounds like you need to have a son. Mines only 8, but he's actually helpful, I'd pick him over the wife any day of the week. He slows things down some, but its good time and he is actually helpful, just slow.
Harlan Mott <- Not French
71 Malibu Convertible - rust bucket
  #9
Old Nov 14th, 06, 11:25 AM
The Fat Stig
well my daughter would be all into helping, but her 22 month old brain just doesn't quite have the attention span I'm looking for (ooooh look at the pretty bright light from the welder I want to touch it and take it inside and give it to my Barney doll. Yeah, that'd go over well with the missiz )
SuperAndy's Garage
  #10
Old Nov 14th, 06, 12:41 PM
Rob
If you had some really strong magnets, or could you spot weld the edge of a washer on it, then use some wire to hold it temporarily.
Rob
  #11
Old Nov 14th, 06, 1:17 PM
Rob
With the washer and wire deal, you can get the panels pulled in pretty close, then with your free hand push the panels together then cleco or sheet metal screws until you can get a couple spot welds in.
Rob
  #12
Old Nov 14th, 06, 2:25 PM
ChaosEnvy ChaosEnvy is offline
Big D
http://www.amazon.com/Bessey-DUO65-8.../dp/B0002H49OY
How about something like this. Its a simple wood type clamp.. Reverse the ends and it pushes outwards rather then clamping.
  #13
Old Nov 14th, 06, 3:00 PM
The Fat Stig
That was the first thing that came to mind. That would work if the tips were long enough and they were made of metal. I can only seem to find them made of pvc or plastic - not a good combo with molten metal nearby
I can picture it in my mind - a vise grip pliers but instead of the jaws coming together at the end, they cross over each other and extend, so that when you clamp it down, the jaws are actually forcing out away from each other rather than together (yeah like a snap-ring pliers). Alternately I'm thinking of perhaps like a t-shaped deal with a screw shaft out the long end and when you twist it the two sides of the "t" get longer. Surely I'm not the first person to have a need for something like this??
SuperAndy's Garage
  #14
Old Nov 14th, 06, 3:02 PM
The Fat Stig
how about this?
http://www.amazon.com/exec/obidos/AS...s-20/ref=nosim
SuperAndy's Garage
  #15
Old Nov 14th, 06, 3:07 PM
Big D
I am sure there are metal ones out there. You can always use and adjustable tie rod . Metal sleeve, with threaded bar on both ends. Tack a couple small metal plates on the end. Voila, adjustable spreader.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: reverse clamp/spreading tool?
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Tools,tools where do i find? 68chevyed Body Shop 13 Oct 4th, 05 1:22 AM
Used Welders -- What to Look For hd99fxst Body Shop 6 Jul 5th, 05 9:13 PM
Reverse Gear worn, should I replace? 396 ss Transmission & Driveline 1 Jan 21st, 04 5:55 PM
Cannot Get into "a grinding Muncie m-20 Reverse gear" chattanoogachoochoo Transmission & Driveline 7 Dec 23rd, 02 3:17 PM
"Basics of Basics" Buying tools MARTINSR Body Shop 5 Sep 15th, 02 1:44 PM
