1 1/4 Inch Front Sway Bar ?????? - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old May 28th, 06, 9:41 AM
htm htm is offline
Default 1 1/4 Inch Front Sway Bar ??????
Hello everyone,, I am hoping someone out here might be able to help me id this sway bar, I purchased from our classified ads, but did not ask enough questions my bad...anyway I matched it up to my stock chevelle sway bar and it appears to match up,, maybe a tad longer, but I have failed trying to get bushings for this big boy, my research says the largest mine should be is 1 inch.. this bar barely fits in the brackets, so if anyoone has a clue what this might be out of so I can sell it with the proper info
Tom
1967 chevelle Project
My Showroom
Old May 28th, 06, 9:46 AM
Derek69SS Derek69SS is online now
"The Stig"
Default Re: 1 1/4 Inch Front Sway Bar ??????
It's most likely a 2nd gen Trans Am bar, which bolts right on a Chevelle.
You'd probably have the best luck getting poly bushings for it from PST or Energy Suspension.
Derek Kiefer, member of Minnesota's Northstar Chevelle Club
69 Malibu Pro-Touring stroker LS1-383/T56 - 69 Chevelle SS396 325/3spd
Old May 28th, 06, 10:08 AM
htm htm is offline
Thanks for the quick response, its sounds like you have experanced this before as far as the bushings go will they fit into the stock mount ? it only looks like there might be a 1/16 of an inch on each side available or do i need a bushing and bracket... are the links the same ?
Tom
My Showroom
Old May 28th, 06, 10:19 AM
Xtreme70SS396 Xtreme70SS396 is offline
Mark
I'm running a 1-3/8" Hotchkis. I think there are all sizes available now, just with different brackets and bushings as you said. I think the end links are pretty much the same.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Old May 28th, 06, 10:22 AM
"The Stig"
I would use these bushings to mount it. http://store.summitracing.com/partde...5&autoview=sku They worked in the factory holes for me.
I don't recall what length ends you will need, but I had to use different ones (longer or shorter, I don't remember) to keep it from contacting the outer tie-rod adjusting sleeve.
  #6
Old May 28th, 06, 10:27 AM
htm htm is offline
Great Thanks a million !!!!!!!
Tom
My Showroom
  #7
Old May 28th, 06, 11:25 PM
71350SS 71350SS is online now
Another option is to get the bushings and frame brackets for 78 or 79 Trans Am from a pontiac or GM parts dealer.Thats the way I did it.I picked a year that had the same size bar as mine, called and ordered them.2 brackets and 2 bushings came to less than $20.
John
71 El Camino SS
406 SBC M21 3.31 12 bolt
  #8
Old Jun 1st, 06, 10:51 AM
Brob Brob is offline
Gold Member
Rob
As I remember there are two larger sizes 1 1/8 & 1 1/4" The 1 1/8 is recommended for street use. I wont be able to check until next wensday, I may have a set of polly bushings from energy suspension Let me know if you have
1 bar you can have them for the price of postage
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: 1 1/4 Inch Front Sway Bar ??????
Human Verification
Similar Threads
Front Sway Bar, 69 bdss396 Brakes, Suspension & Steering 3 May 5th, 06 2:40 AM
rear sway bar instructions JFC69-70 Brakes, Suspension & Steering 5 Oct 18th, 05 7:45 PM
Sway bar vs. drag link echristie Brakes, Suspension & Steering 8 Sep 9th, 05 11:44 PM
Broken Hotchkis rear sway bar 69chevellew/LT1 Brakes, Suspension & Steering 5 Aug 4th, 05 8:53 PM
Time to order: 1-1/4 or 1-1/8 front sway bar? Rich-L79 Brakes, Suspension & Steering 11 Nov 12th, 04 11:29 PM
