Spark plug boot protectors - Chevelle Tech
Auto Insurance
Old Jun 5th, 06, 1:52 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Default Spark plug boot protectors
I have a couple of spark plug wire boots which are very close to the header tubes or may touch the tubes if the wires are left to hang loose. I may have to cut the plug wire boots off and replace them with 135 degree boots but I'm curious about spark plug boot protectors such as these:
http://store.summitracing.com/partde...350109&FROM=MG
Will these sleeves still protect the boot/wire if the sleeves are in direct contact with a hot header tube? My headers are ceramic coated (Hedman calls it a "thermal" coating) but I'm sure they will still be hot enough to burn a bare wire or boot. If these boot protectors are tough enough to resist occassional direct contact with a header tube I might go that route as opposed to chopping off the existing plug boots.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jun 5th, 06, 1:57 PM
drums&cars drums&cars is offline
Trevor
Default Re: Spark plug boot protectors
I've had no problem with them touching hot headers. Had them like this for a good 2 years now and the sleeve or boot don't look burned at all.....
1968 Chevelle Malibu
355/th350, 3.08(bleh!) peg-leg 10 bolt
*Gen III 6.0L build back on! Eventual 4L80E backing it up*
2003 Tahoe 5.3/2wd
1997 GMC Suburban K2500 wif 454 power!
Old Jun 5th, 06, 2:28 PM
71454Chevelle 71454Chevelle is offline
Darren
Send a message via ICQ to 71454Chevelle
Rich,
Same as what Trevor said. I have been using them for several years and have had no problems (no burning).
I recently installed a new/different set of headers (Hooker to Hedman) and a couple of the Hedmans tubes come closer than the Hookers did. I'll have to keep an eye on them.
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
Old Jun 5th, 06, 4:25 PM
Troy70SS Troy70SS is offline
They are fine unless you have the boot pressing the protector directly against the header. The protector will survive OK but the heat conducted to the boot is still enough to damage it. As long as you have 1/8" or more air gap you should be OK.
Troy.
1970 454 SS
460ci Big Block,
Brodix Race-Rite Ovals (115 CNC chamber)
10.2:1 compression
Lunati/UD 276/284 Solid
Performer RPM Intake, Mighty Demon 850
TH400, 4.10's - BTE 10" 3200 conv.
Mostly show but can go!
Best ET 11.72 MPH 115.1
Old Jun 5th, 06, 4:52 PM
66chevyIISS 66chevyIISS is offline
Send a message via ICQ to 66chevyIISS Send a message via AIM to 66chevyIISS Send a message via MSN to 66chevyIISS
I use them and they work great, the only problem I ran into is over time it dries out the wire and it will start to crack.
1966 Nova Super Sport 388, Th350, Moser 9" 3.70 locker w/ caltracs
66 Nova pic 1.84 60ft 1/8: 7.85@89.49mph 1/4: 12.25@111mph
1966 Chevelle 350 TH350
66 Chevelle pic
  #6
Old Jun 5th, 06, 7:50 PM
Hi-po SS 454 Hi-po SS 454 is offline
Richy Rich
Send a message via AIM to Hi-po SS 454
Troy.
This is exactly what happen to me. I had 2 boots on and both wires were adjusted to stay off header pipe. But one found its way onto the header. I don't how long it was there, a few days at least. The boot was brown in that area it touched the pipe, BUT the wire insulation was burnt badly..If anybodies wire boots are laying on the the header pipe check it out, the wire should be burn't from excessive heat transfer..
Rich
71 SS clone, MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
https://www.youtube.com/watch?v=VzkB7RTVDUc
  #7
Old Jun 5th, 06, 8:57 PM
72 Orange 72 Orange is offline
I only needed one of the set of 8 I bought of that exact set you linked to. If you'd like to buy a couple from me shoot me a PM.
Chevelle Tech > General Tech Area > Performance      Current Topic: Spark plug boot protectors
Human Verification
Similar Threads
One bad spark plug Autoengineer Engine 2 May 6th, 07 2:38 AM
#7 spark plug on Brodix Oval Heads rednecks70 Engine 4 May 19th, 06 9:28 PM
Spark plug ?'s 9SecBuick Performance 3 Apr 15th, 06 12:02 PM
Spark Plug Selectoin dave_silva Performance 0 Mar 16th, 05 7:43 PM
Spark Plug Boot Configuration NITRO Restoration Corner 5 Apr 20th, 04 3:39 PM
