Transmission Will Not Engage I Any Gear?? - Chevelle Tech
Auto Insurance
Troubleshooting Diagnosing problems done here.
Old Feb 27th, 06, 3:30 AM
Marxx Marxx is offline
Question Transmission Will Not Engage In Any Gear??
Hello, i have a 402 big block with a turbo 400 trans and the trans will not engage. I just finished installing a rebuilt tilt column and do not know if the neutral safety switch can be causing this, it starts in park only not neutral, the shift linkage is connected to the column? I also removed the TCS system from my car since it was missing most of the parts, in doing this i removed the TCS relay/solonoid that is attached to the wire harness gutter on the firewall, could this be the problem? The trans was working normally before i did this work, so i'm wondering what the problem is, could i have the neutral safety wires connnected wrong? Any help would be appreciated.....
Old Feb 27th, 06, 10:00 AM
Dean Dean is offline
Moderator
Default Re: Transmission Will Not Engage I Any Gear??
NSS wiring can't keep the transmission from going into gear, the switch only keeps the starter from operating when the selector is NOT in neutral or park.
Sounds like the linkage needs to be adjusted.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
Old Feb 27th, 06, 10:33 AM
Do you think removing the tcs system can do it? How do i go about adjusting the linkage, it is a column shift car?
Old Feb 27th, 06, 10:43 AM
Moderator
naa, don't see how it could.
Guess I should ask "what kind of car?" but still ASSUMING, there is a hex headed bolt under the car where the two shift rods meet.
You loosen the bolt which lets the two rods slip farther together or apart.
in short;
Put the tranny in park
Put the column in park
Tighten the "set screw" hex headed bolt.
My 69 SS
My 70 Convertible
Old Feb 27th, 06, 11:04 AM
Its a 1970 chevelle. Ok i will try to adjust it later when i'm off work, thanks for the advice....
  #6
Old Feb 27th, 06, 6:31 PM
bisjoe bisjoe is offline
Make sure the short vacuum hose from the carb to the metal tubing going down to the trans is not cracked or kinked.
'72 El Camino 350/TH350/330hp driver (For Sale)
'96 Explorer Winter/Backup vehicle-Wife's '02 Liberty-Son's '94 Dakota Sport
  #7
Old Feb 27th, 06, 7:13 PM
p-hanny p-hanny is offline
Default Re: Transmission Will Not Engage In Any Gear??
Sounds simple like missadjusted? or out of fluid?
HANNY
`72 ss 454 frame off
`71 671 blown malibu ss clone
http://img306.imageshack.us/my.php?i...sc012736ss.jpg
http://img315.imageshack.us/img315/3660/dsc011508mw.jpg
  #8
Old Feb 28th, 06, 1:21 AM
Thanks for the help guys, stupid me the trans was low on fluid, i had also done a trans service and i had the pan off for like 3 days and i think all of the fluid drained out, i put 4 qts of atf but it was still very low, i had to add almost 3 qts! Thanks again....
  #9
Old Feb 28th, 06, 9:34 AM
Moderator
Guess I was barking up the wrong tree.
I never associated replacing the steering column with being low on fluid.
Glad you got it working.
My 69 SS
My 70 Convertible
Chevelle Tech > Mechanical > Troubleshooting      Current Topic: Transmission Will Not Engage I Any Gear??
Human Verification
