Mounting Horseshoe shifter - Chevelle Tech
Auto Insurance
Interiors Upholstery and soft trim
Old Jul 10th, 06, 6:35 PM
HovsSS HovsSS is offline
Default Mounting Horseshoe shifter
I have a 68 chevelle SS 396 that was orignially a 4 speed and someone changed it into an automatic with a turbo 350 and a b&m type shifter on it currently. I recently bought an automatic console with a horseshoe shifter which I would like to install. When I looked under the carpet I saw the hole in the floorboards for the manual shifter, and I would assume that that hole will be too big for the horshoe shifter. Can someone direct me on what I should do to get my horseshoe shifter to fit. Should I put a piece of sheet metal over the hole and mount it from there, or are there other options. Any help would be appreciated.
Old Jul 11th, 06, 11:23 PM
jloshotz jloshotz is offline
Jack
Default Re: Mounting Horseshoe shifter
You may need to find a donor floorpan to patch the d/t tunnel....i think you can buy that portion aftermarket for the four speed; not sure about the auto...goodmark or year one maybe? Perhaps someone else will chime in here...
Old Jul 12th, 06, 6:03 AM
Junkyard Dawg Junkyard Dawg is offline
Dave
Put a piece of sturdy sheet metal (not the soda can stuff) over the hole, secure it to the floor using the original screw holes for the shifter boot if you can.....then put the console in place, get the shifter where you want (make sure it goes thru all gears w/o hitting the console), mark your holes, drill and install shifter with some self tapping sheet metal screws....
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Old Jul 12th, 06, 6:56 AM
Thanks alot guys, I really appreciate everyones help.
Chevelle Tech > General Tech Area > Interiors      Current Topic: Mounting Horseshoe shifter
Human Verification
Similar Threads
700R4 Horseshoe Shifter Detent Plate Rucumn Transmission & Driveline 6 Mar 1st, 12 12:12 AM
HELP. Lokar trans shifter bar swap on Powerglide FunkyNova66 Transmission & Driveline 3 Jan 23rd, 06 4:57 PM
Horseshoe shifter Questions. 71Avido Transmission & Driveline 1 Oct 17th, 05 9:57 AM
Hurst shifter mounting location DRLs68 Transmission & Driveline 3 Apr 12th, 05 8:46 AM
Shifter mounting pictures 72ElCaminoSS Interiors 3 May 16th, 04 4:41 PM
