Solid roller cold lash setting? - Chevelle Tech
Auto Insurance
Old Apr 30th, 06, 12:39 PM
bbcvelle bbcvelle is offline
Question Solid roller cold lash setting?
Lunati cam solid roller 502A1LUN. Valve lash IN/EX: .022"/.024"
What would be best to set cold lash to? Thanks
Old Apr 30th, 06, 1:16 PM
BillK BillK is offline
Super Mod
Mr Bill
Default Re: Solid roller cold lash setting?
BB,
The best way to do this is to set it a few thousanths loose, then start the engine and get it good and warmed up. Once it is warm, set the valves to the proper hot lash spec. Then, let it cool down overnight and check it. You will see how much it changes when it cools off and the next time you can set them cold based on that.
The amount that the lash changes will be different from one engine to another, depending on head material etc. The best way to do it is to set it hot, but on a street driven engine you can get close enough with the method above.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
1984 Buick Riviera - original owner (Wife's car)
Team Chevelle #100
Old Apr 30th, 06, 2:08 PM
Wolfplace Wolfplace is offline
Mike
What heads??
Aluminum .004-.006 tight
Aluminum heads & block, .012 tight
Cast I set at spec to .002 loose.
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
Chevelle Tech > Mechanical > Engine      Current Topic: Solid roller cold lash setting?
Human Verification
Similar Threads
hdr roller or solid that is the question ? fowl69 Performance 18 Sep 28th, 05 9:45 PM
need a small solid roller Harold. aaronz28 Performance 8 Aug 26th, 05 9:45 AM
Lazy Man's EO/IC Method for Setting Valve Lash kmchugh Engine 9 Jun 2nd, 05 12:55 AM
Setting valve lash on hydraulic lifters Patrick Bellene Performance 4 Mar 19th, 05 12:46 PM
valve lash ? cold vs. hot 77 cruiser Engine 8 Oct 12th, 02 4:40 PM
