Specs for ZZ3 crate motor?? - Chevelle Tech
Auto Insurance
Old May 21st, 06, 10:14 PM
oldchev oldchev is offline
Joe
Default Specs for ZZ3 crate motor??
The guy I bought my car from told me it has a ZZ3 crate motor in it. It has the aluminum heads and looks like it is the ZZ3. My question is does anyone know the specs on the ZZ3? I know it is an older version of the ZZ4, but I can't find find any info about the internals. Anything would help. Thanks!
1969 Chevelle 300 Deluxe
Old May 21st, 06, 10:31 PM
Redrum Redrum is offline
Gold Member
Default Re: Specs for ZZ3 crate motor??
I did a quick internet search using zz3 engine and got a ton of hits... here is one of the first.
This engine kit was built by GM for the Camaro. It's aluminum heads and intake, 345 horsepower, street legal high flow dual catalytic converters, dual snorkel air cleaner, computer and chip combination, make for a complete engine swap kit which should not be overlooked. This kit was created for the Camaros equipped with the 1983-86 L69 (VIN "G") or 1982-87 LG4 (VIN "H") engines.
Another -
Chevrolet engineers have developed an emission-legal conversion kit to install a High Output 5.7-liter (350ci) small-block V8 in a 1982-87 Camaro originally equipped with an LG4 or L69 305ci V8 engine and a 700R4 automatic tranmission. This coordinated package of components significantly improves vehicle performance while retaining all required emission controls.
Performance: During development of the HO 350 Camaro conversion, a prototype HO 350 engine equipped with a computer-controlled Quadrajet carburetor and all emission controls required for this application, produced 308 horsepower (at 5000 rpm) and 365 lb-ft torque (at 3500 rpm). The Chevrolet Raceshop's 1987 Camaro test vehicle equipped with an emission-legal HO 350 ran a quarter-mile elapse time of 13.83 seconds at 98 mph.
Certification: When all components are installed as specified in the instruction manual, the HO 350 conversion meets emission requirements under EPA Memorandum 1A for operation in 49 states (excluding California). The conversion is also legal for sale and use in California under California Resources Board Exemption Order #D-278. Note the entire HO 350 conversion package must be installed exactly as described in the manula to comply with emission regulations. Also note that this conversion is certified only for the specific year models, engines, and tranmission listed above.
Installation: The HO 350 conversion is designed for "do-it-yourself" installation. A comprehensive instruction manual is included. Minor welding is required to install the exhaust system. The HO 350 Camaro conversion is a coordinated package of components that work together to improve vehicle performance. Major assemblies include: Engine: The heart of the Camaro conversion is the HO 350 Chevrolet small-block V8 (P/N 24502609). High performance engine assembly has been updated with new hydraulic roller camshaft profile, a low-profile dual-pattern intake manifold, revised valvetrain components, and other improvements.
Air Cleaner: The HO 350 Camaro breathes through a dual-snorkel air cleaner. A "ram air" system channels cool air to the carburetor through flexible air ducts. Fuel Pump: A high-volume in-tank electric pump meets HO engine's fuel requirements. The pump kit includes vent lines, a sending unit, and a wiring harness. An adjustable external regulator controls fuel pressure.
Exhaust System: The HO 350 conversion package includes a low-restriction exhaust system with dual catalytic converters, high-flow exhaust manifolds with 2 1/4" outlets, a single 3" diameter tailpipe, and a transverse muffler.
Calibration: The kit includes an engine control module (ECM), specially programmed PROM chips, a coolant fan switch, an electric spark control (ESC) module, and Quadrajet secondary metering rods.
I want to die in my sleep like my grandfather...
January 2004 Feature Chevelle
69 SS Chevelle, Pro-Touring, 600+ HP/TQ; A/C, P/S, P/B
1300 Watts of stereo and 11.90 at 118.46 MPH on Goodyear Eagles.
My Showroom
Not screaming and yelling like the passengers in his car.
Old May 22nd, 06, 12:50 AM
Schurkey Schurkey is offline
Gold Founding Member
My '94 GMPP Catalog says the p/n was 10185072.
345 hp/ 387 tq. 9.8 compression, pink rods, 1053 forged crank, Hyper pistons, roller cam.
10 BTDC initial timing, AC FR5LS plugs. Redline at 5800. 92 octane fuel.
Chevelle Tech > Mechanical > Engine      Current Topic: Specs for ZZ3 crate motor??
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
454 crate motor or rebuild? jghoppes Performance 19 Nov 6th, 06 9:43 PM
Got a beehive problem! (crate motor big block guys read this) 69-CHVL Performance 11 Aug 9th, 06 7:59 AM
Fit a gm crate motor in a 1969 velle ss rubadub Engine 9 Oct 16th, 05 12:34 AM
454 aluminum head crate motor rubadub Engine 27 Sep 11th, 05 12:12 PM
Need LS-7 Crate Motor Info Please! Steve.Lorello 1999 -- 8 Jun 4th, 99 5:53 AM
