Melling cams - Chevelle Tech
Auto Insurance
Old Nov 13th, 06, 8:01 PM
Aaron Aaron is offline
Default Melling cams
Anyone have a link to a site that has Melling cam info for a BBC?
Old Nov 13th, 06, 8:31 PM
pdq67 pdq67 is offline
Guest
Paul
Thumbs up Re: Melling cams
Here you go..
http://www.hi-performance.com/Mellin...eCamshafts.htm
Chevy 1966-87 396 - 402 - 427 - 454 CID V8: 1.7 Rocker Arm Ratio- Hydraulic Flat Tappet*
Advertised Duration Gross Lobe
Performance Duration At .050 Lift Valve Lift Center Line RPM Part Price Purchase
Code Int. Exh. Int. Exh. Int. Exh. Int. Exh. Range No.
2 261 272 190 202 .439 .464 106 114 500-4000 22127* $99.95
2 288 298 204 208 .459 .459 108 116 1200-4700 MTC-6* $99.95
3 292 292 214 214 .502 .502 109 119 1700-5200 22214* $99.95
4 306 322 222 235 .500 .505 110 120 2100-5600 22296* $99.95
5 292 292 230 230 .544 .544 107 111 2500-6000 22302* $149.95
6 298 304 240 246 .559 .572 110 114 3000-6500 22471* $99.95
* Stock valve springs cannot be used.
And you might find this interesting??
http://engineparts.com/pubspdfs/4-200-05.pdf
Clevite Cams
CHEVROLET V8 262-265-267-283-302-305-307-327-350-400, 1957-94
229-2199 Hy. 184 194 260 270 .245 .265 .368 .398 104 104 104, 12 ATC 16 ABC 21 BBC 7 BTC
229-2224 Hy. 190 202 258 269 .258 .273 .387 .410 112 108 116, 14 ATC 24 ABC 36 BBC 14 BTC
229-2156 Hy. 194 204 270 278 .265 .281 .398 .422 112 107 117, 10 ATC 24 ABC 39 BBC 15 BTC
229-2200 Hy. 194 204 270 278 .265 .281 .398 .423 104 104 104, 7 ATC 21 ABC 26 BBC 2 BTC
229-2360 Hy. 194 214 268 288 .265 .294 .398 .442 112 107 117, 10 ATC 24 ABC 44 BBC 10 BTC
229-1871 Hy. 202 206 269 271 .269 .276 .404 .415 114.5 115 114, 14 ATC 36 ABC 37 BBC 11 BTC
229-1730 Hy. 204 214 278 288 .281 .296 .422 .444 112 107 117, 5 ATC 29 ABC 44 BBC 10 BTC
229-2201 Hy. 204 214 278 288 .281 .296 .422 .444 110 110 110, 8 ATC 32 ABC 37 BBC 3 BTC
229-2141 Hy. 208 208 280 280 .280 .280 .420 .420 111 106 116, 2 ATC 30 ABC 40 BBC 12 BTC
229-2202 Hy. 208 208 280 280 .272 .272 .408 .408 110 107 113, 3 ATC 31 ABC 37 BBC 9 BTC
229-2203 Hy. 209 216 283 286 .290 .303 .435 .455 112 107 117, 3 ATC 32 ABC 45 BBC 9 BTC
229-1987 Hy. 214 214 287 287 .296 .296 .444 .444 110 105 115, 2 BTC 32 ABC 42 BBC 8 BTC
229-1988 Hy. 214 224 288 298 .296 .311 .444 .467 112 107 117, 0 TDC 34 ABC 49 BBC 5 BTC
229-2205 Hy. 214 224 288 298 .295 .310 .443 .465 112 100 124, 7 BTC 27 ABC 56 BBC 12 BTC
229-2296 Hy. 216 228 282 294 .302 .320 .453 .479 112 107 117, 1 BTC 35 ABC 51 BBC 3 BTC
229-1989 Hy. 218 218 292 292 .303 .303 .455 .455 110 105 115, 4 BTC 34 ABC 44 BBC 6 BTC
229-2225 Hy. 218 218 295 295 .286 .286 .429 .429 110 108 112, 1 BTC 37 ABC 41 BBC 3 BTC
229-1713 Hy. 223 223 290 290 .298 .298 .447 .447 114 110 118, 1 BTC 42 ABC 49 BBC 6 BTC
229-1991 Hy. 224 224 298 298 .310 .310 .465 .465 112 107 117, 5 BTC 39 ABC 49 BBC 5 BTC
229-1990 Hy. 224 224 291 287 .300 .307 .450 .461 114 114 114, 3 ATC 47 ABC 46 BBC 2 BTC
229-2290 Hy. 224 224 300 300 .291 .291 .437 .437 108 107 109, 5 BTC 39 ABC 41 BBC 3 ATC
229-2370 Hy. 224 230 283 291 .320 .324 .480 .486 110 107 113, 7 BTC 37 ABC 51 BBC 1 BTC
229-1998 .022 .022 219 229 258 270 .304 .319 .456 .479 114 110 118, 1 ATC 40 ABC 53 BBC 4 BTC
229-1615 Hy. 230 230 304 304 .302 .302 .453 .453 114 112 116, 3 BTC 47 ABC 51 BBC 1 BTC
229-1993 Hy. 232 232 288 288 .320 .320 .480 .480 108 106 110, 10 BTC 42 ABC 46 BBC 6 ATC
229-1994 Hy. 232 234 300 308 .325 .325 .488 .488 108 106 110, 10 BTC 42 ABC 47 BBC 7 ATC
229-1995 Hy. 234 244 303 313 .325 .339 .488 .509 112 107 117, 10 BTC 44 ABC 59 BBC 5 ATC
229-2120 Hy. 244 244 312 312 .289 .289 .434 .434 108 107 109, 15 BTC 49 ABC 51 BBC 13 ATC
229-1996 Hy. 246 246 302 302 .339 .339 .509 .509 109 106 112, 17 BTC 49 ABC 55 BBC 11 ATC
229-2289 .030 .030 246 246 280 280 .334 .334 .501 .501 108 106 110, 17 BTC 49 ABC 53 BBC 13 ATC
229-1612 .030 .030 254 254 294 294 .323 .323 .485 .485 114 110 118, 16 BTC 58 ABC 64 BBC 10 ATC
229-1622 .022 .024 257 270 304 320 .329 .341 .494 .512 112 108 116, 19 BTC 58 ABC 70 BBC 20 ATC
229-2294 .022 .024 262 272 309 318 .341 .357 .512 .536 112 108 116, 23 BTC 59 ABC 69 BBC 24 ATC
229-2291 .022 .022 274 274 312 312 .386 .386 .579 .579 110 106 114, 31 BTC 63 ABC 71 BBC 23 ATC
229-2297 .030 .030 278 278 319 319 .345 .345 .518 .518 112 107 117, 29 BTC 69 ABC 73 BBC 25 ATC
CHEVROLET V8 366 (Chain Drive)-396-402-427-454 -Exc. VIN ″J″, 1967-96
229-2136 Hy. 190 202 261 272 .258 .273 .439 .464 110 106 114, 12 ATC 22 ABC 35 BBC 13 BTC
229-2004 Hy. 204 214 282 292 .281 .296 .478 .503 112 108 116, 6 ATC 30 ABC 43 BBC 9 BTC
229-2006 Hy. 214 214 293 293 .296 .296 .503 .503 114 109 119, 2 ATC 36 ABC 46 BBC 12 BTC
229-1737 Hy. 214 224 292 302 .296 .311 .503 .529 112 108 116, 1 ATC 35 ABC 48 BBC 4 BTC
229-2007 Hy. 218 218 296 296 .303 .303 .516 .516 110 105 115, 4 BTC 34 ABC 44 BBC 6 BTC
229-2356 Hy. 218 228 277 287 .295 .295 .502 .501 114 109 119, 0 TDC 38 ABC 53 BBC 5 BTC
229-1636 Hy. 222 235 310 325 .294 .297 .500 .505 115 110 120, 0 TDC 42 ABC 57 BBC 2 BTC
229-2305 Hy. 224 234 302 308 .311 .325 .529 .553 114 110 118, 2 BTC 42 ABC 55 BBC 1 BTC
229-2011 Hy. 231 231 290 290 .320 .320 .544 .544 109 107 111, 8 BTC 43 ABC 46 BBC 5 ATC
229-2357 Hy. 240 246 305 311 .329 .337 .559 .572 112 110 114, 10 BTC 50 ABC 57 BBC 9 ATC
229-2301 Hy. 246 246 304 304 .339 .339 .576 .576 110 106 114, 13 BTC 53 ABC 57 BBC 9 ATC
229-1614 .020 .024 242 242 310 297 .306 .306 .520 .520 114 108 120, 12 BTC 50 ABC 60 BBC 2 ATC
And I need to retype my old hand written Elgin list again..
Plus, I have General Kinetics spec's too..
pdq67
Old Nov 13th, 06, 8:48 PM
Default Re: Melling cams
Paul
You every run that MTC-6 cam?
We are putting one in a 440 or a 427 bored .060.
Torque motor for truck!
Old Nov 13th, 06, 8:59 PM
Guest
Paul
Aaron,
No I haven't, but I figure it is probably just about like a BB Performer cam that Summit sell's as their SUM K-1300 at 208/218.
Probably cheaper from Summit too..
And for low rpm, BB grunt, you will be right in there.............
pdq67
Old Nov 13th, 06, 9:01 PM
Thanks Paul.
Do those cams have a little cackle in them?
Chevelle Tech > Mechanical > Engine      Current Topic: Melling cams
Human Verification
Similar Threads
Preventing Flat Cams? GOSFAST Engine 37 Dec 8th, 06 2:58 AM
Lobe Seperation for you experts? senior Engine 28 Jun 19th, 06 8:07 AM
HELP 496 BBC cams, cams, cams blue66 Performance 19 Mar 26th, 06 8:13 PM
Melling High Performance cams? 69boo307 Performance 13 Oct 14th, 05 8:45 PM
