Bench Racing Stories, cruising and more.
Old Jan 8th, 06, 8:59 AM
John D John D is offline
Team Member
John
Default Driveway - Asphalt vs. Concrete
OK guys, any "experts" out there, or people with experience??
Here's the deal. Need a new driveway. The existing (concrete) is all spalled, pitted, and only goes 1/2 way up from the street. The remaining 1/2 to the garage is gravel/class 5. I'm tired of the dirt in the house, and flinging rocks with the snowblower!
Dimensions: 14' wide at the garage, tapering to 12' wide at the street apron, 97' long. There will also be a 23' x 23' "L" off the side to complete the front of the garage and a "turn-out" area.
Had a guy out for an estimate yesterday. His outfit does asphalt. Gave me some very good reasons to think about asphalt vs. concrete - climate, temp. cycles, etc. They use a material called "M.C." (??), over a dolemite compacted base.
Quote includes all permits, removal, grading, fill, base, compaction, and product. Warranty against excessive cracking (??), failure, etc. Average life expectancy is 30+ years. Been in business for 51.
Cost: $10,719
'64 El Camino 383
'65 El Camino 327
'96 Roadmaster LT1
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, beer in hand, body thoroughly used up and screaming "WOO HOO what a ride!"
Old Jan 8th, 06, 9:19 AM
gigem gigem is offline
Fritz
Default Re: Driveway - Asphalt vs. Concrete
I remember the exact same question being posted here a year ago or so. Concrete was the overwhelming answer...
Old Jan 8th, 06, 9:23 AM
6t7gto 6t7gto is offline
concrete!
if it is installed correctly, no maintenace issues whatsoever.
asphalt needs to be coated periodically.
david
CITY GIRL CITY GIRL is offline
Concrete!!!
a little NOS wont hurt!
Old Jan 8th, 06, 9:32 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
You're in Minnessota - blocktop only. Concrete can not be salted. You will get frost heaves in the winter. All the new highway construction in the cold climates use concrete as a base then black top as a wear layer. Every concrete road in my area has been replaced or topped with blacktop. In a warm climate, I would do nothing but concrete, but where you get frezzing, it just doen't handle the winter conditions well.
2010 : .................................................. ...............Gone Cruising
  #6
Old Jan 8th, 06, 9:51 AM
BillsCamino BillsCamino is offline
Gold Founding Member
aka "Wild Bill"
Send a message via AIM to BillsCamino
Concrete!
It makes for better launches...
"Lord, I'm much too young to feel this damn old!"
'67 Malibu 4dr Sedan, Vortec/Voodoo 350 ,TH400 & 2.73 posi 12 bolt
'69 SS 396 w/original L35, TH400, 3.07 12 bolt, factory A/C
Team Chevelle #613
ACES #3920
A.M.C. of Ireland #113
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #102
  #7
Old Jan 8th, 06, 12:56 PM
EXSPANSION JOINTS, usually they do not put enough ...nicole
  #8
Old Jan 8th, 06, 3:30 PM
NiteOwlNY NiteOwlNY is offline
-Allan-
How about pavers? I would say asphault in a colder climate, it has a lot more give.
  #9
Old Jan 8th, 06, 7:04 PM
7t 7t is offline
thats almost 6 dollars a sq. ft. kind of high for blacktop.
around here the going rate for tare out and replace of concrete depending on sq. footage is $8 or less. you have very little tare out.most likely none of the gravel would need hauled away.
here you don't even need a permit for anything other than apron at street.
the ground freezes under blacktop as well as concrete. asphalt will heave.and crack because it is frozen and loses its ability flex like it does when its hot.
i have done dozens of huge freezers for Khans, Meijer,Walmart. not a one of them had a blacktop floor in them.
it boils down to blacktop is just cheaper to do and replace. done right (sub base) and properly sealed it should out last whoever poured it.
you may want to get another price for concrete and blacktop.funny someone thats been in business for 51 years would even do such a small job
jerry
70ss 396 4spd
  #10
Old Jan 8th, 06, 7:32 PM
Gloryhound Gloryhound is offline
Concrete with an integrated water/anti-freeze system so you do not have to worry about shovelling it off. Turn on the heater wait 30 minutes and your drive will have no snow on it, no salt needed! Also everytime you tar your drive you will be cleaning tar off the rear quarters of your chevelle for weeks!!
  #11
Old Jan 8th, 06, 7:34 PM
1badss396 1badss396 is offline
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Brick Pavers, I use them all the time for everything..
I bet you can get a price for $4.50 to $5.00 a square foot.
If your really interested I can order them for you and get a contractors rate for you.
Check them out
http://www.tremron.com/
" NO Replacement For Displacement" Any Questions?
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Top 3
2010 AACA First Place Grand National
  #12
Old Jan 8th, 06, 8:39 PM
Team Member
John
We had thought about pavers until this winter - when I saw a guy down the block trying to shovel/snowblow on them!
(Honestly I was a "concrete" guy until talking to this estimator - he pointed out the following points that relate to my climate:
Asphalt..
1) The material that's used is the same, roadway grade stuff on the streets.
2) Their base material is custom crushed to their specification - no pockets or air-space, water infiltration - complete compaction.
3) Asphalt never "hardens", remains pliable even at 20 below.
4) Asphalt is one continuous "sheet".
4) Being oil/petroleum based, water does not seep in.
5) The sealer they use is gas/oil/grease resistant. Asphalt won't get gooey if promptly cleaned off.
Concrete..
1) Expansion joints are just that. They are a pre-made point so the slab will crack at a certain place.
2) These cracks allow water to get in/under the slab.
3) Repeated freeze/thaw cycles will cause heaves at the expansion joints
4) Gas/oil/grease will stain concrete
5) Kick stands & pogo sticks won't dent concrete
I'm still listening guys... but remember - in a twelve month period of time we go from -20 to +102, with a dozen hard freeze/thaw cycles thrown in!
'64 El Camino 383
'65 El Camino 327
'96 Roadmaster LT1
  #13
Old Jan 8th, 06, 8:40 PM
daveseitz daveseitz is offline
John, Can the present concrete be resurfaced? One of the biggest costs is removal of old driveway. Get some members together on a Sat with a couple of pros and pour it. I know one guy who does this on the side if you want.
  #14
Old Jan 8th, 06, 8:59 PM
Bad Brad
Talking Re: Driveway - Asphalt vs. Concrete
John, you can also get pavers in 1'x1' or even 2'x2' squares, and should be the same price they go by the square foot all the same, that would make it alot easier to shovel the snow? We dont get snow here in Florida, LOL
Also they make a special paver sealer for them and you cant stain them with oil,ect.
ACES Top 3
  #15
Old Jan 8th, 06, 9:07 PM
Hal_396 Hal_396 is offline
Concrete, I live in Iowa and faced your same question back in 00. I went with concrete and have been extremely glad I did. They told me not to use any ICE melt on it the first winter. It still looks new. I keep the expansion cuts cleaned out but thats just me.
You may not post new threads
You may not post replies
