Recommended "tire dollies" for rolling car around in garage? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Nov 13th, 06, 2:20 PM
Xtreme70SS396 Xtreme70SS396 is offline
Mark
Default Recommended "tire dollies" for rolling car around in garage?
I was just wondering if anyone used these, and if so which ones you would recommend. I'm referring to the metal plates with 4 casters on each corner, you set one tire on each dolly.
I don't want to leave the car on them, but they would be great for rolling either car out of the way.
Thanks!
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Old Nov 13th, 06, 2:30 PM
RUQKENF RUQKENF is offline
Tony
Default Re: Recommended "tire dollies" for rolling car around in garage?
We use these and they work great. You can usually get a cheap set for about $100 or less. When they are not under a car we use them to store extra transmissions.
Tony
1969 Chevelle SS396
468CI Twin turbo
Old Nov 13th, 06, 3:27 PM
454rock 454rock is offline
Steve
I got a set from Summit,the aluminum ones,and they are excellent and invaluable. Steve
dave_silva dave_silva is offline
Use them and love them. I put a lot of things on them when they are not under the car. Got some a Harbor Frieght for around $100, had one caster break after 4 years of hard use. Hit the lip between the driveway and gargage with car on it and the caster broke, lip was 1/2" with caster being maybe 3" and I had running start...
Fair Oaks, CA
http://www.x86Racing.com (Dave Silva x86 IMCA Modified)
Old Nov 13th, 06, 3:31 PM
webfoot webfoot is offline
Team Member
Jeremy
I have the harbor freight ones, used them for a short time - work just fine. Don't expect to just be able to push the car around with ease. I was able to push it around with no help, but it is a struggle!
Jeremy
70 Chevelle
383, AFR heads, voodoo hyd roller.
Best time 8.09 @ 88.49 MPH (1/8 mi.)
68 GTO 'vert factory 4-sp, rally gauges, hidden headlights
  #6
Old Nov 13th, 06, 3:51 PM
Bowtie-72 Bowtie-72 is offline
Not Andy
I also have Harbor freight ones. Worked well to move car, but try not to load it up with your spare parts-gets heavy quick. It was not too hard to push, just make sure floor is well swept before pushing.
I've also used them under the front frame rails when I swapped spindles-just use a 4x4 under frame. They do some in handy for heavy stuff.
{OO Malibu OO}
1999 350, Vortecs, GM's HOT cam, Holley Stealth Ram, 700R4, 4:10s
car: http://i168.photobucket.com/albums/u...ps8c002323.jpg
engine: http://i168.photobucket.com/albums/u...s/DSC03416.jpg
  #7
Old Nov 13th, 06, 3:53 PM
nolimitpkr nolimitpkr is offline
Brian
Thumbs up Re: Recommended "tire dollies" for rolling car around in garage?
Thanks!
I looked into them also, but found that I could just as easily move the car around with the floor jack. It may be a little more work, but I can move my 68 with ease now that I know how to do it properly. Just make sure if you want to move the front end, put the car in neutral so that the back wheels are free to move.
1968 300 deluxe
15.9 @ 88.0 mph
1968 mailbu (383,th400,12bolt/posi)
13.52 @ 101.84 mph
"Just about the stupidest thing you could do, is to try and move a big block with your shoes untied."
"IF YOU HAVE A RACE CAR BUY RACE CAR PARTS"
  #8
Old Nov 13th, 06, 3:58 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
I've got a set of the Harbor Freight ones also. Pretty easy to turn a car around with them.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #9
Old Nov 13th, 06, 4:01 PM
Dean Dean is offline
Same here
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
  #10
Old Nov 13th, 06, 5:30 PM
Mark
I usually use the jack, too - but the other car in the garage is a bug, and although I COULD just pick it up and slide it over, my back just doesn't like it so much. Bugs get lifted by 1 SIDE of the car at a time, not front/back like most cars.
Thanks, Guys - looks like quite a few options out there!
Mark
1970 SS396
634 HP @ 6000rpm
ProSystems SV1
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
  #11
Old Nov 13th, 06, 7:54 PM
zeke67 zeke67 is offline
I've got Harbor Freight ones. It's all I can do to move the car around with em'. Require two people and still a struggle. My perspective is I got what I paid for and next time i'd spend more.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
  #12
Old Nov 13th, 06, 8:34 PM
70SS 70SS is offline
I've had the standard dollies before and found they are a bunch of working getting the car on and off of them. Everytime I'm done with the car I put it on dollies so that I can push it out the way). I bought a set of Go-jacks and love them. These dollies jack up the vehicle with a foot pedal, I can have the car off of the ground and agianst the wall in 5 minutes. They are very well made to and should last along time.
  #13
Old Nov 13th, 06, 8:57 PM
72chevy 72chevy is offline
Gregg
HF now carries a Go-Jack knock-off
http://www.harborfreight.com/cpi/cta...emnumber=94682
$140 a pair on sale.
Gregg
1972 Chevelle
454 Pro Street
  #14
Old Nov 13th, 06, 9:10 PM
boomhauer boomhauer is offline
I bought a few sets from harbor freight. They work ok if you are lucky enough to get a set that actually has round wheels.
  #15
Old Nov 14th, 06, 6:09 PM
Donnie1 Donnie1 is offline
Donnie
you know the old saying YOU GET WHAT YOU PAY FOR.
70 SS 396 Chevelle
69 SS L-78 Chevelle
04 GMC 2500HD Dmax/Allison
04 Wells Cargo 24' autowagon
04 Cadillac Deville
ACES #4390
some pics Webshots Album
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Recommended "tire dollies" for rolling car around in garage?
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
need info on a 66 427 Dana chevelle bronze & Dana chevy merittone Chevelle Tech 11 Sep 5th, 14 1:24 PM
Need Ebay legal info and opinions on car deal mykes68 Bench Racing 18 Jun 6th, 05 8:19 PM
Body Off Frame In 2 car Garage - Help! MAXXOM Restoration Corner 15 Jun 3rd, 05 11:52 PM
New hear with 70 SS 454, awesome car SS 454 Restoration Corner 16 Jun 2nd, 05 3:42 PM
Best way to protect car (in garage) 69-CHVL Bench Racing 35 May 25th, 05 10:07 PM
