View Poll Results: To have c clip eliminators installed or not?
Yes 105 57.69%
No 77 42.31%
Voters: 182. You may not vote on this poll
Old Feb 4th, 06, 1:35 AM
chevydog66 chevydog66 is offline
Jason
Default C Clip eliminators or not?
I have heard that they can leak and wear out prematurely with regular street use. Is is good insurance to have them installed or not? How many of you guys have them or recommend them?
2 wrongs don't make a right but 3 lefts do!!
http://www.cardomain.com/id/chevydog66
The new 406 is done!!!
66 Chevelle Malibu 406ci sbc all motor 10.92 @ 123mph, 1.50 60', 3440lbs.
72 GMC Super Custom 1500
96 Chevy Silverado Z71
00 Haulmark 24' trailer
  #2
Old Feb 4th, 06, 2:21 AM
SS_Sean SS_Sean is offline
It IS a Malibu!
Default Re: C Clip eliminators or not?
With a ten bolt rear? Why waste the money?
Sean Thomas
1978 Chevy Malibu
10.49@128mph, 1.44 60'
1986 Buick Grand National 3.8 liter SFI Turbo
The maserati of the trailer park!
Old Feb 4th, 06, 2:24 AM
Jason
No not a 10 bolt. I am getting a new 12 bolt built for my car.
Old Feb 4th, 06, 3:59 AM
chevguy65 chevguy65 is offline
Banned
Carl
You shouldn't need them on a 12 bolt.
Old Feb 4th, 06, 7:51 AM
forcd ind forcd ind is online now
Team Member
as everything else, it depends on usage and horsepower-if its mainly a street car, i would get the c-clip aftermarket axels, around $200 and their a little better than 35 year old axels-serious track stuff, then theirs a better chance of breaking an axel, and w/o c-clip eliminators and if you were to break an axel, you could have damage-you might want to look into one of the new 12 bolts, weigh that cost against buying an orig 12 bolt, adding axels, changing gears, rebuilding posi, etc-your gonna be close
when your credit cards are maxed, have the limits raised
  #6
Old Feb 4th, 06, 9:42 AM
DOUG G DOUG G is offline
If you're having a rear "built" then go with the Ford ends (Moser carries). Bearing is pressed on to axel shaft and retained by a bolt on plate.
Doug G.-406ci
Camaro Pics AKA: RedЯum
1.643 - 60'
7.511 @ 91.33 -660'
11.823 @ 113.52 -1320'
  #7
Old Feb 4th, 06, 11:57 AM
Motor Martyr Motor Martyr is offline
As Doug said, if you are buying a brand new rear, have them install Ford Style housing ends.
Moser offers them with a Chevy 4-bolt pattern so your brakes will fit with only minimal grinding to allow removal of the axles.
C-clips are dangerous, regulardless of the type of rear, i've seen alot of damage done by those who choose to use them.
Most cars that break a c-clip ruin the quarter panel and bang up the frame under the side of the car from landing and sliding on it.
Some are worse, if they break the c-clip slightly after the starting line and are going at some speed, they usually head for the wall.
The safety of the guy in the driver seat and that of the car and driver next to him are the most important thing. At the shop i work at, safety is the primary function of design.
I've over-engineered my own drivetrain. Ford housing ends on a 12-bolt. 1350 u-joints and a Denny's Nitrous Ready driveshaft and 1/2" studs.
Round tube 4130 driveshaft loop triangulated at the mounts.
Doing it again, i would have went with 5/8" drive-studs and at probably 33 spline axles.
  #8
Old Feb 4th, 06, 2:20 PM
camaroman7d camaroman7d is offline
Royce
If the car will have sticky tires and/or makes decent power, I would suggest c-clip eliminators.10 or 12 bolt doesn't matter, if the axle breaks or the cross pin wears you will have a wheel trying to exit the car. I ran Moser c-clip eliminators on the street for several years before I sold the car and as far as I know they are still holding up fine. Sure the better option is ford housing ends, but your budget and ability are the limiting factors. If you are just trying to make your present rear end safer, then go with eliminators. It's easy for other people to spend your money. I have yet to hear anyone on here give a reason not to use eliminators or anyone that has had problems with them.
If you are starting from scratch and building a new rear end or looking to buy one, then by all means get large Ford ends.
Royce (NO XQSSS) Bradley
http://community.webshots.com/user/camaroman7d
  #9
Old Feb 4th, 06, 4:16 PM
http://www.jimmybiggstv.com/yourway/...tang-crash.wmv
Doug G.-406ci
1.643 - 60'
7.511 @ 91.33 -660'
  #10
Old Feb 4th, 06, 6:54 PM
Daren71 Daren71 is offline
Daren
I've got a Strange Engineering c clip eliminator kit. It was leaking into the right rear drum, after I replaced the seal, o-ring, and siliconed the mounting areas I've got no leaks. I think mine are the stock axles, with this kit installed. I will have to do regular maint., to make sure I don't trash another set of drum shoes. I will keep installed though, for the safety aspect. Daren
We're not splitting an atom here.
My '71
  #11
Old Feb 4th, 06, 10:45 PM
JUNK YARD DOG JUNK YARD DOG is offline
Wink Re: C Clip eliminators or not?
if your having the rear built do as the other man suggest get the ford ends or the olds ends whitch ever you perfer it will be cheaper than the c clip eliminators and you will never regret it
alan , gadsden ala. 66 chevelle bracket car best 6.95 in 1/8th big block now 67 nova bracket car best 6.739 in 1/8th 1.429 60ft at 100.45mph 400 sb
  #12
Old Feb 5th, 06, 8:34 AM
bracketchev1221 bracketchev1221 is online now
Whatever you decide to do, I would not use c-clips at all. I have the c-clip eliminators on my car but it is not a street car. I like the idea of using axles with the pressed on bearings.
Ray
http://www.dragtimes.com/1970-Chevro...ures-7479.html
Best pass so far 9.089 at 146.78, 1.266 60'.
  #13
Old Feb 5th, 06, 9:51 AM
BillsCamino BillsCamino is online now
Gold Founding Member
aka "Wild Bill"
Send a message via AIM to BillsCamino
Yeah...the only way to go!! Got plenty of street miles on mine.
'67 Malibu 4dr Sedan, w/ 460 cu,TH400 & 3.73 12 bolt posi
'69 SS 396 w/original L35, TH400, 3.07 12 bolt, factory A/C
Team Chevelle #613
ACES #3920
A.M.C. of Ireland #113
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #102
  #14
Old Feb 5th, 06, 12:06 PM
Harold Sutton Harold Sutton is offline
I really like the Ford rear ends as they are a better design than our Chevrolet's due to the fact that the pinion gear is supported on both ends. However it is possible to break anything with enough force. I've seen Fords break axles both inside and outside the outer wheel bearing race and both can damage your car. One i saw broke outside the race right outside the race and the wheel and tire got into a Mustang's fender bending it up pretty badly. Another guy put a Ford rear end with stock 28 spline axles in a high powered big block Chevy and the car went over the guardrail when the axle broke. Any car will make a hard turn if an axle breaks under power. It is advisable to always buy the best parts in any driveline application to avoid problems down the road, this is money wisely spent. My son is changing out his 1/2" studs to 5/8" high strength ones even though he hasn't had any problems with his current setup. These cars are getting so fast that the axles may not be the most dangerous thing about them.
  #15
Old Feb 5th, 06, 12:33 PM
isnt that what i'm advising?
Keep in mind, the cars that we're talking about here arent 1200hp shoot-out cars.
The car in question is a 12.00 ride, and the one i drive is an 11.30 ride.
Brian
You may not post new threads
You may not post replies
