factory tach wiring in 65 Chevelle - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Jun 12th, 06, 1:07 PM
earlc earlc is offline
Exclamation factory tach wiring in 65 Chevelle
I am installing a factory tach in place of the clock in a 65 Chevelle convertible and did not receive a wiring diagram. On the back of the tach it is marked + / - and S , I assume that the plus goes to the distributer side of the coil, the minus to ground and the S to the switch, am I assuming correct on this? Thanks for your help
Old Jun 12th, 06, 2:07 PM
undee70ss undee70ss is offline
Greg
Send a message via AIM to undee70ss
Default Re: factory tach wiring in 65 Chevelle
Is this a factory tach? Where did you get it? This is how i think it should be wired, + goes to a power source with the key on (You can use the IGN terminal at fuse box) - goes to a good ground and "S" is the sending, would go to distributer side of the coil, which would be the negative side. I would be sure of the wiring before connecting any wires.
Greg U
MY 70SS
Old Jun 12th, 06, 2:50 PM
That was my original thoughts also, seems to make sense that the S would be " sending " and the plus and minus would be self explanatory. It is supposed to be an original GM NOS tach and it was in a Box with a GM part number, it is brand new and never been installed before, but no diagram came with it, however it was wrapped in buble wrap which I doubt that they had in 65 but either way it looks original and fits fine.
Old Jun 12th, 06, 3:58 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
The factory wiring is only two wires, one for a keyed hot and one to the coil. The unit is grounded by being bolted to the instrument panel pod. Only the two mounting studs to the left and right sides are used, the one in the middle isn't connected to anything.
I will look up the diagram and post it when I get home later tonight.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jun 12th, 06, 5:54 PM
Thanks, I would appreciate it very much
  #6
Old Jun 12th, 06, 11:25 PM
Super Mod
Rich
I was wrong, the wiring uses the center stud and the one to the right (when looking at the rear of the tach).
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: factory tach wiring in 65 Chevelle
Human Verification
Similar Threads
69 factory tach question jtm60 Interiors 3 Mar 15th, 06 11:34 PM
Not Chevelle, Need 1979 GMC wiring Diagram asbill71 Electrical & Wiring 0 Mar 11th, 06 1:45 AM
71 SS Factory Tach Wiring dalejunior Electrical & Wiring 4 Jun 19th, 03 7:45 AM
65 C-10 tach wiring Steve67L-79 2002 2 Jul 9th, 02 9:25 PM
Hey John....how was a factory '72 SS tach triggered? riskyvt Electrical & Wiring 7 Mar 7th, 02 7:41 PM
