Any Issues with Locked-out timing - Chevelle Tech
Auto Insurance
Old Mar 21st, 06, 6:03 AM
71454Chevelle 71454Chevelle is offline
Darren
Send a message via ICQ to 71454Chevelle
Default Any Issues with Locked-out timing
I was thinking about locking out the timing on my car. The last several years its been just street driven, but I'm hoping to find some time this year to get a couple of outings down the 1320.
I'm using a 6AL MSD box, a 85551 Pro-Billet distributor and an MSD 8970 Multi-step retard box with a 25 degree retard start (which I will use).
I was wanting to cleanup the idle a little and looking for abit more low speed throttle response.
Is there any other issues with running locked out timing on the street other than starting?
Thanks in advance.
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
Old Mar 21st, 06, 10:31 AM
jbird jbird is offline
wannabe
Default Re: Any Issues with Locked-out timing
I just locked out the timing on my Camaro. same box and Pro Billet dist. I have 14:1 compression, and at least in my shop, it has no problems starting. I use a summit mini starter. I guess if the engine were real hot it may, but not so far. I run 37-38*. It idles MUCH better, I can't see any drawbacks. You do not have a vacuum advance, right?
Jay Campbell
Campbell Competition Motorsports
Old Mar 21st, 06, 11:06 AM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Same box, same distributor, MSD crank trigger...locked at 37 degrees.
No problems starting...hot or cold. No start retard box either.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
Old Mar 21st, 06, 11:46 AM
Darren
Jay,
Correct, no vacuum advance.
I wasn't sure weather I would need the start retard hooked up or not, I figured I have it, might as well use it.
I don't have near the compression that you do, only 10:1. I'm also using a Tilton mini started with a 1000 cold cranking amp battery.
I was going to shoot for about 37 to 38 degrees locked.
Also..............if I do decide to lock the timing, I do away with the springs and weights right?
Darren
1971 Chevelle
496
10.5 scr
525++ rwhp
Old Mar 21st, 06, 11:48 AM
LAUGHING RAT LAUGHING RAT is offline
No Issues With Mine Locked Out At 38 Degrees. Msd 6al And Dist. And Timing Computer And Retard Control.
67' CHEVELLE 3700 LBS.(W/DRIVER)
460 B.B.
6.27@111.62 ON NITROUS 1/8 MILE
9.82@137.39 ON NITROUS 1/4 MILE, 6.86@100.25 MOTOR ONLY 1/8 MILE
10.81@123.69 MOTOR ONLY 1/4 MILE
1.47 - 60' .004 R/T
  #6
Old Mar 21st, 06, 12:17 PM
wannabe
Originally Posted by 71454Chevelle
Jay,
Yes, look in your documentation for the instructions. It's an easy deal, but you do have to remove and reinstall the dist. gear. Not a big deal at all.
Jay Campbell
  #7
Old Mar 21st, 06, 1:54 PM
Strip Poker 388 Strip Poker 388 is offline
Team Member
Rob
I have 3 engines/cars all locked out.I like the idle alot better.I would hook up the retard .it just makes it easy on the starter!!
Plan B Kill It With Fire
http://i19.photobucket.com/albums/b1...ps516f6e1a.png
  #8
Old Mar 21st, 06, 2:02 PM
Yellow68SS Yellow68SS is offline
mines locked out as well, my start retard only retards 10* but i do use it.
2 possible drawbacks i noticed when i locked it out. The thing is harder to start when its cold and been sitting a while but not a big deal. The other thing is that if my battery doesn't have a pretty good charge it will just crank and never fire. Its not like other motors were if the battery is low and is cranking slow it will just fire right before the battery gives out. I got stuck in the staging lanes cause my bottle heater was on and took too much juice . But it looks like you have a better battery so go for it, ill never run a curved distributer again.
Kyle
68 Camaro, 468, 11.5:1, ProSystems HP1000, Victor Jr, AFR 305, 264/275 @0.050, Th-400 with brake, converter flashes to 4800, 3.73's.
9.93 @135.78
  #9
Old Mar 21st, 06, 7:11 PM
68softtop 68softtop is offline
I have mine locked out as well, 34 degrees. Idle quality & throttle response are great. No real issues with cold starts even though I have a retard box that kicked the bucket after only one year of service
Ron
68 Chevelle Conv. HT383 430HP/490TQ 9.5/1 Comp, Vortec Heads, LT4 Hot Cam, RPM Air Gap Intake, Demon 750 Mech. Sec, MSD Ignition. Trans - 2004r. Converter - CK Performance 3000 w/Lockup. Rear - 3.73 10 Bolt Posi, Nitto Drag Radials 275/50/15.
  #10
Old Mar 21st, 06, 9:22 PM
Pro67Chevy Pro67Chevy is offline
Jim
Send a message via AIM to Pro67Chevy
I did not realize this was such a popular thing to do. What are the benefits of locking out the timing? What circumstances cause this to be better than a curve? I have the same box and distributor (8555) and with the curve being so easy to custumize...why lock it out?
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
"It's all in the smoke!"
Video 1 Video 2
No time slips yet, 2013!!!
  #11
Old Mar 21st, 06, 10:57 PM
ejrempel ejrempel is offline
I locked mine out, and the whole deal just became so much more stable, idled better, everything better except maybe gas milage. It is a breeze to put the timming light on it now. Just try it with a solid roller from a dragster motor with the weights jumping all over the place. Impossible to time.
"We try to at all times at least assume that the world is not being properly run." Paul Singer (Elliot Management)
  #12
Old Mar 22nd, 06, 1:45 AM
sixtysixss sixtysixss is offline
Justin
I locked mine out one day at the track (MSD HEI Pro Billet) when I noticed it was about 15 mph slow. Turned out the weights were binding up so I just locked it out at 36*. Been running great for over 5 years since. The car idles rock steady now also. Throttle response didn't really improve, but I think it's in the carb. Oh, no starting probs either.... Kragen battery and Delco starter.
1966 Chevelle Malibu
383 700R4 Daily Driver
1966 Chevelle SS - SOLD
11.81@119.6
  #13
Old Mar 22nd, 06, 11:03 AM
Jim
I don't understand how a car idles at 36*. How is that possible?
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
  #14
Old Mar 22nd, 06, 11:27 AM
"Wild Bill"
Very simple and does so well.
Is your vacuum advance plugged into a manifold vacuum source? Almost the same results...with the engine at idle.
  #15
Old Mar 22nd, 06, 12:05 PM
Jim
Car is not running yet but it will have no vac advance. I knew it bumped it a few degrees but I didn't realize it was that much. Maybe locked-out timing is worth playing with when I'm done.
And there is no pinging? I will be running 94 octane with 10.7 comp. closed chamber heads and small dome pistons.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
Chevelle Tech > General Tech Area > Performance      Current Topic: Any Issues with Locked-out timing
Human Verification
