Spray technique with HVLP vs LVHP - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Sep 27th, 06, 10:01 AM
ToocoolZ28 ToocoolZ28 is offline
Gold Founding Member
Ron
Default Spray technique with HVLP vs LVHP
I've been using a Binks number 7 siphon type LVHP paint gun for 20 plus years and have decided to go with a new Sata HVLP gun. How much do I have to change my spraying technique? I know I have to experiment with it some but do I hold the gun closer? Go slower?
Any help appreciated.
Ron
70 Chevelle SS396 (427) M21
69 Malibu convertible
95 Z28 Convertible T56
TC #54 Gold
69 - Top down
69 – Top up
new wheels
70 side
On Gearz
Old Sep 27th, 06, 1:23 PM
Novaholic Novaholic is offline
Default Re: Spray technique with HVLP vs LVHP
Ron
Well, Since you have sprayed for 20 plus years you have the teqnique down, the only change your going to make is to how you set of your psi and fluid control on a SATA, compared to the #7 you've sprayed with for years...I spray basecoats at 17-22 psi and clearcoats at 21-25 psi...the transfer rate and efficiency of the HVLP guns is great, I do recommend a 1.5 on basecoats and the SATA RP for clearcoats, you may not like the way a regular SATA basecoat gun lays out clearcoats. Also take a look at the digital guns from SATA.
Roy Landgrave
Old Sep 27th, 06, 3:43 PM
baddbob71 baddbob71 is offline
Make sure you've got a good supply of air, and high flow fittings without a cheater valve to take full advantage of the HVLP. Sata guns like lots of air.
Old Sep 28th, 06, 12:12 AM
Ron
I just bought this compressor, air shouldnt be a problem
http://www.mytscstore.com/detail.asp...productID=1270
Ron
TC #54 Gold
69 - Top down
69 – Top up
new wheels
70 side
On Gearz
Old Sep 28th, 06, 6:31 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
I have a Binks 7 also (at least 20 years old and still works perfect). The 7 was virtually fool proof. When I shot the car last spring, the HVLP worked well but I did find that the clear did not flow out as smooth as I wanted. Ironically, it had more texture when applied drier than when applied wet. May be a function of the paint or the the switch to HVLP, but this was opposite of what I had been used to. In al fairness though, this was the first BC/CC job I had done, I pretty much had just sprayed enamel or SS in the past.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Spray technique with HVLP vs LVHP
Human Verification
Similar Threads
"Basics of Basics" Spray technique tip MARTINSR Body Shop 6 Dec 2nd, 05 1:50 PM
Eastwood HVLP spray Gun Kit p/lineman Body Shop 4 Apr 14th, 05 8:40 AM
Sharpe HVLP gun smittyocat Body Shop 1 Oct 26th, 03 11:53 AM
how to spray small parts with hvlp gun bhawk Body Shop 2 Sep 16th, 03 10:04 PM
Question on HVLP Spray Guns (Gravity or Suction) Richss396 Body Shop 5 Oct 8th, 00 5:58 PM
