High gear timing retard - Chevelle Tech
Auto Insurance
Old Apr 25th, 06, 3:07 PM
bracketchev1221 bracketchev1221 is online now
Default High gear timing retard
Does anyone have any experience with these? I am putting the start retard with the single stage timing retard, for ease of starting with the locked out dist. I have heard that on a n/a motor, not a nitrous motor, that pulling timing out upstairs helps make power. Has anyone seen this first hand and how much timing did you take out. I want to run the car at 0 first and then try it from there.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
Old Apr 25th, 06, 4:11 PM
d1_bradley d1_bradley is offline
Dave
Default Re: High gear timing retard
"Back in the day" they used to run a dual point distributor and used the second set only to retard in 4th gear. Some guys said it was worth a tenth or two. Never did it in any of our cars. My guess is that there's a writeup on the Internet on how its done. Everything else is out there..........
Dave Bradley
Old Apr 26th, 06, 9:01 AM
Does anybody have one of these things?
Ray
Old Apr 26th, 06, 3:29 PM
Mike Feudo Mike Feudo is offline
I made one using a factory dual point dist and an early CD ign. I could find no difference in the performance but it was a bracket car and it didn't have a dead kill engine in it.
Old Apr 26th, 06, 4:16 PM
SSchevy400 SSchevy400 is offline
Send a message via AIM to SSchevy400
I'm thinking about gettin one also, more for the starter saver tho. Any help would be nice
70 Nova SS
383 Cubes, de-stroked
13.8:1 pistons
Comp Cams Solid 288/550 lift/ground on a 106
TH350
12 bolt 4.56s
http://www.cardomain.com/id/sschevy400
AOL/AIM screen name: SSchevy400
  #6
Old Apr 26th, 06, 9:46 PM
That's mainly why I got mine too, but I was curious about using the other stage or just forget it and leave it at 0.
Ray
  #7
Old Apr 26th, 06, 11:04 PM
73_ss_496 73_ss_496 is offline
i dont know if we are talking about hte same thing but i am using a timing computer from MSD with my locked out dist. i can adjust timng curve base and total with it and it has a place to plug modlues in to pull timing . i started with the 2 degree module in it . and went to the 4 degree ( 4 degrees out of my total) and the car ran smoother when crusing but did not pull as hard on the big end ( i turn mine 7400) good luck
73 496 CI chevelle ss
  #8
Old Apr 27th, 06, 7:14 AM
383Malibu 383Malibu is offline
Roger
We run a crank trigger (locked timing) and the MSD-8982 retard box. We take 4 degrees out in 5th gear and see about .2 mph improvement and negliglible et improvement (i.e., change is within the degree of error for the samples).
Roger Copeland
"Only a rich man can afford cheap parts, because he can afford to replace them."
R&R Racing
Chevelle Tech > General Tech Area > Performance      Current Topic: High gear timing retard
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
New Timing Gear with New Cam? Brad Engine 1 Mar 14th, 05 11:18 AM
TOTAL Distributor advance----with or without vacuum DZAUTO 2004 14 Aug 27th, 04 5:28 PM
Initial timing with new timing gear set DaleM Engine 3 Mar 4th, 04 6:49 AM
Ignition Firing Timing... jgoggan 2003 58 Nov 21st, 03 6:56 PM
Timing Chain to Gear Drive - UNBELIEVABLE! - HELP! Danspeed1 Engine 6 Nov 11th, 02 2:23 PM
