67 chevelle big block headers - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Dec 20th, 05, 10:10 PM
sansteve sansteve is offline
steve
Default 67 chevelle big block headers
I have a 67 chevelle with a 396 and my hooker super pro comp headers are hitting the steering rod coming from the fire wall,does anybody else have problems fitting these headers or have a solution to my problem?
Old Dec 21st, 05, 7:44 AM
kboorman kboorman is offline
Kirk
Default Re: 67 chevelle big block headers
If that's the only place they hit, you're lucky. You just have to dimple the header a little for clearance.
Kirk
My '66:
http://www.cardomain.com/ride/556053
Old Dec 23rd, 05, 8:22 PM
MJRIBEIRO MJRIBEIRO is offline
Mike
I have a set of thorleys (SP?) on mine - no problems with clearance.
Old Dec 23rd, 05, 10:23 PM
DaleM DaleM is offline
Gold Founding Member
Dale
I had a set of Hookers in my 67 when I first rebuilt it and had the same type problem. The 'medallion' on either 1 or 3 hit the steering column. Wouldn't even let the engine drop to the mount unless the column was turned so the narrow side was vertical. Once engine was bolted down I couldn't turn the steering wheel at all. I wound up having it towed to an exhaust shop to have the medallion cut off and the tube dimpled. Stupidest place to put a useless piece of metal I've ever seen. I can't honestly remember anyone having luck with Hookers on a 67 BB.
TC Gold #92 ~ August 1998
* Ever stop to think, and forget to start again?
* ChevelleStuff - Decoding info for 64-72 (For Sale)
* 1966/1967 Chevelle Reference CD/1970 Build Sheet Decoder CD
* Chevelle Registeries
* Build Sheet Data Collection
Old Dec 23rd, 05, 11:00 PM
Mr Chevelle Mr Chevelle is offline
Papa
I have a set of super comp #2213's with 2" primaries on my BB 67. They are up against the floor boards on the passenger side. I had to move a brake line on the drivers side. They were in there so tight I had almost no movement before I bolted them up. I didn't have any issues with the steering.
After all the hassle I still like them.
1969 300 Deluxe
  #6
Old Dec 24th, 05, 9:00 AM
Rick Bandy Rick Bandy is offline
We have a 65 and 66 both with 454 engines,one is a 396 car and the 65 was a 283 car. We had the same problem with a very slight rubbing on the steering shaft but neither had the Hooker medalion in that spot. A good hard wack with a socket and hammer put a small dimple the right spot to correct the problem.
  #7
Old Dec 24th, 05, 9:55 AM
Astro70SS Astro70SS is offline
Seems like the super comp's are really hit and miss...I have a set on my 70,And they fit perfect.
I have a buddy who ordered a set for a 78 vette.They didnt even come close to fitting...Called Hooker...Sent them back,They sent out another set,These didnt come close to fitting either...But were hitting in different area's then the first set.Finally the fourth set were close enough to work with...Hooker asked him to fit them up...Clearance them where they needed it...And then send them back to be recoated.
I guess he was Hookers R&D department for the 78vette...
70 Chevelle SS Clone 468 TH400 3.73's Here's A few vids my 70&87Gn
http://videos.streetfire.net/video/3...9358B33BEA.htm
http://videos.streetfire.net/Player....1-615A31D9666B
  #8
Old Dec 24th, 05, 11:41 AM
Motorhead62 Motorhead62 is offline
Chris
Send a message via AIM to Motorhead62
Cool Re: 67 chevelle big block headers
I like the fit and quality of Hedman Headers myself. My 67 Chevelle has 2" X 3" and they fit very nice. Only slight rubbing on the passenger side upper a-arm. It clearanced itself on the first cruise!
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Rat Muscle Parts Hauler)
1967 C10 Short-Wide 489BB/TH400/12-bolt (The Future Shop Truck)
2008 Harley Davidson Dyna Low Rider (Stress Buster)
2015 Harley Davidson Road Glide Special (Cruiser)
2013 Chevy Cruze RS Turbo (Daily Driver)
My Chevelle: http://www.chevelles.com/feature/nov98.html
C & D Performance
North Texas Chevelles
  #9
Old Dec 24th, 05, 12:48 PM
Chris R Chris R is offline
Im not sure if there would be much of a difference. But I have Super Comps in my 66SS and they fit fine. It is very close to the steering shaft but there was no clearancing on any header tubes needed.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
  #10
Old Dec 24th, 05, 7:57 PM
PRO65 PRO65 is offline
I have a 65 with a BB and the hooker headers hit my steering shaft also. Took them out and laid a 1/2" extension on the tube and gave it a good whack and now it slitley touches.
Derrell's 1965 Chevelle
  #11
Old Dec 24th, 05, 9:16 PM
Chuck Chuck is offline
Moderator
Chuck
Mee too. The Thorlesy headers dropped right in with only one small cut to shorten an upper control arm bolt that was sticking out a bit too far. The flanges are thick too. I have yet to lose a header gasket.
Chuck
Chuck Bonasera
Team Chevelle #385
Nor-Cal ChevelleCaminos
http://nor-cal.chevelles.net
My 65 Malibu SS
My 67 Super Sport
My 70 Super Sport
My 70 El Camino
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: 67 chevelle big block headers
Location
*REQUIRED*
Insurance
First Name
Human Verification
