muncie shifter linkage adjustments - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Jun 13th, 06, 9:01 AM
steelworker198 steelworker198 is offline
Default muncie shifter linkage adjustments
i'm restoring another chevelle I bought and this ones a 4 speed, it came as an original 4 speed car with the muncie 20 and its orignal shifter, the body is done trans and engine are in and now since i've been an automatic type i'm having a difficult time adjusting the trans linkages, i went into forum and there is several topics posted but none is real clear, also have service manual and its also not very clear, can anyone help??? i'd appreciate it, mike
My Showroom There's 2 types of people in this world, ones who own 1970 chevelles and those who want to!
Old Jun 13th, 06, 9:16 AM
huffhuff huffhuff is offline
Team Member
Default Re: muncie shifter linkage adjustments
make sure the correct levers are on the transmission. disconnect the rods from the shifter. insert a 1/4" drill bit in the shifter mechanism to line up the shifter levers. put the appropriate rods in place in the tranny levers (one at a time) starting closest to the transmission and working out. closest will be reverse. next is 1-2 and last 3-4 and adjust the length to fit into the shifter.
Old Jun 13th, 06, 12:17 PM
floyd66 floyd66 is offline
Tom Lloyd
huffhuff's description pretty much covers it.
I would like to point out that you do have the right linkage. The shop manual is a good source for orientation of the shifter linkage. I often see shifter rods on backwards.
When the drill bit (or 1/4 inch pin) goes into the shifter mechanism this positions all three levers in their neutral position.
Make sure the shifter is mounted in the final position.
Then put reverse into neutral by moving the lever on the Muncie. Adjust the rod to fit.
Do the same for 1-2, then 3-4. Done.
How do you keep you work space so clean? It looks fake! Beautiful car.
Tom Lloyd
my 66
take my advice, I'm not using it.
Old Jun 13th, 06, 12:34 PM
COPO COPO is offline
Mark
For Sale Brochures, Magazines, Service Manuals etc http://www.nastyz28.com/~copo/CarBrochures.xls
Web Site http://www.nastyz28.com/~copo/index.htm
WTB: 70 SS396 Canadian built car, 4-spd with ZL2 flapper hood, buckets. No rag tops,A/C or vinyl roof.
Old Jun 13th, 06, 8:14 PM
thanks for the info, the trans was just rebuilt locally, another question, should the trans go into gear without engine running? if so mine is not, thanks mike
  #6
Old Jun 13th, 06, 8:44 PM
MrBill66Malibu MrBill66Malibu is offline
Bill
Send a message via AIM to MrBill66Malibu
Mike, Yes it should go into gear with out the engine running. Do you have gear lube in it? I would put some in and turn it by hand a few times and then try to shift the gears. Sometimes things get a little stuck just sitting around.
Bill
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: muncie shifter linkage adjustments
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Muncie 4-speed Shifter bob cole Transmission & Driveline 5 Jan 12th, 06 10:04 AM
Hurst shifter versus Muncie bob cole Transmission & Driveline 3 Aug 21st, 05 9:42 PM
Muncie bench seat shifter & linkage info mockingbird812 Transmission & Driveline 14 Jun 6th, 04 6:37 PM
Muncie shifter linkage CT Mark Transmission & Driveline 0 Apr 6th, 03 1:37 PM
'69 linkage on '66-'67 Muncie. can you? Flye Transmission & Driveline 1 Nov 22nd, 02 1:03 PM
