327 harmonic balancer question - Chevelle Tech
Auto Insurance
Old Jul 25th, 06, 6:25 PM
kentrx1 kentrx1 is offline
Default 327 harmonic balancer question
I have aquired a 1962 327 (3789817 casting....s is suffix code) and have a question about the harmonic balancer. There is no center bolt going into the crank----my limited knowledge leads me to believe it is either broken off flush, stripped, etc.----but i am just checking that all old 327's used a center bolt to attach the balancer. The thought of trying to drill out a broken bolt (even when looking with a bright light i can not see any signs a bolt was there). Unfortunately I do not have access to any of the prior owners to get a history on the engine. Thanks for any help offered.
Old Jul 25th, 06, 6:32 PM
furball8994 furball8994 is offline
Scott
Default Re: 327 harmonic balancer question
Yes. It should have a center bolt. If it is broken off, you need to remove it. If its missing just install a new one. P.S. you should delete the other 3 post's . JMHO
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
69bu 69bu is offline
Rich
My 307 did not have a balancer bolt on it. It was simply pressed on. I have been told that some 283's were also this way.
1969 Chevelle Malibu
496 /th400/ford 9", 3.70 gears.
Best Time: TBD
Old Best:
408 big block / th350 / 4.11 powertrax 10 bolt
11.988@113.39 on BFG drag radials
1.782 60'
A.C.E.S. # 7037
http://www.chevelles.com/showroom/da...dium/MCC01.jpg http://www.chevelles.com/showroom/da...C_Show_015.jpg
Old Jul 25th, 06, 6:40 PM
ty for your reply.....and my apologies for the multiple posts....do not have a clue what happened.
  #6
Old Jul 25th, 06, 6:42 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Not in '62...no crank bolt. Older dampers were just pressed on.
And are you sure it's a 327??
A hole can be drilled and tapped easily with the crank out of the block...not as easy where it's at right now.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #7
Old Jul 25th, 06, 6:48 PM
Nolowrider Nolowrider is offline
Nope, no bolt on 327's. I am not aware of any 327 that has one. The only ones that may have one are the ultra rare 4 bolt mains (if they do exist, never seen one). My 67 does not have one. Never had a problem not having one, mine rev's to the moon with no problems.
I agree with Bill about drilling one.
  #8
Old Jul 25th, 06, 6:50 PM
Scott
I have been educated! I guess you learn something new every day.
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
  #9
Old Jul 25th, 06, 6:51 PM
Yeah, I was fixing to say "same answer on all four post". No problem, it happens. I think you can go through and delete them.
  #10
Old Jul 25th, 06, 6:53 PM
That's why I come here, alot of good people and excellent knowledge base.
  #11
Old Jul 25th, 06, 7:05 PM
BigFred66 BigFred66 is offline
Don
Odd...but my '66 EA code(250hp) has a crank bolt.
I certainly don't know if it was there from the factory or if it was added after the fact...for that matter...don't know if it's the original crank...but it's got one!
  #12
Old Jul 25th, 06, 7:19 PM
#8trx450r #8trx450r is offline
Send a message via AIM to #8trx450r
The early SBC had no hole to put a bolt but as mentioned you can drill and tap it if you feel its needed but they were just pressed on as are all of them, the later ones just had an added bolt.
I have a Large jurinal steel crank 327 here with a Bolt and an earlier 327 with no Bolt
Corey
  #13
Old Jul 25th, 06, 8:57 PM
sorry....have not figured out how to delete others!!
  #14
Old Jul 26th, 06, 12:54 AM
Boldly procrastrinating
TerribleTom II
I have
Tom
  #15
Old Jul 28th, 06, 2:00 PM
Dave Murdoch Dave Murdoch is offline
Just to add confusion, my '69 350 has no balancer bolt. Although this seems to indicate an older engine, this is the stock engine in a Malibu with 350 badges and the engine code matches at 69 350. Has anybody heard of this?
I've never had the bottom end apart, so last time I had the balancer off, I "pressed" it on with a 4x4 block and the BFH method. So far so good for about 1000 miles, but I am always wondering.
Chevelle Tech > Mechanical > Engine      Current Topic: 327 harmonic balancer question
Human Verification
Similar Threads
weird harmonic balancer problem dreis454 Engine 5 May 7th, 06 9:22 AM
A question about harmonic balancers: what's good, what's not for the street Rich-L79 Performance 11 Jan 17th, 05 11:40 AM
327 Harmonic Balancer 7Deuce Engine 8 May 21st, 04 10:39 PM
Pulling off a harmonic balancer 61dragon Engine 6 Nov 22nd, 02 12:44 AM
350 harmonic balancer question Patrick 1999 -- 7 Jun 16th, 99 1:29 PM
