Torque Specs - Chevelle Tech
Auto Insurance
Old May 27th, 06, 12:17 PM
66lover 66lover is offline
Default Torque Specs
Trying to find torque specs for oil pump, flywheel, pressure plate on a 66 396
Old May 28th, 06, 7:28 AM
dirtrocker dirtrocker is offline
Kevin
Send a message via Yahoo to dirtrocker
Default Re: Torque Specs
Big Chevy
Fastener Type Torque Specs
Main cap bolt, 396-427 2-bolt 95 ft.-lbs.
Main cap bolt, 396-454 4-bolt (inner/outer) 110 ft.-lbs.
3/8 in. connecting rod bolt 50 ft.-lbs.
7/16 in. connecting rod bolt 67-73 ft.-lbs.
Cylinder head bolts, long 75 ft.-lbs.
Cylinder head bolts, short 65-68 ft.-lbs.
Screw-in rocker arm studs 50 ft.-lbs.
Intake manifold bolts (cast iron head) 25 ft.-lbs.
Oil pump bolt 65 ft.-lbs.
Cam sprocket bolts 20 ft.-lbs.
Harmonic damper bolt 85 ft.-lbs.
Flywheel/flexplate bolts 60 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Bellhousing bolts 25 ft.-lbs.
Exhaust manifold bolts 20 ft.-lbs.
1971 chevelle SS conv. dark rosewood metallic w/ black top/stripes/int. 402/4sp bench. Under resto.
1965 Chevelle Malibu 4dr Wagon, 283, pg, ps, air.
1984 Buick GN
http://imageshack.us/photo/my-images...kle142hs1.jpg/
Chevelle Tech > Mechanical > Engine      Current Topic: Torque Specs
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Torque specs shaddow Chevelle Tech 3 Mar 31st, 06 2:13 PM
Torque specs for super T-10? Black1972 Transmission & Driveline 3 Jan 29th, 06 9:49 AM
scat I beam torque specs needed 94guy Performance 6 Dec 14th, 05 1:54 PM
torque specs for differential? Jim Mac Transmission & Driveline 2 Oct 18th, 05 8:56 PM
Torque Specs for Alum Intake? Mike O'H 2003 3 Jul 15th, 03 8:03 PM
