weird harmonic balancer problem - Chevelle Tech
Auto Insurance
Old May 6th, 06, 5:17 AM
dreis454 dreis454 is offline
Dan
Unhappy weird harmonic balancer problem
Ok I just completed A cam change in my 454. When installing the balancer I noticed that
1. It was going in very hard
2. when the balancer is seated properly, the drive belts will no longer line up correctly.
3. I pulled the balancer back out & there was no marks on it where the timing cover seal was riding on the balancer.
4. When the baalancer is installed so the belts line up, The timing tab on the cover is barely next to the balancer.
Before the cam change the belts lined up & the engine did not leak oil & now I can't remember what the position of the pointer in relation to the balancer was.
At this point I have to beleive that the balancer was not fullt seated to maintain belt alignment because of the lack of a seal mark on the balancer.
Anyone ever seen this before?
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 547hp @ 5400 & 567tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old May 6th, 06, 2:49 PM
GetMore GetMore is offline
Default Re: weird harmonic balancer problem
On my small blocks the timing pointers go out to the edge of the balancer. Seems really stupid, but that's how they are.
Are you sure your crank gear is seated properly?
Old May 6th, 06, 6:11 PM
Just_Another_Mike Just_Another_Mike is offline
Mike
Are you using a balancer installation tool? I hope so. If you are whacking it in with a piece of wood to absorb the shock of the iron mallet, I can understand all of your problems. As for #3, you shouldn't see any markings unless you put lube or some other goop on the seal or the outside of the balancer. I don't understand question #4.
Mike
my bottomless pit
Old May 7th, 06, 7:55 AM
Dan
Good ideas but I am using a installtion tool & the gear is seated. I have done this numerous times before but I've never seen this... I put it back together the way it was & it runs great & no oil leaks. It just doesn't look right to me.
TC#3095
Old May 7th, 06, 9:06 AM
LevonH LevonH is online now
Moderator
Levon
Are you sure the crank gear is on the correct way? The raised shoulder may be stopping the balancer if backwards.
Or has the crank key "cocked" which would only allow limited travel?
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed (Current Engine VortecPro 460 (513 HP) Original is resting
1966 427 Corvette SOLD
1973 Camaro IHRA Hot Rod (LS-6 Auto)11.00 @121 (Chased a 10.99 or better) SOLD
Priddis, Ab. Canada
My Showroom
  #6
Old May 7th, 06, 9:22 AM
Mike
Well, if it runs good and the belts aren't crooked or being thrown, I wouldn't worry. The last time I used a stock timing cover on a BB, I do remember that when the balancer was all the way on, the timing mark tab edges were practically unreadable at the front edge of the balancer. However, at a angle, I could get a gun on the mark and set the timing.
Mike
my bottomless pit
You may not post new threads
You may not post replies
Similar Threads
ZZ502 Harmonic balancer and Flex plate. Dave I Performance 4 Jan 30th, 06 10:40 PM
Harmonic Balancer suggestions Hi-po SS 454 Performance 21 Jan 26th, 06 6:22 PM
Harmonic balancer removal knudsonm Performance 8 Jan 17th, 06 10:48 PM
Harmonic Balancer Problem...Advice? hilks 2004 3 May 29th, 04 11:45 PM
Remove Harmonic Balancer MikeD70Malibu 2002 4 Apr 15th, 02 7:49 PM
