How to remove 67 SS dash. - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Jun 15th, 06, 3:34 PM
pappybear pappybear is offline
Don
Default How to remove 67 SS dash.
Can anyone share some light on the ramification of removing the dash.
I purchased this vehicle 2 years ago and if I don't start restoring it soon my grandkids will be enjoying it instead of me... Shooting for completion in 2007 so I can make the Maryland and Tenn. shows.... Thanks for your help....
Old Jun 15th, 06, 9:59 PM
zeke67 zeke67 is offline
Default Re: How to remove 67 SS dash.
Not sure what you mean by ramifications. It's pretty easy to do. There are a row of phillips head screws under the dash pad, on an each end of the dash and a few bolts from underneath the dash. You'll need to drop the steering column to get the dash out. Remove the fuse panel from the bulkhead connector and the wiring will pretty much come out with it.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
Old Jun 15th, 06, 10:11 PM
droptop396 droptop396 is offline
Todd
Really quite simple. And pretty much self explanitory.
Just take it slow and you will have it out in no time.
pretty much like zeke67 said
__________________________________________________
SOLD, SOLD, SOLD!!!!
1966 Chevelle SS 396/325HP 4-speed Convertible. Marina Blue.
Old Jun 15th, 06, 10:21 PM
DaleM DaleM is offline
Gold Founding Member
Dale
Done it a few times myself. Whether you plan on removing the entire dash or just the speedo/gauge assembly, here's a couple things I found to make it easier.
1. Disconnect battery naturally.
2. Remove steering wheel. This makes access to everything SO much easier.
3. Remove the bezels for the ignition, headlamps, etc. I've found it easier to disconnect/unplug the ignition wiring, headlamp switch wiring, wipers and lighter if you carefully remove the speedo housing so you can get your hands behind the dash...it's tight back there.
4. Take some masking tape and pen to mark and tape which wires go where - lights, high beam indicator, lighter, etc. to make reassembly much easier.
If you're removing the entire dash you'll probably want to drop the steering column as well. Removing the heater (and/or AC) controls out the back will make getting to the radio easier as well. Remove glove box liner and door to save wrestling those around as well.
TC Gold #92 ~ August 1998
* Ever stop to think, and forget to start again?
* ChevelleStuff - Decoding info for 64-72 (For Sale)
* 1966/1967 Chevelle Reference CD/1970 Build Sheet Decoder CD
* Chevelle Registeries
* Build Sheet Data Collection
Old Jun 16th, 06, 1:26 AM
Chris R Chris R is offline
Actually, I perfer to pull the entire steering column out with the wheel attached, so I dont have to deal with re-positioning back on in the correct position. Thats exactly what I did with my 66SS. It looks like it wont clear when you keep going back all the way to the back of the seat but you can wrestle it out.
I had my dash out a few years ago for a re-paint but plan to pull it out to do all the electrical this time. Just not sure when it will happen. I should also clean up and replace the insulation, and heater core housing.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
  #6
Old Jun 16th, 06, 1:23 PM
Herb Herb is offline
The GM Chassis Service Manual has a step by step description on how to remove the dash. Simple and easy. Zeke has the right idea, pull the wiring with it. I'd leave the heater controls coneccted. Just slide the bezel back thru the dash opening. It's actually pretty easy.
You should pick up that book and the factory assembly manual. Best $20 you'll spend.
Herb Sr
'67 Coupe (frame-off)
489BB w/ Straub custom roller cam
M20/3.73 Eaton posi
http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG
  #7
Old Jun 20th, 06, 11:48 PM
BigFred66 BigFred66 is offline
Don
DON'T FORGET TO DISCONNECT THE SPEEDO CABLE!(been there/done that!)
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: How to remove 67 SS dash.
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Goodmark Resto Center Pricing SSuper Dave Body Shop 3 Sep 25th, 05 7:54 PM
how to remove dash and gauges from 1969 elcamino?? 1969_elcamino El Caminos 7 Sep 24th, 05 5:10 PM
Dash Light Problem KAA Electrical & Wiring 5 Jun 5th, 05 10:23 AM
How to remove the padded dash? chevelless502 Interiors 2 Apr 22nd, 04 12:41 AM
70 El Camino dash SS vs non SS boondoggle_dave Interiors 3 Jul 17th, 03 9:47 AM
