Ram Horn Exhaust Manifolds - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Jul 19th, 06, 2:28 PM
Ray White Ray White is offline
Ray
Default Ram Horn Exhaust Manifolds
Not interested in using headers. Ram Horn exhaust manifolds are supposed to be best flowing cast iron production part ever made by Chevy. Will Ram Horn Exhaust manifolds work on the 1973-77 A body with a 350 without any modifications? Not sure straight centre dumps will clear frame. Truck style with centre dumps and angled outlets might. If not which cast iron production piece will flow better than my stock 1973 units?
Old Jul 19th, 06, 2:53 PM
1968SS427 1968SS427 is offline
Default Re: Ram Horn Exhaust Manifolds
Ray;
The Ram-Horns are fairly short and hug the engine, they should fit fairly well. You would have to make a pair of front pipes (manifold to muffler), this well also address any frame clearance issue. Ram-Horns are pretty good flowing stock manifolds, I have a set of 2.5" from a Vette on my Stroker, their are hard to find today but repops are available, you can find a set of 2" on e-bay or in a boneyard, their still floating around.
P.S. Welcome to the forum. .... Tell us more about your ride.
JIM
* 1968 Chevelle SS - L72 427-4 speed
* 1959 Impala __ 2dr coupe - 383 Stroker-TH400
* 1955 Belair __ 2dr coupe - 283 alum. PG
Old Jul 19th, 06, 4:36 PM
Ray
Thanks Jim,
I would look for the 2 1/2" parts, in fact there are some on e-bay right now and close to my Toronto home as well. GM Performance Division still offers the Corvette Ram Horns at 2 1/2" through the dealers, although I'd hate to see the price.
As for my car it is a 1973 Pontiac LeMans GT. GM Canada says one of 3,761 built. I know, this is for Chevelles! You see in Canada GM built Pontiacs along side Chevrolets so pretty much all Canadian Pontiacs built between 1955 and 1977 run Chevrolet chassis and drive trains. Our Pontiacs were named differently as well. In 1961 you had the Laurentien with the 348 triple carb set up and then the 1964 & 65 Parisienne Custom Sport was a hot performer with the 409 dual quads, then later from 67 on the 2+2 with the 396, 427 and 454 up to 1970. Our midsized Pontiac was the Beaumont from 1964 to 1969, SD cars - Super Deluxe, look like Chevelle SS's on the outside with Pontiac grilles and trim and totally GTO interiors. Engines were 283 up to 396 depending on year.
Small blocks were know as Pontiac "Astro-Flash" and big blocks as "Astro-Jet". Notice any similarities to Chevy "Turbo-Fire" and "Turbo-Jet". There was even a 396 called "Econo-Jet" a 2bbl version.
My car looks like a 73 GTO on the outside but mechanically it is 1973 Chevelle. Mine is a 350 with a TH 350 trans. It has bucket seats and no console with a column shift! I like to keep it looking stock and try to use GM NOS or good used parts when I can. The engine has a ZZ4 Bowtie aluminum intake, Edelbrock #1406 - 600 cfm replacement carb all exiting through duals. I use a pair of 90's Bonneville SE mufflers, the ones everybody complains are too loud on the Bonnie, which have good flow and a nice deep tone. This is no drag strip car but it moves out smartly and sounds good doing it. It is a weekend cruiser that the whole family enjoys that maybe gets 1,000 miles per year. I am having trouble with the passenger side exhaust manifold leaking hence my question. Might as well try and upgrade when a repair is needed.
Thanks again, Ray
Old Jul 19th, 06, 4:51 PM
Mr69 Mr69 is offline
I doubt you could use the old ram horn style manifolds on an A body.
I believe they will dump right onto the frame.
You'd have to make a super sharp 90 degree bend right out of the dump and that would probably kill any benefit you were trying to get on flow.
Just put headers on it.
Old Jul 19th, 06, 5:03 PM
Ray
Thanks Mr69,
That was certainly my impression as well. There does not appear to be enough clearance for the centre dump to go but onto the frame. I was hoping someone had tried and knew for sure.
Any suggestions on a good quality header for the 73 A-Body?
Thanks, Ray
  #6
Old Jul 19th, 06, 5:06 PM
Q-ship Q-ship is offline
Karl
Ram Horns won't fit any of the a-body chassis at least not not without cutting torch the frame.
Life's journey is not about arriving at the gate well preserved, it's about skidding in sideways, all used up and worn out yelling........GOD, what a ride!!!!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
  #7
Old Jul 19th, 06, 5:14 PM
Ray
Thanks Q-ship,
That settles it. There will be No Torching & No Ram Horns!
Ray
  #8
Old Jul 19th, 06, 6:16 PM
Originally Posted by Ray White
Thanks Mr69,
Thanks, Ray
Hooker Super Comp ceramic coated
OR
If you want some real nice headers, call Lemons headers. 805-239-4238
or visit their website at www.lemonsheaders.com
I just ran into Dan Lemons at Subway. Nice guy!
Be sure to check out the customers cars on the website. Lots of wheelstanders !
  #9
Old Jul 20th, 06, 12:34 AM
DZAUTO DZAUTO is offline
Team Member
Tom
AS mentioned, Ram horm manifolds won't fit an A-body. I don't think that even the Ram horn versions that are angled back would even fit. But, even if they would fit, I seriously doubt that you would gain anything with the angled Ram horn manifolds because they were ONLY available in a 2in version, same size as the regular Chevelle style manifolds. The ONLY small block ex manifolds that will provide any worthwhile benefit are the 2 1/2in version. Those manifolds ONLY came on the 62-65 HP 327 Vette engines and the full size Chevys with a 300hp/327.
Those manifolds were still availalble from Chev parts dept up until last year. They are now discontinued!!! Sure, they are available from some of the aftermarket sources, but the prices are climbing fast. But, it doesn't matter, the 2 1/2in Ram horn manifolds CANNOT be used on any 64-later A-body!
Tom Parsons
TC# 474
#3 FOREVER!!!!!
Light travels faster than sound. That is why some people appear to be bright until you hear them speak. (unknown)
  #10
Old Jul 20th, 06, 9:16 AM
Wwalstrom Wwalstrom is offline
Wade
If you want cast iron manifolds on an a-body, try Sanderson Headers
http://www.sandersonheaders.com/
They make a cast iron header/manifold
http://www.centuryperformance.com/de..._id=SDH-QP1000
-Wade
1969 300 Deluxe Sport Coupe
I earn a seven-figure salary ... Unfortunately, there's a decimal point involved.
  #11
Old Jul 20th, 06, 1:42 PM
Ray
Thanks to all for the quick and definitive responses. Sanderson cast iron headers sure look interersting and not that expensive or out of line price wise with other headers I could buy.
Thanks, Ray
  #12
Old Jul 20th, 06, 2:37 PM
JWagner JWagner is offline
Gold Member
Is there any information on how the cast headers compare to the stock manifolds for power and so on?
  #13
Old Jul 20th, 06, 5:02 PM
Ray
http://www.exhaustcenter.com/headers.shtml
This link talks in general terms about Shorties, which seem to resemble cast headers, and traditional tri Y and 4 into 1 headers.
  #14
Old Jul 20th, 06, 6:05 PM
LKN BCK LKN BCK is offline
Dan
Look at todays Help!What Color? Topic... TC member ATLAST has a pic of the sandersons on his ZZ4 in his sig. He may be able to give you some info. They caught my eye and I think they look great.
65 ragtop
65 Coupe
  #15
Old Jul 20th, 06, 6:34 PM
JimN JimN is offline
Jim
Watch out for the Sanderson cast iron headers in the ram's horn style. Sanderson told me that the headers would fit my '65, when they didn't I had a heck of a time trying to return them. I ended up swapping them for the Sanderson shorties which were not the greatest performers and did not seal all that well. I wound up finally with Hedman full length headers which turned out to be a great choice.
65MALIBU 4 door wagon, Disc brakes, F41 suspension, GMPP 350/330hp crate engine 700R4trans, http://www.facebook.com/album.php?ai...4&l=3194cb2bc5http://chevelles.com/feature/september2004.html
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Ram Horn Exhaust Manifolds
Human Verification
Similar Threads
I want exhaust Manifolds I hate headers. Tag Performance 19 Jul 17th, 06 5:05 AM
small block 2.5 exhaust manifolds bri2203 Chevelle Tech 12 May 5th, 06 12:00 AM
396/375 exhaust manifolds Loong Restoration Corner 0 Feb 4th, 06 2:14 PM
Painted Exhaust Manifolds? Mike O'H Restoration Corner 12 Jun 27th, 03 10:51 AM
Exhaust manifolds for 69 SS, A.I.R. or not? Steve Petzer 2002 7 Aug 22nd, 02 1:15 PM
