hooking up internal regulated alternator with external regulator in place? - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Sep 2nd, 06, 1:59 AM
bluechevelless bluechevelless is offline
Danny
Send a message via AIM to bluechevelless Send a message via Yahoo to bluechevelless
Default hooking up internal regulated alternator with external regulator in place?
How do you hook up an internal regulated alt to a external regulated system with keeping the external regulator in place?
1970 Chevelle SS 396
Originally Mist Green
Dark green Interior
AC PW PL
www.cardomain.com/id/3115ultima
www.g3gm.com
Old Sep 2nd, 06, 8:25 AM
Raymond Raymond is offline
Default Re: hooking up internal regulated alternator with external regulator in place?
Not exactly sure about your question,but there is some good information on this website,especially in the tech section. This may help answer your own queston.
http://www.madelectrical.com/index.shtml
Old Sep 2nd, 06, 11:33 AM
undee70ss undee70ss is offline
Greg
Send a message via AIM to undee70ss
You want to make it look like it is still externally regulated... I have not done it personally, but I have seen it done.... Take a old mech VR, remove the guts, since there are no terminals inside, wires will have to be soldered to connect the tabs inside the VR. All you are doing is jumping one wire to another. Jumper the brown to the blue, and the white to the red (may be orange on some cars). After soldering, check the terminals with a ohm meter to be sure none have continuity to ground or to the wrong wire. At the alternator, remove the plug for the externally regulated alternator off the wires and replace it with a internally regulated plug. (Auto zone has a replacement plug for a internally regulated alternator although they are white, americanautowire has black ones or get a original from a bone yard 73-late 80s GM's) When replacing the wires in the new plug make sure the blue goes to terminal one and the white to terminal 2 at the internally regulated alternator (there are markings on the back of alternator to show which terminal is which) Thats it, other than looking at the plug at the alternator, it will look like it is still externally regulated, and since there is no cutting of the original wires, you could even go back to externally regulated. Hope this helps.
Greg U
MY 70SS
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: hooking up internal regulated alternator with external regulator in place?
Human Verification
Similar Threads
internal / external balanced sbc deiinc Performance 6 Jan 13th, 05 2:54 AM
Internal vs external crank balance JIM Engine 4 Mar 24th, 04 2:15 PM
Internal versus external voltage regulator problem Steve Petzer Electrical & Wiring 1 Nov 9th, 03 2:53 PM
Using both internal and external voltage regularators Carnut108 Electrical & Wiring 2 Sep 19th, 03 1:28 AM
Easy way to convert from external regulator to internal? 2BlueLS6's Electrical & Wiring 5 Aug 8th, 02 2:02 PM
