Idle circuit not working - Holley 600 - Chevelle Tech
Auto Insurance
Troubleshooting Diagnosing problems done here.
Old May 31st, 06, 11:08 AM
cobra2411 cobra2411 is offline
Default Idle circuit not working - Holley 600
Just rebuilt a holley 600 VS carb for my 70 and it looks like the idle circuit on one side isn't working. Finally got it starting and I've got nothing in cyls 1,7,4,6. It's on a Performer manifold.
Carb's been sitting for a long time and was very dirty before I rebuilt it. Guess I'm buying a can of carb cleaner and taking it apart again...
Any tips on what to look for? This is my first holley rebuild. Model number is 1850-2.
David
P.S. I know it's not an ignition problem because if you get it off the idle circuit it does run on all 8.
-=1970 Malibu - 454, 4spd, 3.73 12 Bolt Posi =-
http://www.middletoninv.com/Chevelle
Old May 31st, 06, 11:57 AM
Default Re: Idle circuit not working - Holley 600
Ok, update... It's the idle air passage that's clogged on the one side. I had it sitting in laquer thiner for a day before I rebuilt it... Though that'd clear it up... Any tips on removing the plug on top without F'ing it all up?
The main reason for this is that while I have plenty of carbs laying around, none are rebuilt. I didn't want to but a freshly rebuilt carb on the 454 to break it in... Also I had the performer manifold and a gasket set so....
It does look pretty though... It's amaizing what a little paint and elbow grease will do...
David
Click image for larger version
Old May 31st, 06, 4:20 PM
I found a self taping screw that was just the right size, threaded it in and was able to get the plug out. I used a guitar string (.009") to poke the hole clear. It runs now, but it's blowing smoke when I rev it, so I think I've got a sealing problem...
The screw is the kind for taping drilled holes and is flat on the bottom and has a pie shape cut out of the side and is slightly tapered at the end.
It's always funny how as soon as you order a replacement part you're able to fix what you've got...
David
You may not post new threads
You may not post replies
Similar Threads
Holley 3310 idle problems mike67sd Performance 8 Mar 22nd, 06 8:29 PM
Help Tuning Holley 750DP 4 Corner idle bigmike69ss Engine 1 Mar 1st, 06 1:47 AM
Idleing prob with UD 288/296F10 and 950HP C.W.Mellow Performance 18 Nov 25th, 03 2:59 PM
oversized carb and single-plane intake bowtie455 Performance 10 Nov 19th, 03 4:27 AM
does jetting affect idle quality (switched 750DP to 950HP)? 19_chevelle_71 Performance 11 Nov 9th, 03 8:18 AM
