502 BB Chevy Oil Use - Chevelle Tech
Auto Insurance
Old Sep 6th, 06, 2:50 AM
rreince rreince is offline
Default 502 BB Chevy Oil Use
I hope I found the right place, hi to all:
I have a question Im sure you all have had tabled before. Currently have a 502 in a 68 GMC. It has always used oil, about 1qt in every 400-500 miles. Is that normal? I did a leak test which turned out fine, my thought was the valve guide seals but was told they are not avaiable for the 502, I dont think a new motor 13000 mi should have such a problem.
Any Ideas, thanks in advance.
Bob
Old Sep 6th, 06, 7:53 AM
PCB67SS PCB67SS is offline
Bill
Default Re: 502 BB Chevy Oil Use
Things You Should Know About 502's
A) All 502's built since the inception during the mid 80's have used a unique ring combination of 2.0mm/1.5mm/4.0mm. The factory installed 4.0mm oil ring is a low tension ring. It is used to reduce frictional horsepower losses. Oil consumption is a natural characteristic of this type of oil ring. When it is time for a ''freshen up'' on your 502, we recommend the Speed-Pro High performance file fit ring set which includes a standard tension oil ring for improved ring sealing and oil control. (This info was taken from page 11 Tech. Note in Scoggin Dickey Parts Center catolog)...Hope this helps
Old Sep 6th, 06, 8:00 AM
69-CHVL 69-CHVL is online now
Vinny Vince
Which 502, the ZZ or HO?
*69 CHEVELLE SS EFI 502/T56 Mag/3.90
*06 C6 LS2/T56
*96 Stang LS/6.0 turbo - everybody should have one!
Old Sep 7th, 06, 12:45 AM
Thank you for the information it seems very common from what I gather. When the day arrives and I hope not soon to refresh it I will keep these notes for reference. I might try a 20-50 was another suggestion. Thanks again.
Old Sep 7th, 06, 12:47 AM
Its the 502 HO 450HP Cast heads.
  #6
Old Sep 7th, 06, 7:19 AM
Vinny Vince
Does it smoke idling?
I think these big block crate motors suffer from 2 problems. The ring situation obviously, and the inadequate valve seals on the iron head motors. I went through this also...still going through it to some degree. My motor smoked bad in addition to using a qt. of oil every 2-300 miles. The factory umbrella seals IMO are too small to drape over the stem adequately, causing a smokey idle and deceleration. Also had puddles of oil on top of each intake valve. I had my heads machined for PC seal. Smoking is gone, but still uses oil. All my plugs come out w/oil on the threads still. I was more concerned about the smoking though as it was quite embarrassing. No seals off the shelf will fit the guides b/c of the dual springs. Getting valves seals will reduce the smoking but not eliminate the oil burn. I was told the low-tension oil rings were worth ALOT of power so that's why GM ran them.
Here's a pic of the factory valve seal (if you want to call it a seal)
Here's a push-on type seal, but the there's not enough clearance between the dual springs to run it. Another member suggested to take the top metal ring off of it and maybe even trim the top a bit. Shoulda tried if B4 ripping the heads off.
*06 C6 LS2/T56
  #7
Old Sep 7th, 06, 8:12 AM
TW TW is offline
Tom
Bob, I had my 502/502 torque plate honed before I assembled the motor (also had it decked). I reassembled it with the same piston/rings it came with. I used about half a quart in the first 200 miles and have not used any since (~700 miles total). I drive the car hard (it's too much fun stepping into it ). Perhaps the torque plate hone helped the rings to seat bettter?
Vince, I had the same problem when I switched to my Lunati solid roller springs. The stock guide seals would not fit in the spring. I looked through a bunch of sites and found a teflon seal with a smaller OD (I think it was from Crane) that fit with room to spare. You may want to try that route.
Tom
502 Powered '66 SS
  #8
Old Sep 7th, 06, 8:25 AM
Vinny Vince
Tom, you have aluminum heads right? They are machined for the smaller seals from the factory. The iron motor have unmachined guides (.625).
Unless they have a small o.d. push on seal for .625 guides...that would be a godsend.
*06 C6 LS2/T56
  #9
Old Sep 7th, 06, 10:33 AM
pdq67 pdq67 is offline
Guest
Paul
It's as if these big motors make all that much power stock to begin with that they need "ring-lites" in them!!
These two things here are just more of the General's not better ideas to me!!
Sorry for your hassle.........
pdq67
  #10
Old Sep 7th, 06, 1:07 PM
TW TW is offline
Tom
Yeah Vince, that's a good point. I think my guides use the 0.530" seals. You would obviously need to turn down the guides to make them work. I think the ones I have are the larger ones.
Tom
502 Powered '66 SS
  #11
Old Sep 17th, 06, 3:01 AM
I'm not sure this will get to evryone who has had a hand on my question, but just wanted to say thank you, what a great group.
With the information you ALL have offered I have decided its "normal" for this power plant, when it's time to refresh I have some good information.
Thanks agian
Bob
  #12
Old Sep 25th, 07, 10:03 PM
1st timer 1st timer is offline
Grant
do the new ZZ's with alumninum heads have the same problems as the HO's? I really want to put a ZZ in my 67, but no way am I going to pay the big bucks for an engine that burns oil.....very shameful! guess I will have to go with another engine choice....anybody hear anything about the new Edelbrock 502?
thanks
  #13
Old Sep 25th, 07, 10:19 PM
Bryan59EC Bryan59EC is offline
Bryan
my 454 HO (build date=07-04) had the rings in upside down
Light hone--machine heads for new valve seals--new rings
(had this done by a builder)
Engine has not been back in the car long enough for me to get a grip on it yet.
Tailpipes were litterally dripping with oil
Even had an oil spot on the garage floor under the mufflers while the car was sitting w/o motor.
Also---the valley baffle is designed so that the 'tabs' that support it, rest on a intake/head mating surface.
I trimmed the tabs in the center off-----double the vacuum.
Chimps are building these motors
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
65 Ranchero v8/4-spd, that my uncle bought new
  #14
Old Sep 26th, 07, 7:34 AM
Guest
Paul
This is why I will build my next BB myself!!
Whether it be a 468" or a 588"!!
F-- GM!!
pdq67
  #15
Old Sep 26th, 07, 8:56 AM
Finally Finally is offline
Hank
I know some will say garbage but here's what I've seen with my 454HO. After initial breakin it blew smoke on startup like crazy. Was only running on 6 or 7 cylinders and would take 5 minutes to burn up all the oil in the cylinders and start running on all 8. This was consistent, every startup.
I swapped the valve covers that come with the engine for the short chrome covers from my 396, no more smoke and starts on all 8. Also moved PCV valve hookup from intake to carb. Oil consumption is way down as well. Still less than 1000 miles on engine, maybe the rings have seated more. All I know is the change was dramatic. Wouldn't cost much to test this yourself. Remove PCV valve and replace with breather.
Hank
70 Chevelle SS396(454), M20, 3.73
My Chevelle
Chevelle Tech > Mechanical > Engine      Current Topic: 502 BB Chevy Oil Use
Human Verification
Similar Threads
Chasing Oil Leak dmg1029 Chevelle Tech 6 May 30th, 06 8:03 AM
BB Chevy Help, oil pressure mac762 Engine 13 Apr 7th, 06 6:41 PM
Help!!! Will these holes in the oil gallery plugs hurt oil to the lifters? Whittaker Performance 5 Feb 4th, 06 7:03 AM
So how does an oil gauge work? 67 vette guy Chevelle Tech 9 Aug 2nd, 05 3:48 PM
Fuel in Oil - Low Oil Pressure? Brad Engine 6 Apr 19th, 05 8:39 AM
